1000 Eaton Boulevard
Cleveland, OH 44122
United States
1.9kW 120V Single-Phase Basic PDU - 28 NEMA
5-15/20R Outlets, L5-20P Input (5-20P Adapter),
15 ft. Cord, 60 in. 0U Rack
Highlights
Ideal no-frills PDU for telecom,
security, audio/video and other
network applications
28 NEMA 5-15/20R outlets
distribute AC power to
connected equipment
Lighted power switch with
protective cover helps prevent
accidental shutdowns
15 ft. cord with L5-20P input
(and 5-20P adapter) connects to
AC power source
60 in. 0U PDU with included
mounting brackets installs in
rack or under counter
MODEL NUMBER: PDUV20-60
Applications
Deliver network-grade power to
high-density equipment in
networking, telecom, security,
audio/video and sound
reinforcement applications
Delivers 120V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a
data center or network closet.
Features
Single-Phase 120V PDU Distributes Network-Grade Power to Multiple Loads
This basic PDU is an ideal no-frills unit for networking, telecom, security, audio/video and sound
reinforcement applications. Recommended for small to mid-sized data centers, computer rooms and
network closets, the PDUV20-60 features 28 NEMA 5-15/20R outlets for connecting equipment. A 15-foot
cord with L5-20P input plug (and included 5-20P adapter) connects to your facility’s AC power source,
generator or protected UPS system to distribute power to connected loads.
Up-to-Date Safety Features Protect Your Vital Equipment
A lighted on/off switch is protected by a transparent plastic cover to help prevent an accidental shutdown
that could lead to costly downtime. A 20A circuit breaker protects connected components from dangerous
overloads.
Versatile Installation Options Give You Plenty of Choices
The 60-inch 0U PDU mounts vertically in an EIA-standard 19-inch rack using the included toolless
mounting buttons or the included mounting clips and hardware. You may also use the clips to secure the
PDU to a wall, counter or other flat, secure surface. Bolt-down retention brackets keep power cords
organized and your rack free of clutter.
Specifications
OVERVIEW
UPC Code
037332256003
PDU Type
Basic
INPUT
1/3
Package Includes
PDUV20-60 1.9kW 120V SinglePhase Basic PDU
L5-20P to 5-20P input plug
adapter
Plug retention brackets with
installation hardware
Rack-mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Input Phase
Single-Phase
PDU Input Voltage
120
Recommended Electrical Service
Single-phase 20A 120V service
Maximum Input Amps
16
Maximum Input Amps Details
Agency de-rated to 16A continuous
PDU Plug Type
NEMA 5-20P; NEMA L5-20P
Input Cord Length (ft.)
15
Input Cord Length (m)
4.57
OUTPUT
Output Capacity Details
1.92kW (120V) / 16A total capacity; 16A max per outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(28) 5-15/20R
Output Nominal Voltage
120V
Overload Protection
20A circuit breaker
USER INTERFACE, ALERTS & CONTROLS
Switches
Lighted on/off switch with integrated transparent saftey cover
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Aluminum
Form Factors Supported
Vertical
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
2.40 x 3.50 x 63.20
Shipping Weight (kg)
3.18
Unit Dimensions (hwd / in.)
60.470 x 1.500 x 1.640
Unit Dimensions (hwd / cm)
153.59 x 3.81 x 4.17
Unit Weight (lbs.)
5.39
Unit Weight (kg)
2.44
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
-22° to 122°F (-30° to 50°C)
Relative Humidity
5% to 95% non-condensing
2/3
Cleveland, OH 44122
United States
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 60950-1
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDUV20-60”相匹配的价格&库存,您可以联系我们找货
