1000 Eaton Boulevard
Cleveland, OH 44122
United States
TAA SmartPro 208/120V 5kVA 4kW LineInteractive Sine Wave UPS, 6U, Extended Run,
Network Card Options, USB, DB9
Highlights
Federal Trade Agreements Act /
TAA Compliant for GSA
Schedule purchases
5kVA / 5000VA / 4000W line
interactive 6U rack/tower UPS,
Sine wave output
208 & 120V output during
brownouts to 151V and
overvoltages to 260V
USB, RS232, EPO and slot for
network communication card
options
Expandable runtime, 8 singleoutlet switched output load
banks
NEMA L6-30P input, 10 5-15R,
2 5-15/20R, 1 L6-30R & 1 L1430R outlets
To use the Auto Probe feature,
this product requires a
WEBCARDLX network interface
(sold separately) running LX
firmware update 15.5.2 or later
MODEL NUMBER: SM5000RT3UTAA
Package Includes
Description
Tripp Lite's line-interactive SM5000RT3UTAA UPS System is compliant with the Federal Trade
Agreements Act (TAA) for GSA Schedule purchases. This UPS protects server, networking or
telecommunications equipment from blackouts, voltage fluctuations and surges in a compact
tower/rackmount housing. In rack configuration, the power module and battery pack occupy only 3 rack
spaces (3U) each. Large capacity 5000VA/4000W power module converts raw 208V AC input to fully
regulated dual output 208/120 voltage for simultaneous protection of both high- and low-voltage
equipment loads. True sine wave output at all times offers guaranteed compatibility with all equipment
types. Includes 14 outlets, 8 of which can be individually reset via software interface to selectively reboot
remote equipment or shed less critical loads to extend battery runtime for more critical equipment. Battery
support can be extended indefinitely with additional external 3U rackmount battery packs. Network
management interfaces support communications via USB, RS-232 and optional slot for network
management card options.
Features
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Large 5000VA/4000W output capacity with full-time sine wave output offers guaranteed compatibility
with all equipment types
High power density 5kVA power module and battery pack occupy only 3 rack spaces (3U) each (UPS
and battery pack require 6U total installed)
38 min. half load runtime, expandable with multiple external battery packs (part# BP48V60RT3U)
Line-interactive voltage regulation corrects severe brownouts and overvoltages without using battery
power
Dual voltage output is simultaneously compatible with both 208V and 120V equipment
14 total outlets (120V: 10 x 5-15R, 2 x 5-20R/208V: 1 x L6-30R, 1 x L14-30R)
Diagnostic LEDs provide visual indication of 17 separate performance conditions
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
4 built-in communications ports (2 x DB9, 2 x USB) for remote monitoring and unattended shutdown
Compatible with Tripp Lite UPS management card options WEBCARDLX and SNMPWEBCARD
1/6
BP48V60RT3U battery pack
USB, DB9 and EPO Cabling
Mounting hardware
Instruction manual with warranty
information
Cleveland, OH 44122
United States
8 customized load management receptacles can be individually powered off and back on again via
software interface to reboot remote equipment or perform "load shedding" of less critical loads to extend
battery runtime for the most critical equipment
Emergency Power Off (EPO) interface for emergency shutoff in large facilities
Hot-swappable/user replaceable batteries allow on-site battery replacement through the front panel
without powering off connected equipment or removing the UPS from the rack
UPS battery set ships fully assembled and ready for connection to the power module, no time
consuming, connection of individual internal batteries by user is necessary
$250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
NAFTA compliant
Specifications
OVERVIEW
UPC Code
037332161475
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Nominal Input Voltage(s) Supported
208V AC
UPS Input Connection Type
L6-30P
Input Circuit Breakers
30A double-pole
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
30A 208V
OUTPUT
Output Capacity (VA)
5000
Output Capacity (kVA)
5
Output Capacity (Watts)
4000
Output Capacity (kW)
4
Output Capacity Details
Maximum output increases to 4800W when hardwire or user supplied 50A rated input plug is used
Power Factor
0.8
Nominal Voltage Details
208/120V nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
208 & 120V (-10%, +20%)
Output Voltage Regulation (Battery
Mode)
+/- 5%
Load Management Receptacles
Eight switchable single-outlet 5-15R load banks
2/6
Cleveland, OH 44122
United States
Output Circuit Breakers
15A branch rated (x3) - 2 breakers support 5 5-15R outlets each, one breaker supports 2 5-20R outlets, L6-30R and
L14-30R outlets are unbreakered
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V; 208V
Output Receptacles
(10) 5-15R; (2) 5-15/20R; (1) L14-30R; (1) L6-30R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
16 min. (4000W)
Runtime Half Load (min.)
38 min. (2000W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP48V24-2U (limit 1); BP48V60RT-3U (multi-pack compatible); BP48V272US (multi-pack compatible)
DC System Voltage (VDC)
48
Battery Recharge Rate (Included
Batteries)
3 hours
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 151 to 282
Overvoltage Correction
Input voltages between 240V and 282 are reduced by 12%
Undervoltage Correction
Input voltages between 180V and 199 are boosted by 12%
Severe Undervoltage Correction
Input voltages between 151V and 179 are boosted by 24%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure, overload and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
1020
UPS AC Suppression Response
Time
Instantaneous
3/6
Cleveland, OH 44122
United States
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
6U
Cooling Method
Fans
Included Battery Pack Dimensions
(hwd / in.)
5.2 x 17.5 x 22.8
Included Battery Pack Weight (lbs.)
135
Included Battery Pack Weight (kg)
61.23
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Minimum Required Rack Depth (cm)
7.62
(inches)
3
Minimum Required Rack Depth with
External Battery Pack (cm)
75
External Battery Pack (in.)
29.5
without External Battery Pack (cm)
72
without External Battery Pack (in.)
28.25
Optional Mounting Accessory Notes
2 sets of 2POSTRMKITHD required for 2 post
rackmount installation of separate power module and battery pack
Primary UPS Depth (mm)
572
Primary UPS Height (mm)
132
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
24.50 x 35.00 x 24.00
Shipping Dimensions (hwd / cm)
62.23 x 88.90 x 60.96
Shipping Weight (lbs.)
321.62
Shipping Weight (kg)
145.88
Unit Dimension Details
Includes 3U UPS/power module and 3U external battery pack
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.21 x 44.45 x 57.15
(hwd, in.)
5.2 x 17.5 x 22.5
4/6
Cleveland, OH 44122
United States
UPS Power Module Weight (kg)
42.18
UPS Power Module Weight (lbs.)
93
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
Battery Mode BTU / Hr. (Full Load)
1518
AC Mode Efficiency Rating (100%
Load)
94%
Audible Noise
45 dBA maximum, front side 1m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; WEBCARDLX
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; 2 USB ports, 1 DB9 serial and 1 DB9 contact
closure port (4 total)
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
Contact closure; DB9 Serial; USB
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
151
High Voltage Transfer to Battery
Power (Setpoint)
282
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection
Grounding Lug
Back panel grounding lug
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
5/6
Cleveland, OH 44122
United States
Product Compliance
RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
