1000 Eaton Boulevard
Cleveland, OH 44122
United States
1.9kW Single-Phase 120V Basic PDU, 14 NEMA 515/20R Outlets, NEMA L5-20P Input with 5-20P
Adapter, 15 ft. (4.57 m) Cord, 0U Vertical
MODEL NUMBER: PDUV20
Highlights
NEMA L5-20P input with 15-ft.
(4.57 m) cord and 5-20P
adapter
14 NEMA 5-15/20R outlets
Switchless design prevents
accidental shutdown
36 in. all-metal housing
Supports toolless 0U vertical
mounting
Package Includes
Delivers 120V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a
high-density IT environment. Recommended for data centers, server rooms and network wiring closets.
Description
The PDUV20 1.9kW Single-Phase 120V Basic PDU is an excellent no-frills unit for data centers, server
rooms and network wiring closets. Perfectly suited for high-density IT environments, the PDUV20 features
14 NEMA 5-15/20R outlets. The NEMA L5-20P input plug with long 15-ft. (4.57 m) cord connects to your
facility's compatible AC power source, generator or protected UPS to distribute power to connected
equipment. An included adapter converts the input plug to NEMA 5-20P.
The switchless design prevents an accidental shutdown, which could lead to costly downtime. A 20A
circuit breaker protects connected equipment from dangerous overloads. The 36-inch all-metal housing
supports 0U vertical mounting in EIA-standard 19-inch racks using the included hardware and mounting
clips or toolless mounting using the included buttons. You can also mount the PDUV20 on a wall or
workbench or under a counter with user-supplied hardware.
Features
Reliable Single-Phase Power Distribution
● Versatile no-frills PDU for data centers, server rooms and network wiring closets
NEMA L5-20P input with 15-ft. (4.57 m) cord and 5-20P adapter
20A circuit breaker protects outlets against overloads
Switchless Design
● Prevents accidental shutdowns and costly downtime
Versatile Installation Options
● 36 in. all-metal housing
Supports toolless 0U vertical mounting in EIA-standard 19 in. racks
Also supports 0U mounting using included hardware
Rear installation buttons can be relocated to the left or right surface for rear, center or forward-facing
1/3
120V Basic PDU
NEMA 5-20P plug adapter
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
outlet orientation
Also mounts on wall, workbench or under a counter with user-supplied hardware
Specifications
OVERVIEW
UPC Code
037332143402
PDU Type
Basic
INPUT
PDU Input Voltage
120
Recommended Electrical Service
Single-phase 20A 120V service
Maximum Input Amps
16
Maximum Input Amps Details
Agency de-rated to 16A continuous
PDU Plug Type
NEMA 5-20P; NEMA L5-20P
Input Phase
Single-Phase
Input Cord Length (ft.)
15
Input Cord Length (m)
4.57
OUTPUT
Output Capacity Details
1.92kW (120V) / 16A total capacity; 16A max per 5-15/20R outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(14) 5-15/20R
Output Nominal Voltage
120V
Overload Protection
20A circuit breaker
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
Form Factors Supported
Vertical (0U) mounting in rack enclosures, horizontal mount in raceways and a variety of other applications
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
39.76 x 4.61 x 2.40
Shipping Dimensions (hwd / cm)
100.99 x 11.71 x 6.10
Shipping Weight (lbs.)
5.48
Shipping Weight (kg)
2.49
2/3
Cleveland, OH 44122
United States
Unit Dimensions (hwd / in.)
36.470 x 1.500 x 1.640
Unit Dimensions (hwd / cm)
92.6 x 3.81 x 4.17
Unit Weight (lbs.)
4.01
Unit Weight (kg)
1.82
ENVIRONMENTAL
Operating Temperature Range
0C ~ 40C (32F ~ 104F)
Storage Temperature Range
-30°C to +50°C (-22°F to +122°F)
Relative Humidity
5-95% non-condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDUV20”相匹配的价格&库存,您可以联系我们找货
