1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline SUTX Series 3-Phase 220/380V,
230/400V, 240/415V 20kVA 20kW On-Line DoubleConversion UPS, Tower, Extended Run, SNMP
Option
Highlights
On-line double-conversion
topology, VFI operation
Automatic and Manual Bypass
for enhanced reliability
Add optional WEBCARDLX with
latest version of PADM20 for
enhanced remote management
Internal batteries and
expandable runtime options
Paralleling capability of up to 4
units
MODEL NUMBER: SUTX20K
Package Includes
3-phase UPS system protects connected mission-critical equipment against damage, downtime and data
loss due to blackouts, brownouts, power surges and line noise.
Description
The SUTX20K SmartOnline® SUTX Series 3-Phase 220/380V, 230/400V or 240/415V 20kVA 20kW OnLine Double-Conversion UPS provides battery backup and AC power protection against power
disturbances that can damage electronics or destroy data. It’s recommended for critical data center,
LAN/WAN and distributed server room applications.
The SUTX20K’s Voltage and Frequency Independent (VFI) design allows continuous operation at any
supported voltage at either 50 or 60 Hz. Zero transfer time to battery mode ensures no disruption to the
attached loads. Automatic and Manual Bypass keeps connected equipment powered, even during
overloads and UPS maintenance.
IGBT inverter technology produces output power with 1% total harmonic distortion (THD) to keep
connected equipment functioning at its peak. A 3:1 crest factor safely supports a variety of loads, even
those with wildly fluctuating power demands.
Managing the SUTX20K is simplified through the multi-language LCD interface, which displays critical
operating conditions and diagnostic data, such as battery and load status. Four LEDs indicate bypass,
line, battery and fault modes. A serial port allows connection to Tripp Lite’s free local shutdown agent. A
built-in card slot supports the optional WEBCARDLX network management card for network interface and
remote monitoring and control.
Features
VFI True On-Line Double-Conversion 3-Phase UPS System
● Provides fully regulated sine wave AC output for critical data center, LAN/WAN and distributed server
room applications
+/-1% output voltage regulation in online and battery modes
1.0 unit power factor offers 20kVA/20kW output capacity, allowing for more connected devices
Supports 380/220V, 400/230V or 415/240V at 50/60 Hz in continued operation
Wide input voltage window (228–477V) minimizes battery use and prolongs battery life
Reliable Battery Backup with Expandable Runtime
● Supports half load for 33.4 min. and full load for 14.3 min. with standard internal battery
1/6
SUTX20K SmartOnline SUTX
RS-232 (DB9) cable
Owner’s manual
Cleveland, OH 44122
United States
Zero transfer time suitable for advanced network applications
Expandable runtime with optional external battery packs, such as Tripp Lite’s BP480V09
Restarts automatically after lengthy power outages
IGBT Inverter Technology
● Produces output power with 1% THD to keep connected equipment functioning at its peak
Low
很抱歉,暂时无法提供与“SUTX20K”相匹配的价格&库存,您可以联系我们找货
