1000 Eaton Boulevard
Cleveland, OH 44122
United States
TAA-Compliant AVR Series 120V 900VA 480
Ultra-Compact Line-Interactive UPS with USB
port
Highlights
Federal Trade Agreements Act /
TAA Compliant for GSA
Schedule purchases
900VA ultra-compact 120V line
interactive UPS
Corrects brownouts and
overvoltages from 83V to 147V
6 UPS battery supported outlets,
6 surge-only outlets
USB port, TEL/DSL protection,
Wall mountable, 98% efficient
NEMA 5-15P input plug and 12
NEMA 5-15R outlets
MODEL NUMBER: AVR900UTAA
Package Includes
Description
Tripp Lite's AVR900UTAA Ultra-Compact Line Interactive UPS offers complete power protection for
desktop PCs, network workstations and a wide variety of professional and consumer electronic devices.
Uninterruptible Power Supply / UPS circuits switch to battery backup mode within milliseconds to keep
connected equipment running without interruption or data loss during power failures. Automatic Voltage
Regulation / AVR power conditioning maintains smooth, continuous operation of connected equipment
during brownouts and overvoltages. Surge-only outlets offer convenient protection for printers and other
desktop accessories not requiring battery support. AC and dataline surge suppression prevents connected
equipment damage. USB communications port supports built-in power management and auto-shutdown
features of Windows and Mac OS X or full featured monitoring and data-saving auto-shutdown options
using Tripp Lite's free PowerAlert monitoring software.
Specifications
OVERVIEW
UPC Code
037332152756
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
12A
Nominal Input Voltage(s) Supported
120V AC
1/4
AVR900UTAA TAA Compliant
UPS System
USB cable
Instruction manual
Cleveland, OH 44122
United States
UPS Input Connection Type
5-15P; Right-Angled
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
900
Output Capacity (Watts)
480
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
120V (+8%, -21%)
Output Voltage Regulation (Battery
Mode)
115V (+/- 5%)
UPS Output Receptacles (Surge
Suppression Only)
6 UPS outlets, 6 surge-only outlets
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
115V; 120V
Output Receptacles
(12) 5-15R
Individually Controllable Load Banks
No
BATTERY
Runtime Half Load (min.)
10 min. (240w)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC51
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147
Overvoltage Correction
Input voltages between 129 and 147 are reduced by 12%
Undervoltage Correction
Input voltages between 83 and 104 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
Combination switch controls on/off power status and self-test operation
Audible Alarm
Audible alarm indicates power-failure and overload status
2/4
Cleveland, OH 44122
United States
LED Indicators
2 LEDs indicate power status and overload/check battery status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
420
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 2 out)
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Desktop
Installation Form Factors Supported
with Included Accessories
Tower; Ultra-compact desktop
Primary UPS Depth (mm)
178
Primary UPS Height (mm)
102
Primary UPS Width (mm)
305
Shipping Dimensions (hwd / in.)
5.50 x 14.50 x 9.75
Shipping Dimensions (hwd / cm)
13.97 x 36.83 x 24.76
Shipping Weight (lbs.)
16.30
Shipping Weight (kg)
7.39
UPS Housing Material
ABS
UPS Power Module Dimensions
(hwd, cm)
10.16 x 30.48 x 17.78
(hwd, in.)
4 x 12 x 7
UPS Power Module Weight (kg)
6.94
UPS Power Module Weight (lbs.)
15.3
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
68
AC Mode Efficiency Rating (100%
Load)
98%
COMMUNICATIONS
PowerAlert Software
Free download from https://tripplite.eaton.com/products/power-alert
Communications Cable
USB interface cable included
3/4
Cleveland, OH 44122
United States
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network UPS Tools (NUT)
Compatibility
NUT compatible. See the full list of Tripp Lite NUT compatible UPS systems at
https://www.networkupstools.org/stable-hcl.html?manufacturer=Tripp Lite
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
4 milliseconds (AC to battery) / 1 millisecond (Battery to AC)
Low Voltage Transfer to Battery
Power (Setpoint)
83
High Voltage Transfer to Battery
Power (Setpoint)
147
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Hot swappable batteries
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
3-year limited warranty
Product Warranty Period (Latin
America)
(International)
2-year limited warranty
Product Warranty Period (Mexico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“AVR900UTAA”相匹配的价格&库存,您可以联系我们找货
