1000 Eaton Boulevard
Cleveland, OH 44122
United States
OmniSmart 120V 330VA 225W UL 60601-1
Medical Grade Line-Interactive UPS, Tower, DB9
Serial
Highlights
330VA line interactive tower
UPS
Maintains sine-wave 120V
nominal output over an input
range of 83 to 132V
Professional features include
serial port, hospital grade plug &
outlets, built-in isolation
transformer and UL60601-1
listing
Input: Hospital-grade NEMA 515P (120V 15A) / Output: 4
Hospital-grade NEMA 5-15R
(120V)
2 line phone suppression for
TEL/DSL line protection
Leakage current less than 100
microamps
Approved for use within the
Patient Care Vicintiy
Approved to EN60601-1-2:2015
& IEC60601-1-2:2014, 4th
Edition
MODEL NUMBER: OMNISMART350HG
Package Includes
Description
Tripp Lite's OMNISMART350HG offers medical-grade UPS protection with built-in line interactive voltage
regulation, intelligent monitoring and unattended shutdown capability. Hospital-grade plug & outlets, plus
built-in isolation transformer with Faraday shield offers full isolation and removes common mode noise
equal to 100 microamps. UL 60601-1 listed as medical electrical equipment. 330VA power handling
capacity supports computers, inter-networking equipment and other critical loads during commercial
power failures. Line interactive voltage regulation corrects brownouts as low as 83V back to normal 120V
levels, saving battery reserves for use only during complete power failures. Includes, 2 line phone surge
suppression and built-in DB-9 communications port that works with PowerAlert Software and cabling to
provide automatic unattended shutdown of connected network and PC applications.
Application Usage
This UPS contains a lead acid battery designed to be connected continuously to an AC power source,
except during brief power outages. It is not intended for frequent charge/discharge cycles, such as mobile
cart applications where the UPS is often disconnected from the power source. Using the
OMNISMART350HG in this type of application will void the battery warranty.
Features
Ideal UPS protection for applications in medical patient-care areas where UL 60601-1 listed electrical
medical equipment is required
Line-interactive voltage regulation corrects brownouts as low as 83V without using battery power
Hospital-grade plug and outlets offer added degree of safety and reliability to input/output connections
Full line isolation prevents shock potential and operational problems in sensitive electronic equipment
Resistant to electrostatic discharge
Supports loads up to 330VA/225 watts
46 minutes half load runtime (with 165VA load), 18 minutes full load runtime (with 330VA load)
4 protected hospital-grade outlets; 6-ft. cord
1-DB9 serial port for network interface
Complete surge protection, line isolation and EMI/RFI noise filtering
2 phone line surge suppression for modems, fax machines and other phone accessories
Complete remote monitoring cabling included, PowerAlert UPS management software available via free
1/5
OMNI SMART 350HG Hospital
Grade UPS System
Serial cable for remote
monitoring
Warranty information
Instruction manual
Cleveland, OH 44122
United States
download
4 diagnostic LEDs indicate AC present, on battery, voltage correction & battery low/replace
Battery replacement door and back panel grounding lug
Specifications
OVERVIEW
UPC Code
037332098542
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
2.3A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P-HG
Input Circuit Breakers
3.5A
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
330
Output Capacity (kVA)
0.33
Output Capacity (Watts)
225
Output Capacity (kW)
0.225
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-18%, +8%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Output Receptacle Details
Hospital grade output receptacles
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(4) 5-15R
Individually Controllable Load Banks
No
2/5
Cleveland, OH 44122
United States
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
18 min. (225W)
Runtime Half Load (min.)
46 min. (113W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC52 (quantity 2)
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 89
Undervoltage Correction
Input voltages between 89 and 107 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
4 LEDs indicate line power, battery power, overload and battery low/replace status
ISOLATION
Output Isolation Transformer
Hospital grade load isolation transformer
SURGE / NOISE SUPPRESSION
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
2 line TEL/DSL
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
183
3/5
Cleveland, OH 44122
United States
Primary UPS Height (mm)
274
Primary UPS Width (mm)
132
Shipping Dimensions (hwd / in.)
14.00 x 8.00 x 10.10
Shipping Dimensions (hwd / cm)
35.56 x 20.32 x 25.65
Shipping Weight (lbs.)
27.80
Shipping Weight (kg)
12.61
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
27.43 x 13.21 x 18.29
(hwd, in.)
10.8 x 5.2 x 7.2
UPS Power Module Weight (kg)
11.34
UPS Power Module Weight (lbs.)
25
Unit Weight (lbs.)
25.0000
Unit Weight (kg)
11.34
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
48.8
Battery Mode BTU / Hr. (Full Load)
215.8
AC Mode Efficiency Rating (100%
Load)
94%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
DB9 serial cable included
Network Management Card
Description
Network management not supported
Communications Interface
DB9 Serial
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
89
High Voltage Transfer to Battery
Power (Setpoint)
139
4/5
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Hot swappable batteries; Surge/noise protection
Grounding Lug
Grounding lug
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); UL 1778; UL 60601-1
Product Compliance
RoHS; FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“OMNISMART350HG”相匹配的价格&库存,您可以联系我们找货
