1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 230V 1.5kVA 940W Line-Interactive
UPS, Tower, DB9, 6 Outlets
MODEL NUMBER: SMARTINT1500
Highlights
Corrects under- and
overvoltages from 165V to 277V
6 IEC-320-C13 outlets
Front-panel LEDs indicate load,
power and battery statuses
Monitoring of power conditions
via PowerAlert®
20 min. runtime at half load; 7
min. at full load
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, power surges and line noise. Ideal solution for VoIP systems, point-of-sale applications and
network closets.
Description
The SMARTINT1500 SmartPro 230V 1.5kVA 940W Line-Interactive UPS provides battery backup and AC
power protection against blackouts, brownouts, power surges and line noise that can damage electronics
or destroy data. Ideal for backing up VoIP systems, point-of-sale applications and network closets, the
SMARTINT1500 switches to battery mode in milliseconds to keep your connected equipment running long
enough to save files and shut down safely with no data loss.
Featuring six IEC-320-C13 outlets and two C13-to-C14 power cords, the SMARTINT1500 has an internal
battery that provides 20 minutes of support at half load and seven minutes at full load. Front-panel LEDs
indicate line power, battery power, load level, voltage regulation and battery status. An alarm sounds to
indicate power failure or a low battery.
Automatic voltage regulation (AVR) maintains 230V nominal output over an input range of 165V to 277V
without using battery power. EMI/RFI noise filtering improves your equipment’s performance and prevents
damage. A 480-joule surge suppression rating protects your equipment from harmful power surges. With
Tripp Lite’s PowerAlert software (available via free download), SMARTINT1500 enables safe unattended
system shutdown and file saves in case of a prolonged power failure.
Features
Protects Mission-Critical Equipment
● Provides fully regulated AC output for VoIP systems, point-of-sale applications and network closets
Audible alarm signals loss of utility power or low battery
C14 inlet
Reliable Battery Backup
● Supports half load up to 20 min. and full load up to 7 min.
Internal batteries designed for hot-swap field replacement
94% line-power efficiency rating saves money in energy costs
1/5
UPS
(2) IEC-320 C13-to-C14 power
cables
(2) DB9 cables
Owner’s manual
Cleveland, OH 44122
United States
Cold-start capability enables turn-on in battery mode during blackouts
Automatic Voltage Regulation (AVR)
● Maintains 230V nominal output over input range of 165V–277V without using battery power
EMI/RFI Line Noise Filtering
● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s
performance
LED Indicators
● Front-panel LEDs signal indicate line power, battery power, load level, voltage regulation and battery
status
Communications Port
● DB9 port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Small-Footprint Tower Housing
● Mounts on wall with optional UPSWM accessory
Specifications
OVERVIEW
UPC Code
037332033925
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
6.5A
Nominal Input Voltage(s) Supported
230V AC
UPS Input Connection Type
C14 inlet
Input Circuit Breakers
10A
OUTPUT
Output Capacity (VA)
1500
Output Capacity (kVA)
1.5
Output Capacity (Watts)
940
Output Capacity (kW)
0.94
Nominal Voltage Details
230V nominal output in battery mode
Frequency Compatibility
50 / 60 Hz
2/5
Cleveland, OH 44122
United States
Frequency Compatibility Details
Automatic frequency selection
Output Voltage Regulation (Line
Mode)
-15%, +8%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Included Output Power Cables
Includes 2 C13 to C14 output power cables
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(6) C13
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
7 min. (940W)
Runtime Half Load (min.)
20 min. (470W)
Expandable Runtime
No
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 4 hours from 10% to 90% (typical, full load discharge)
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC53
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 166 to 277
Overvoltage Correction
Input voltages between 243 and 277 are reduced by 12%
Undervoltage Correction
Input voltages between 191 and 215 are boosted by 10%
Severe Undervoltage Correction
Input voltages between 165 and 190 are boosted by 22%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
3/5
Cleveland, OH 44122
United States
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
234
Primary UPS Height (mm)
325
Primary UPS Width (mm)
191
Shipping Dimensions (hwd / in.)
17.00 x 11.20 x 13.10
Shipping Dimensions (hwd / cm)
43.18 x 28.45 x 33.27
Shipping Weight (lbs.)
40.30
Shipping Weight (kg)
18.28
UPS Housing Material
Polycarbonate
UPS Power Module Dimensions
(hwd, cm)
32.51 x 19.05 x 23.37
(hwd, in.)
12.8 x 7.5 x 9.2
UPS Power Module Weight (kg)
17.51
UPS Power Module Weight (lbs.)
38.6
Unit Weight (lbs.)
38.6000
Unit Weight (kg)
17.51
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode Efficiency Rating (100%
Load)
94%
COMMUNICATIONS
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; contact closure communications via 2nd DB9 port (2
total)
4/5
Cleveland, OH 44122
United States
PowerAlert Software
For local monitoring via the UPS’s built-in DB9 port, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
2 DB9 cables included
Network Management Card
Description
Network management not supported
Communications Interface
Contact closure; DB9 Serial
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
165
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); GOST (Russia); IEC/EN 62040; IRAM (Argentina); UL 1778
Product Compliance
RoHS; SASO (Saudi Arabia); CE (Europe)
WARRANTY & SUPPORT
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“SMARTINT1500”相匹配的价格&库存,您可以联系我们找货
