1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro LCD 120V 1000VA 500W LineInteractive UPS, AVR, Tower, USB,
TEL/DSL/Coax Protection, 8 Outlets
MODEL NUMBER: SMART1000LCD
Highlights
Supports a basic desktop PC up
to 60 min. during power outage
Features 8 protected outlets—4
battery-protected, 4 surge-only
Offers automatic voltage
regulation (AVR)
LCD screen reports real-time
UPS and power status
Plugs into any NEMA 5-15R
socket
Package Includes
Provides reliable 1000VA/500W power protection for your desktop computer, network workstation,
audio/video components or media center. Protects against surges, line noise, blackouts and brownouts.
Description
The SMART1000LCD SmartPro LCD 120V, 1000VA/500W Line-Interactive Uninterruptible Power Supply
provides battery backup and AC power protection against blackouts, brownouts, power surges and line
noise that can damage electronics or destroy data. Ideal for backing up your desktop computer or
audio/visual components, this line-interactive UPS switches to battery backup mode in milliseconds to
keep your connected equipment running long enough to save files and shut down safely with no data loss.
While all eight NEMA 5-15R outlets protect against surges, four outlets also provide up to 3 hours of UPS
battery support for a DVR component, 60 minutes of support for a basic desktop PC and LCD monitor,
and 10 minutes of support at half load (250W).
Automatic voltage regulation (AVR) corrects undervoltages as low as 89V without using any battery
power. EMI/RFI noise filtering improves your equipment's performance and prevents damage. A 1038joule surge suppression rating protects your equipment from harmful power surges.
Space-saving NEMA 5-15P plug with 6-ft. (1.83 m) cord connects to any NEMA 5-15R socket and allows
furniture to be placed flush against the wall. Large rotatable LCD screen with dimmer shows real-time
input voltage, overload, AVR and battery statuses at a glance. With Tripp Lite's free PowerAlert software
(available via free web download), the SMART1000LCD enables safe unattended system shutdown and
file saves in case of a prolonged power failure.
Features
Reliable Battery Backup
● Provides 1000VA/500W high-performance power protection for desktop computers, audio/video
components, media centers and other electronics
Supports basic desktop computer and LCD monitor up to 60 minutes or single DVR components up to 3
hours during power outage
Supports 50% load (250W) up to 10 minutes and full load (500W) up to 3 minutes
97% full-load efficiency rating saves money in energy costs
Audible alarm indicates loss of utility power or low battery
Optimized Outlets
1/6
LCD 120V 1000VA/500W LineInteractive UPS
USB cable
Telephone cord
Owner’s Manual
Cleveland, OH 44122
United States
4 NEMA 5-15R outlets deliver battery backup for devices that require constant power
All 8 outlets protect against surges or spikes that can harm equipment or data
Automatic Voltage Regulation (AVR)
● Corrects undervoltages as low as 89V with a 14% boost without drawing battery backup power
Rotatable LCD Status Screen
● Large LCD screen shows real-time input voltage, overload, AVR and battery statuses
Rotates for easy viewing in both horizontal and vertical installations
Dimmer switch controls brightness level
AC Line, Coaxial and Tel/DSL Surge Suppression
● Surge suppression rating of 1038 joules protects connected equipment and data from harmful power
surges
Tel/DSL RJ11 jacks and included cord protect standard dialup/DSL phone connection
2.2 Hz coaxial jacks protect CATV, broadband cable internet, satellite or broadcast antenna connections
EMI/RFI Line Noise Filtering
● Removes electromagnetic and radio frequency interference that can disrupt or damage your
USB Communication Port and Free PowerAlert Software
● HID-compliant USB port integrates with built-in power management and auto-shutdown of Windows and
Mac OS X
Works with Tripp Lite PowerAlert software available as free web download from
tripplite.eaton.com/products/power-alert, to enable safe, unattended system shutdown and file saves
during prolonged power failure
Flexible Installation Options
● Space-saving NEMA 5-15P right-angle plug with 6-ft. (1.83 m) cord connects to any NEMA 5-15R
socket
Adapts to vertical or horizontal installation without special hardware
Specifications
OVERVIEW
UPC Code
037332124999
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
12A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P; Right-Angled
2/6
Cleveland, OH 44122
United States
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
Output Capacity (Watts)
500
Output Capacity (kW)
0.5
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Battery
Mode)
+/- 5%
UPS Output Receptacles (Surge
Suppression Only)
4 UPS outlets, 4 surge-only outlets
Hot-Swap PDU options
PDUB15 (2U / 8 5-15R outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(8) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3 min. (500W)
Runtime Half Load (min.)
10 min. (250W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 16 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC51
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 89
3/6
Cleveland, OH 44122
United States
Undervoltage Correction
Input voltages between 89 and 104 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Backlighted LCD screen indicates input voltage, 5-bar battery charge level, overload, AVR, on battery and replace
battery status; LCD screen rotates for rack/tower viewing
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; dimmer switch controls LCD brightness
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery status; alarm can be disabled using PowerAlert software
LED Indicators
Front panel LCD display
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
1038
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); Coax jacks (1 set)
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower; Ultra-compact desktop
Primary UPS Depth (mm)
184
Primary UPS Height (mm)
301
Primary UPS Width (mm)
93
Shipping Dimensions (hwd / in.)
15.40 x 4.80 x 10.60
Shipping Dimensions (hwd / cm)
39.12 x 12.19 x 26.92
Shipping Weight (lbs.)
16.70
Shipping Weight (kg)
7.57
UPS Housing Material
ABS
UPS Power Module Dimensions
(hwd, cm)
30.07 x 9.30 x 18.39
(hwd, in.)
11.84 x 3.66 x 7.24
UPS Power Module Weight (kg)
7.05
UPS Power Module Weight (lbs.)
15.55
Unit Weight (lbs.)
14.9000
Unit Weight (kg)
6.76
ENVIRONMENTAL
4/6
Cleveland, OH 44122
United States
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
61
Battery Mode BTU / Hr. (Full Load)
510
AC Mode Efficiency Rating (100%
Load)
97%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in USB port, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network UPS Tools (NUT)
Compatibility
NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite
Network Management Card
Description
Network management not supported
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
3 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
89
High Voltage Transfer to Battery
Power (Setpoint)
139
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
3-year limited warranty
Product Warranty Period (Latin
America)
(International)
2-year limited warranty
5/6
Cleveland, OH 44122
United States
Product Warranty Period (Mexico)
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
