SU5000XFMR2UTAA
SU5000XFMR2UTAA
    TRIPPLITE
    SMARTONLINE STEP-DOWN ISOLATION
SU5000XFMR2UTAA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline Step-Down Isolation Transformer, 208V to 120V, 5kVA, 5kW, 2U Rack-Mount, TAA MODEL NUMBER: SU5000XFMR2UTAA Highlights ● Converts high-voltage AC output into low voltage for powering low-voltage equipment ● 12 NEMA 5-15/20R outlets for connecting components with 515P or 5-20P plugs ● Resettable circuit breakers protect connected equipment from hazardous overloads ● NEMA L6-30R outlet accepts high-voltage equipment ● Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Applications ● Connecting low-voltage (120V) equipment to a high-voltage (208V) AC power source Package Includes 5kVA 5kW transformer converts UPS, utility, generator or other 208V input to 120V for powering lowvoltage AC components. ● SU5000XFMR2UTAA SmartOnline Step-Down Isolation Transformer Features ● Rack-mounting hardware 208V to 120V Isolation Transformer Converts High-Voltage Input to Low-Voltage OutputThe 5kVA 5kW SU5000XFMR2UTAA SmartOnline® Step-Down Isolation Transformer converts your UPS, utility or generator's 208V high-voltage input to 120V low-voltage output. It features 12 NEMA 5-15/20R outlets for connecting equipment with common NEMA 5-15P and NEMA 5-20P plugs. Four resettable 20A circuit breakers protect your low-voltage equipment against overload conditions. One NEMA L6-30R outlet supports high-voltage output. The 5kVA transformer's 10-ft. (3.05 m) power cord with 208V 30A input connects to a NEMA L6-30R outlet. ● Owner’s manual Versatile Installation OptionsHardware is included for mounting this 208V to 120V isolation transformer in 2U of space in an EIA-standard 19-inch 4-post rack with a maximum depth requirement of 20.75 inches. Use the optional 2POSTRMKITWM for 2-post rack mounting or the optional 2-9USTAND for mounting in an upright tower position (both accessories sold separately). TAA-Compliant UPS for GSA Schedule PurchasesThe SU5000XFMR2UTAA is compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. 2-Year Warranty and Environmentally Responsible DesignThe SU5000XFMR2UTAA comes with a 2year warranty. It's manufactured in compliance with strict RoHS specifications. Specifications OVERVIEW UPC Code 037332214645 Accessory Type Isolation Transformer Accessory Class UPS Accessories 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Nominal Input Voltage(s) Supported 208V AC UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 208V 30A Maximum Input Amps 24 Input Connection Type NEMA L6-30P Voltage Compatibility (VAC) 120 Input Frequency 60 Hz OUTPUT Frequency Compatibility 60 Hz Output Receptacles (12) 5-15/20R; (1) L6-30R Output Nominal Voltage 120/208V AC Overload Protection Includes 4 built-in 20A circuit breakers. Each breaker protects 3 5-15/20R outlets each. PHYSICAL Material of Construction Steel Form Factors Supported Rack/Tower (2U) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Minimum Required Rack Depth (cm) 60.96 Minimum Required Rack Depth (inches) 24 Shipping Dimensions (hwd / in.) 8.60 x 19.90 x 23.40 Shipping Dimensions (hwd / cm) 21.84 x 50.55 x 59.44 Shipping Weight (lbs.) 74.50 Shipping Weight (kg) 33.79 Unit Dimensions (hwd / in.) 3.500 x 17.500 x 20.750 Unit Dimensions (hwd / cm) 8.9 x 44.5 x 52.7 Unit Weight (lbs.) 57 Unit Weight (kg) 25.85 ENVIRONMENTAL Relative Humidity 0-95% (non-condensing) STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SU5000XFMR2UTAA 价格&库存
很抱歉,暂时无法提供与“SU5000XFMR2UTAA”相匹配的价格&库存,您可以联系我们找货
