SUTX40K
SUTX40K
    TRIPPLITE
    SMARTONLINESUTXSERIES3-PHASE
SUTX40K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline SUTX Series 3-Phase 220/380V, 230/400V, 240/415V 40kVA 40kW On-Line DoubleConversion UPS, Tower, Extended Run, SNMP Option Highlights ● On-line double-conversion topology, VFI operation ● Automatic and Manual Bypass for enhanced reliability ● Add optional WEBCARDLX with latest version of PADM20 for enhanced remote management ● Internal batteries and expandable runtime options ● Paralleling capability of up to 4 units MODEL NUMBER: SUTX40K Package Includes 3-phase UPS system protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Description The SUTX40K SmartOnline® SUTX Series 3-Phase 220/380V, 230/400V or 240/415V 40kVA 40kW OnLine Double-Conversion UPS provides battery backup and AC power protection against power disturbances that can damage electronics or destroy data. It’s recommended for critical data center, LAN/WAN and distributed server room applications. The SUTX40K’s Voltage and Frequency Independent (VFI) design allows continuous operation at any supported voltage at either 50 or 60 Hz. Zero transfer time to battery mode ensures no disruption to the attached loads. Automatic and Manual Bypass keeps connected equipment powered, even during overloads and UPS maintenance. IGBT inverter technology produces output power with 1% total harmonic distortion (THD) to keep connected equipment functioning at its peak. A 3:1 crest factor safely supports a variety of loads, even those with wildly fluctuating power demands. Managing the SUTX40K is simplified through the multi-language LCD interface, which displays critical operating conditions and diagnostic data, such as battery and load status. Four LEDs indicate bypass, line, battery and fault modes. A serial port allows connection to Tripp Lite’s free local shutdown agent. A built-in card slot supports the optional WEBCARDLX network management card for network interface and remote monitoring and control. Features VFI True On-Line Double-Conversion 3-Phase UPS System ● Provides fully regulated sine wave AC output for critical data center, LAN/WAN and distributed server room applications ● +/-1% output voltage regulation in online and battery modes ● 1.0 unit power factor offers 40kVA/40kW output capacity, allowing for more connected devices ● Supports 380/220V, 400/230V or 415/240V at 50/60 Hz in continued operation ● Wide input voltage window (228–477V) minimizes battery use and prolongs battery life Reliable Battery Backup with Expandable Runtime ● Supports half load for 15.5 min. and full load for 5.9 min. with standard internal battery 1/6 ● SUTX40K SmartOnline SUTX Series 3-Phase 220/380V, 230/400V, 240/415V 40kVA 40kW On-Line DoubleConversion UPS ● RS-232 (DB9) cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Zero transfer time suitable for advanced network applications ● Expandable runtime with optional external battery packs, such as Tripp Lite’s BP480V09 ● Restarts automatically after lengthy power outages IGBT Inverter Technology ● Produces output power with 1% THD to keep connected equipment functioning at its peak ● Low
SUTX40K 价格&库存
很抱歉,暂时无法提供与“SUTX40K”相匹配的价格&库存,您可以联系我们找货
