1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208 & 120V 5kVA 4.5kW DoubleConversion UPS, 6U Rack/Tower, Extended Run,
Network Card Slot, USB, DB9 Serial
Highlights
5kVA / 5000VA / 4500 watt online double-conversion UPS; 0.9
power factor
208/120V 60Hz output; high
efficiency economy mode option
6U Rack/Tower compatible; Hot
swappable battery modules
USB, RS232 & EPO ports; Slot
for network management card
options
Front panel LEDs with detailed
LCD monitoring and control
screen
Expandable runtime with
optional external battery packs
NEMA L6-30P input (3 wire); L630R, L6-20R & 5-15/20R
outputs
MODEL NUMBER: SU5000RT4UTF
Package Includes
SU5000RT4UHV UPS Power
Module
SU5000XFMRT2U Stepdown
Transformer
4 Post Rackmount Installation
Rails
USB, DB9 and EPO cables
Description
Tripp Lite SU5000RT4UTF 5000VA / 5kVA / 4500 watt on-line, double-conversion UPS system offers
complete power protection for critical server, network and telecommunications equipment in a 6U
rack/tower configuration. Full-time active power conditioning provides clean, continuous dual-conversion
AC output free of voltage fluctuations, power interruptions and line noise. Fault-tolerant auto-bypass
prevents unexpected service interruptions during UPS overload or internal fault conditions. 4U UPS power
module with internal batteries and 2U step-down transformer installs in a total of 6 rack spaces (6U) with a
maximum installed depth of only 20.75 in. / 52.7 cm. Maintains full-time sine wave output within 2% of 208
and 120V nominal at 60Hz during brownouts as low 100V and overvoltages as high as 300V. Expandable
runtime is supported with optional BP192V12-3U external battery packs. Battery independent restart
ensures automatic UPS power-up without user interaction after lengthy power outages, even when
batteries are expired and require replacement. Double-conversion operation converts raw input from AC
to DC, then resynthesizes output power back to perfect sine wave AC with enhanced protection from
harmonic distortion, fast electrical impulses and other hard-to-solve power problems not addressed by
other UPS types. Highly efficient operation in optional economy mode significantly reduces BTU heat
output and operating energy costs. Network-grade AC surge and noise suppression. Supports detailed
monitoring of equipment load levels, self-test data and utility power conditions via built-in RS-232 and
USB interfaces. Optional communications card accessories available. HID-compliant USB interface
enables integration with built-in power management and auto shutdown features of Windows and Mac OS
X. PowerAlert monitoring software, available via free download, offers detailed site power and UPS
updates with support for safe auto-shutdown of connected systems as UPS batteries become depleted.
Supports Emergency Power Off (EPO) via built-in interface. Front panel LEDs and LCD readout with scroll
controls support front-panel visual monitoring of all major UPS functions with support for a variety of
control options to support advanced UPS settings and configurations. LED / LCD display panel rotates for
viewing in rackmount or tower configurations. L6-30P input, plus 2 L6-30R, 2 L6-20R and 12 5-15/20R
outlets. External battery packs are field replaceable and hot swappable. $250,000 connected equipment
insurance;
Features
Tripp Lite SU5000RT4UTF 5000VA / 5kVA / 4500 watt on-line, double-conversion UPS system in a 6U
rack/tower configuration (4U UPS power module with internal batteries + 2U step-down transformer)
Full-time active power conditioning maintains clean, continuous dual-conversion AC output free of
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
1/7
Cleveland, OH 44122
United States
L6-30P input plug, plus 2 L6-30R, 2 L6-20R and 12 5-15/20R outlets
Included rail kits support rackmount installation of both included modules in 4 post racks
Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks (2 required for SU5000RT4UTF)
Optional 2-9USTAND supports upright tower placement (1 required for SU5000RT4UTF)
Maximum installed rack depth of only 20.75 in. / 52.7 cm
Maintains full-time sine wave output within 2% of 208V & 120V at 60Hz nominal in double conversion
mode
Corrects brownouts to 156V at full load (100V at 50% load or less)
Corrects overvoltages to 290V at full load (300V at 90% load or less)
Double-conversion operation offers full-time AC to DC, then DC to AC conversion to maintain perfectly
regulated sine wave AC output with enhanced protection from harmonic distortion, fast electrical
impulses and other hard-to-solve power problems not addressed by other UPS types
High efficiency ECONOMY MODE operation significantly reduces BTU heat output and operating
energy costs
Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via
built-in RS-232, USB and optional SNMP card slot interfaces
UPS card slot supports one card-based network interface options
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Optional RELAYIOMINI interface module offers three configurable hard contact closure outputs for
custom event notification (requires removal of USB interface module)
HID-compliant USB interface enables integration with built-in power management and auto shutdown
features of Windows and Mac OS X
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Front panel LEDs and LCD readout with scroll controls support front-panel visual monitoring of all major
UPS functions with support for a variety of control options to support advanced UPS settings and
configurations
LED/LCD display panel rotates for viewing in rackmount or tower configurations
Battery independent restart ensures automatic UPS power-up without user interaction after lengthy
power outages, even when batteries are expired and require replacement
Intelligent battery management system with temperature-compensated charging extends battery life
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
$250,000 connected equipment insurance
Specifications
OVERVIEW
UPC Code
037332157140
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
2/7
Cleveland, OH 44122
United States
Rated input current (Maximum Load)
24A (208V)
Nominal Input Voltage(s) Supported
208V AC
UPS Input Connection Type
L6-30P
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
30A
OUTPUT
Output Capacity (VA)
5000
Output Capacity (kVA)
5
Output Capacity (Watts)
4500
Output Capacity (kW)
4.5
Output Capacity Details
Supports up to 105% load continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30
seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power;
Double conversion mode is automatically restored as the overload is cleared
Power Factor
0.9
Crest Factor
3:1
Nominal Voltage Details
208V default power module setting; This configuration requires the Power Module be set to 208V output voltage;
Included step-down transformer supports 120V output
Frequency Compatibility
60 Hz
Frequency Compatibility Details
Output frequency regulation +/- 0.05Hz (free running)
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Output Circuit Breakers
High voltage 20A breaker protects L6-20R outlets, L6-30R outlets are unbreakered; Low voltage 20A breakers
protect 3 5-15/20R outlets each
Output AC Waveform (AC Mode)
Pure sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
120V; 208V
Output Receptacles
(12) 5-15/20R; (2) L6-20R; (2) L6-30R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3.5 min. (4500W)
Runtime Half Load (min.)
11 min. (2250W)
3/7
Cleveland, OH 44122
United States
Expandable Runtime
Yes
External Battery Pack Compatibility
BP192V12-3U ; BP192V5RT2U (limit 1); BP192V787C-1PH
DC System Voltage (VDC)
192
Battery Recharge Rate (Included
Batteries)
6 hours from 10% to 90% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC5-192 (qty 1)
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 280V (full load) / 300V (90% load or less)
Undervoltage Correction
2% output voltage regulation during undervoltages to 156V (full load) / 100V (50% load or less)
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options;
LED/LCD panel rotates for viewing in rack/tower formats (see manual)
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and
execute scrolling LCD functions
Alarm Cancel Operation
Alarm cancel switch
Audible Alarm
Unique audible alarms for all major UPS, environmental and power conditions (see manual)
LED Indicators
6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD
screen offers additional information and control options
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
2595
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
6U
Cooling Method
Fan
Included Mounting Accessory
Description
2 sets of adjustable 4 post rack rails included
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
4/7
Cleveland, OH 44122
United States
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Maximum Device Depth (cm)
52.70
Maximum Device Depth (in.)
20.75
Maximum Device Depth (mm)
527
Minimum Required Rack Depth (cm)
60.96
(inches)
24
Minimum Required Rack Depth with
External Battery Pack (cm)
74
External Battery Pack (in.)
29
without External Battery Pack (cm)
65
without External Battery Pack (in.)
25.75
Optional Mounting Accessory Notes
2 sets of 2POSTRMKITHD required for 2 post
rackmount installation of separate 4U power module and 2U transformer
Primary UPS Depth (mm)
525
Primary UPS Height (mm)
174
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
22.20 x 23.60 x 29.10
Shipping Dimensions (hwd / cm)
56.39 x 59.94 x 73.91
Shipping Weight (lbs.)
227.80
Shipping Weight (kg)
103.33
Stepdown Transformer Dimensions
(hwd / cm)
8.89 x 44.45 x 52.70
(hwd / in.)
3.5 x 17.5 x 20.75
Stepdown Transformer Height (mm)
89
Stepdown Transformer Width (mm)
445
Stepdown Transformer Depth (mm)
527
Stepdown Transformer Weight (kg)
34.47
Stepdown Transformer Weight (lbs.)
76
UPS Housing Material
Sheet metal
UPS Power Module Dimensions
(hwd, cm)
17.40 x 44.45 x 52.50
(hwd, in.)
6.85 x 17.5 x 20.67
UPS Power Module Weight (kg)
51.53
5/7
Cleveland, OH 44122
United States
UPS Power Module Weight (lbs.)
113.6
Unit Dimensions (hwd / in.)
10.050 x 17.500 x 20.750
Unit Weight (lbs.)
189.600
Unit Weight (kg)
86.00
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
5% to 90% (non-condensing)
AC Mode BTU / Hr. (Full Load)
1767
AC Economy Mode BTU / Hr. (Full
Load)
640
Battery Mode BTU / Hr. (Full Load)
1708
AC Mode Efficiency Rating (100%
Load)
90%
AC Economy Mode Efficiency Rating
(100% Load)
96%
Operating Elevation (ft.)
0 to 6560 ft. / 0 to 2000 m
Audible Noise
65 dB at 1m front side
Operating Elevation (m)
0-2000 m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
Two contact closure monitoring options available - RELAYIOCARD with six configurable contact closure outputs
(uses UPS card slot) and RELAYIOMINI with 3 configurable contact closure outputs (requires removal of USB port
module)
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB, DB9 serial and EPO cables included
WatchDog Compatibility
Yes
Description
Network management card optional
Communications Interface
DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
156V (full load) / 100V (50% load or less, derates linearly)
6/7
Cleveland, OH 44122
United States
High Voltage Transfer to Battery
Power (Setpoint)
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Hot swappable batteries; Remote
management; Surge/noise protection; Zero transfer time
Green Energy-Saving Features
High efficiency economy mode operation; Support for daily startup and shutoff; Schedulable daily hours of economy
mode operation
STANDARDS & COMPLIANCE
Product Certifications
IEC 61000; CSA (Canada); UL 1778
Product Compliance
RoHS; FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
7/7
