1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208/240V 5kVA 3.5kW DoubleConversion UPS, 5U Rack/Tower, Extended Run,
Network Card Options, DB9 Serial
Highlights
5000VA / 5kVA / 3500 watt online double-conversion 5U
rack/tower UPS
200/208/220/230/240V 50/60Hz
output, high efficiency economy
mode option
Hot-swappable battery modules
RS232 & EPO ports; slot for
network management card
options
Front panel LEDs with detailed
LCD monitoring and control
screen
Expandable runtime with
optional external battery packs
NEMA L6-30P input (3 wire); L630R & L6-20R outputs
MODEL NUMBER: SU5000RT3UHV
Package Includes
SU5000RT3UPM UPS Power
Module
BP240V5RT2U External Battery
Pack
Description
DB9 Cable
Tripp Lite 5kVA Smart Online RM UPS. 5000VA on-line, double-conversion UPS for server, network and
Mounting hardware to support
each module in 4-post
rackmount enclosures
power conditioning. Fault-tolerant auto-bypass prevents unexpected service interruptions during overload
Warranty information
or internal fault conditions. 3U power module and 2U battery pack install in 5 rack spaces. Full-time sine
Instruction manual
telecommunications equipment. Maintains battery derived AC output during blackouts with active, full-time
wave output within 2% of selectable 200/208/220/230/240V AC. Corrects brownouts to 156V and
overvoltages to 276V. Frequency regulation locks output power to 50/60Hz (+/-0.2%)/Expandable runtime
with optional rackmount external battery packs. Double-conversion UPS converts raw input from AC to
DC, then back to perfect sine wave AC output with enhanced protection from harmonic distortion, fast
electrical impulses and other hard-to-solve power problems not addressed by other UPS types. Highly
efficient operation in optional economy mode setting, saving BTU heat output and energy costs. Networkgrade AC surge and noise suppression. Network management interfaces include 2 DB9 ports and slot for
network management card options. Supports simultaneous detailed monitoring of equipment load levels,
self-test data and utility power conditions via all 3 network interfaces. PowerAlert monitoring software is
available via free download. Emergency Power Off (EPO) interface. Front panel LEDs and LCD readout
with scroll controls support visual monitoring of all major UPS functions. Audible alarm. Self test. 4-post
rackmount accessories included; 2-9USTAND and 2POSTRMKITHD accessories available. L6-30P plugin connection; built-in L6-30 & L6-20 outlets. Power Distribution Unit (PDU) options supported. Fieldreplaceable, hot-swappable external battery packs. Attractive all-black color scheme. $250,000 Ultimate
Lifetime Insurance (U.S., Canada, and Puerto Rico only).
Features
True online, double-conversion UPS provides pure, full-time sine wave AC output free of surges,
voltage fluctuations and line noise
5000VA/3500 watt output power capacity compatible with 200-240V applications at 50/60 Hz
1/6
Cleveland, OH 44122
United States
3U power module and 2U battery pack installs in any 19 inch rack enclosure using only 5 rack spaces
Double conversion UPS actively converts raw input from AC to DC, then back to perfect sine wave AC
output with enhanced protection from harmonic distortion, fast electrical impulses and other hard-tosolve power problems not addressed by other UPS types
Provides perfectly regulated, sine wave output power free of line noise, transient surges and frequency
variation for the most efficient operation of critical servers, networking and telecommunications
equipment
Accepts input voltages between 156 and 276, regulating output within 2% of selected
200/208/220/230/240V nominal voltage
Supports connected equipment during blackouts for 20/8 minutes at half/full load levels. Runtime is
further expandable with optional external battery packs
Intelligent battery management system extends battery life
Network interfaces support simultaneous communications via 2 DB9 ports and slot for network
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Built-in Emergency Power Off (EPO) interface with cable
Includes 4 built-in output receptacles (2 L6-30R, 2 L6-20R)
L6-30P input plug-in connection
Front panel LEDs and LCD readout with scroll button enables visual confirmation of all major UPS
functions and current site electrical conditions
Front panel switches enable power on/off control, self-test and alarm cancel functions
Included adjustable mounting rails support installation in 4 post 19 inch rack enclosures. Optional
2POSTRMKITHD supports 2 post rackmount installation
UPS ships fully assembled in full compliance with DOT regulations, no time consuming connection of
internal batteries by user is required
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
$250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332122391
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A (208V), 21A (240V)
Nominal Input Voltage(s) Supported
200V AC; 208V AC; 220V AC; 230V AC; 240V AC
UPS Input Connection Type
L6-30P
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
30A 208/240V
2/6
Cleveland, OH 44122
United States
OUTPUT
Output Capacity (VA)
5000
Output Capacity (kVA)
5
Output Capacity (Watts)
3500
Output Capacity (kW)
3.5
Output Capacity Details
Supports up to 102% load continuously in double conversion mode, 102 to 125% for 1 minute, 126% to 150% for 30
seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power;
Double conversion mode is automatically restored as the overload is cleared
Power Factor
0.7
Crest Factor
3:1
Nominal Voltage Details
Voltage selection via front panel LCD interface
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Output Circuit Breakers
20A double-pole breaker protects L6-20R outlets, L6-30R outlets are unbreakered
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
200V; 208V; 220V; 240V
Output Receptacles
(2) L6-20R; (2) L6-30R
Individually Controllable Load Banks
No
BATTERY
Runtime Full Load (min.)
8 min. (3500w)
Runtime Half Load (min.)
20 min. (1750w)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP240V10RT3U ; BP240V557C-1PH; BP240V787C-1PH ; BP240V1037C-1PH; BP240V1407C-1PH
DC System Voltage (VDC)
240
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Replacement Description
Hot-swappable, user replaceable batteries
3/6
Cleveland, OH 44122
United States
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 276
Undervoltage Correction
2% output voltage regulation during undervoltages to 156
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options;
LED/LCD panel rotates for viewing in rack/tower formats (see manual)
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and
execute scrolling LCD functions
Alarm Cancel Operation
Alarm cancel switch
Audible Alarm
Unique audible alarms for all major UPS, environmental and power conditions (see manual)
LED Indicators
6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD
screen offers additional information and control options
SURGE / NOISE SUPPRESSION
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
5U
Cooling Method
Fan
Included Battery Pack Dimensions
(hwd / in.)
3.5 x 17.5 x 22.5
Included Battery Pack Weight (lbs.)
92
Included Battery Pack Weight (kg)
41.73
Included Mounting Accessory
Description
2 sets of adjustable 4 post rack rails included
Installation Form Factors Supported
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Maximum Device Depth (cm)
66.04
Maximum Device Depth (in.)
26
Maximum Device Depth (mm)
660
Minimum Required Rack Depth (cm)
83.82
(inches)
33
4/6
Cleveland, OH 44122
United States
Optional Mounting Accessory Notes
2 sets of 2POSTRMKITWM required for 2 post rackmount
installation of separate power module and battery pack
Primary UPS Depth (mm)
660
Primary UPS Height (mm)
132
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
22.00 x 27.00 x 33.50
Shipping Dimensions (hwd / cm)
55.88 x 68.58 x 85.09
Shipping Weight (lbs.)
243.00
Shipping Weight (kg)
110.22
Unit Dimension Details
Includes 3U UPS/power module and 2U battery pack
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.21 x 44.45 x 66.04
(hwd, in.)
5.2 x 17.5 x 26
UPS Power Module Weight (kg)
19.05
UPS Power Module Weight (lbs.)
42
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
1327
Battery Mode BTU / Hr. (Full Load)
1327
AC Mode Efficiency Rating (100%
Load)
90%
AC Economy Mode Efficiency Rating
(100% Load)
94%
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
RS232 and contact closure communications are located on two separate DB9 ports
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
DB9 cable included
Communications Interface
DB9 Serial; Contact closure; EPO (emergency power off); Slot for SNMP/Web interface
5/6
Cleveland, OH 44122
United States
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
156
High Voltage Transfer to Battery
Power (Setpoint)
276
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic inverter bypass; Hot swappable batteries
Green Energy-Saving Features
High efficiency economy mode operation; Schedulable daily hours of economy mode operation
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
