1000 Eaton Boulevard
Cleveland, OH 44122
United States
550VA 340W 120V Line-Interactive UPS - 12
NEMA 5-15R Outlets, Double-Boost AVR, USB,
Desktop/Wall-Mount
Highlights
Protects equipment against
blackouts, brownouts, transient
surges and line noise
Keeps AC power running during
blackouts to allow time for file
saves and safe shutdown
Double-boost AVR maintains
120V nominal output during
brownouts and overvoltages
12 NEMA 5-15R outlets power
and protect PC, home theater or
digital signage equipment
High >98.3% efficiency and low
BTU ratings save electricity and
lower your energy costs
MODEL NUMBER: OMNISMART550MX
Applications
Protect your PC and other
sensitive electronics against
power surges, line noise,
brownouts, overvoltages and
blackouts
Operate essential equipment
during short-term power outages
using battery backup power
Shut down desktop PCs and
other equipment without data
loss during long-term power
outages
Extend runtime for DVRs,
wireless routers and other lowpower home network equipment
Desktop UPS offers complete power protection for small network applications, including home offices,
security systems and digital signage.
Features
550VA/340W/120V Battery Backup for PCs, Home Theaters or Digital Signage
This OmniSmart® line-interactive UPS system with AVR protection provides reliable battery backup and
AC power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage
valuable electronics or destroy data. The 120V battery backup is ideal protection for your home office,
media center or commerce components, including computers, routers, printers, HDTVs, Blu-ray players,
game consoles, ATMs, security systems and digital signage equipment.
Package Includes
Allows Time to Back Up Critical Files During a Blackout
Backup support allows you to work through short power failures and gives you enough time to safely save
files and shut down your system in case of a prolonged blackout. Backup time varies according to load,
but internal battery should keep a half load (170W) powered as long as 10 minutes and a full load (340W)
up to 3.6 minutes. During normal operation, incoming utility power keeps the replaceable internal battery
fully charged, so backup power will always be available.
12 NEMA 5-15R Outlets Protect Your Connected Components
Six 5-15R outlets provide battery backup, surge protection and voltage regulation for your computer,
monitor and other crucial components. The other six 5-15R outlets provide surge suppression only for
printers, speakers and other desktop equipment regarded as non-essential during a blackout. In addition,
RJ45 jacks protect a telephone/DSL dial-up or 10BaseT Ethernet connection.
Double-Boost AVR Corrects Low/High-Voltage Conditions for Enhanced Performance
A double-boost, single-cut AVR (Automatic Voltage Regulation) circuit, designed specifically for the
LATAM region, protects your equipment from incremental hardware damage, data loss and performance
problems caused by brownouts and overvoltages. Slight under-voltages as low as 93V are boosted by
13%. More severe brownouts as low as 78V are increased by 35%. A voltage cut of 16% reduces UPS
output during overvoltage conditions as high as 152V, all while keeping the battery fully charged and
ready to take over in case of power failure.
600 Joules Fight Back Against Unexpected Power Surges
A 600-joule surge suppression rating protects connected components from the harmful effects of power
surges.
1/6
OMNISMART550MX 550VA
UPS with 12 Outlets
USB cable
Owner’s manual
Cleveland, OH 44122
United States
Designed for High Efficiency to Help You Save Money and Protect the Environment
A >98.3% efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy
costs.
Combats Electromagnetic Interference That Can Harm Equipment
Various electromagnetic and radio sources found in virtually every home and business can cause
disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio
frequency interference), this line noise is a common cause of performance problems and can lead to
incremental hardware damage, data corruption and audio/video transmission problems. The
OMNISMART550MX incorporates technology that filters out disruptive line noise so that it won't affect
your equipment.
Alarm and Diagnostic LEDs Keep You Informed 24/7
The alarm sounds to report low battery, battery replace, overload and fault condition. A set of 4 LEDs
reports AC line present (green), battery mode (yellow), overload/low battery (red) and battery replace
(red).
USB Port Allows for Automatic Saves and Shutdowns
The HID-compliant USB port connects the UPS to a computer running free downloadable PowerAlert®
software to enable safe unattended system shutdown in case of a prolonged power failure. USB cable is
included.
Compact Housing Compatible with Easy Desktop or Wall-Mount Installation
The space-saving UPS fits on a desktop, shelf or any other flat surface convenient to your workstation or
home theater. Keyhole mounting tabs on the rear allow easy wall installation. The five-foot power cord
with space-saving right-angle NEMA 5-15P plug connects to any compatible AC outlet.
Specifications
OVERVIEW
UPC Code
037332256096
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
6A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P; Right-Angled
Input Circuit Breakers
7A
UPS Input Cord Length (ft.)
7
UPS Input Cord Length (m)
2.1
Input Frequency
60 Hz (±3%)
OUTPUT
Output Capacity (VA)
550
Output Capacity (kVA)
0.55
2/6
Cleveland, OH 44122
United States
Output Capacity (Watts)
340
Output Capacity (kW)
0.34
Output Capacity Details
4.6A @ 120V. Supports 125% load for 10 minutes, 20 seconds (load PF=1.0); Supports 110% for up to 27 seconds
Power Factor
0.6
Nominal Voltage Details
120v nominal output in AC and battery modes
Frequency Compatibility
60 Hz
Frequency Compatibility Details
60 Hz (±3%) tolerance
Output Voltage Regulation (Line
Mode)
120V~ (+8% / -15%)
Output Voltage Regulation (Battery
Mode)
120V (±5%)
UPS Output Receptacles (Surge
Suppression Only)
6 UPS outlets, 6 surge-only outlets
Output AC Waveform (AC Mode)
Pure sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(12) 5-15R
Output Amp Capacity
4.6A @ 120V~
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3.6 min. (340W)
Runtime Half Load (min.)
10 min. (170W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
5 hours to 90%
Battery Access
Battery access door
Battery Replacement Description
Replaceable internal batteries (see manual)
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 78 to 152
Overvoltage Correction
Input voltages between 128 and 152 are cut by 16%
Undervoltage Correction
Input voltages between 93 and 108 are boosted by 13%
Severe Undervoltage Correction
Input voltages between 78 and 93 are boosted by 35%
3/6
Cleveland, OH 44122
United States
USER INTERFACE, ALERTS & CONTROLS
Switches
Switch supports On/Off power control (release after 3 seconds), UPS battery-test (line mode only, release after 5
seconds), Alarm-mute (battery mode only, release after 0.5 seconds)
Alarm Cancel Operation
Manual alarm-cancel supported
Audible Alarm
Alarm sounds to report Battery-mode operation, Low-battery status, Overload status and UPS Battery test modelowbattery, fault, overload and replace-battery conditions
LED Indicators
2 Status LEDs; GREEN indicates power status and operating mode / RED indicates battery-low, overload, replacebattery and fault conditions (see manual)
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
600
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL or Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Desktop
Rack Height
0U
Installation Form Factors Supported
with Included Accessories
Tower; Ultra-compact desktop; Wallmount
Primary UPS Depth (mm)
305
Primary UPS Height (mm)
105
Primary UPS Width (mm)
190
Shipping Dimensions (hwd / in.)
10.71 x 6.30 x 15.00
Shipping Weight (kg)
6.00
UPS Power Module Dimensions
(hwd, in.)
4.14 x 7.48 x 12
UPS Power Module Weight (kg)
5.50
UPS Power Module Weight (lbs.)
12.13
Unit Dimensions (hwd / in.)
4.140 x 7.480 x 12.000
Unit Weight (lbs.)
12.130
Unit Weight (kg)
5.50
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 113°F (-15° to 45°C )
Relative Humidity
0 to 90%, non-condensing
AC Mode BTU / Hr. (Full Load)
23.21
4/6
Cleveland, OH 44122
United States
AC Mode Efficiency Rating (100%
Load)
>98.3%
AC Economy Mode Efficiency Rating
(100% Load)
98.3%
Operating Elevation (ft.)
3,000 m above the sea level
Operating Elevation (m)
Up to 3000m
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB interface cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network Management Card
Description
Network management not supported
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
2-6 milliseconds (typical), 10 milliseconds (max)
Low Voltage Transfer to Battery
Power (Setpoint)
78
High Voltage Transfer to Battery
Power (Setpoint)
152
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
Grounding Details
Includes side-panel grounding lug
APPLICATIONS
UPS Applications
Home/Office Desktop
STANDARDS & COMPLIANCE
Product Certifications
RETIE (Colombia); CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; EAC (Belarus, Kazakhstan, Russia); ENERGY STAR Qualified; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
2-year limited warranty
Product Warranty Period (Latin
America)
5/6
Cleveland, OH 44122
United States
(International)
Product Warranty Period (Mexico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
