1000 Eaton Boulevard
Cleveland, OH 44122
United States
3.8kW Single-Phase 208/240V Basic PDU, 14
Outlets (12 C13 & 2 C19), NEMA L6-20P Input, 15
ft. (4.57 m) Cord, 1U Rack-Mount
MODEL NUMBER: PDUH20HVL6
Highlights
NEMA L6-20P input with 15-ft.
(4.57 m) power cord
14 total outlets—12 C13 and 2
C19
Switchless design prevents
accidental shutdown
Reversible all-metal housing
Installs in rack, on wall or under
counter
Package Includes
Delivers 208/240V single-phase AC power to multiple loads from a utility outlet, generator or UPS system
in a high-density IT environment. Ideal for data centers, server rooms and network wiring closets.
Description
The PDUH20HVL6 3.3/3.8kW Single-Phase 208/240V Basic PDU is a versatile no-frills unit for data
centers, server rooms and network wiring closets. Perfectly suited for high-density IT environments, the
PDUH20HVL6 features 14 total outlets— four C13 in front and eight C13 and two C19 in the rear. The
NEMA L6-20P input plug with long 15-ft. (4.57 m) cord connects to your facility's compatible AC power
source, generator or protected UPS to distribute power to connected equipment.
The switchless design prevents an accidental shutdown, which could lead to costly downtime. The
reversible all-metal housing supports a variety of mounting options, including 1U horizontal or 0U vertical
mounting in EIA-standard 19-inch racks, under a counter or on a wall or workbench.
Features
Reliable Single-Phase 20A 208/240V Power Distribution
● Ideal no-frills PDU for data centers, server rooms and network wiring closets
14 total outlets—4 C13 in front, 8 C13 and 2 C19 in rear
NEMA L6-20P input plug with 15-ft. (4.57 m) power cord
Rear-panel grounding lug
Switchless Design
● Prevents accidental shutdowns and costly downtime
Versatile Installation Options
● Reversible all-metal housing faces front or rear in rack
Supports 1U horizontal or 0U vertical mounting in EIA-standard 19 in. racks
Also mounts on wall, workbench or under a counter
1/3
PDU
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332158970
PDU Type
Basic
INPUT
PDU Input Voltage
208; 240
Recommended Electrical Service
Single-phase 20A 208/230V service
Maximum Input Amps
16
Maximum Input Amps Details
Agency de-rated to 16A continuous
PDU Plug Type
NEMA L6-20P
Input Phase
Single-Phase
Input Cord Details
Input cable is attached
Input Cord Length (ft.)
15
Input Cord Length (m)
4.57
OUTPUT
Output Capacity (kW)
3840
Output Capacity Details
3.84kW (240V), 3.33kW (208V) / 20A total capacity (Agency de-rated 16A); 16A max per C19 outlet; 12A max per
C13 outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(12) C13; (2) C19
Output Nominal Voltage
208/240V
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
Form Factors Supported
1U rackmount, 0U vertical rackmount, wall-mount, and under-counter installation
Minimum Required Rack Depth (cm)
17.27
(inches)
6.8
Outlets Measurement (Center to
Center)
Distance between front (C13) outlets = 28.75mm; Distance between rear (C19) outlets = 55mm; Distance between
rear (C13) outlets = 28.75mm
PDU Form Factor
Horizontal (1U)
2/3
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / in.)
11.00 x 2.25 x 20.25
Shipping Dimensions (hwd / cm)
27.94 x 5.72 x 51.44
Shipping Weight (lbs.)
5.90
Shipping Weight (kg)
2.68
Unit Dimensions (hwd / in.)
1.750 x 17.250 x 3.750
Unit Dimensions (hwd / cm)
4.45 x 43.8 x 9.5
Unit Weight (lbs.)
3.75
Unit Weight (kg)
1.70
ENVIRONMENTAL
Operating Temperature Range
0C ~ 40C (32F ~ 104F)
Storage Temperature Range
-30°C to +50°C (-22°F to +122°F)
Relative Humidity
5-95% non-condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
FEATURES & SPECIFICATIONS
TVSS Grounding
Grounding lug
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA-C22.2 No. 62368-1 (Canada); NOM (Mexico); UL 62368-1
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDUH20HVL6”相匹配的价格&库存,您可以联系我们找货
