PDUH30HV19
PDUH30HV19
    TRIPPLITE
    POWER OUTLET STRIPS
PDUH30HV19 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5.8kW Single-Phase 200-240V Basic PDU, 4 C19 Outlets, NEMA L6-30P Input, 12 ft. (3.66 m) Cord, 1U Rack-Mount MODEL NUMBER: PDUH30HV19 Highlights ● NEMA L6-30P input with 12-ft. (3.66 m) power cord ● 4 rear C19 outlets ● Switchless design prevents accidental shutdown ● Reversible all-metal housing ● Dual 20A circuit breakers protect against overloads Package Includes Delivers 200-240V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a high-density IT environment. Ideal for data centers, server rooms and network wiring closets. Description The PDUH30HV19 5/5.8kW Single-Phase 200-240V Basic PDU is a versatile no-frills unit for data centers, server rooms and network wiring closets. Perfectly suited for high-density IT environments, the PDUH30HV19 features four rear outlets. The NEMA L6-30P input plug with 12-ft. (3.66 m) cord connects to your facility's compatible AC power source, generator or protected UPS to distribute power to connected equipment. The switchless design prevents an accidental shutdown, which could lead to costly downtime. Dual 20A circuit breakers protect connected equipment from dangerous overloads. The reversible all-metal housing supports a variety of mounting options, including 1U horizontal or 0U vertical mounting in EIA-standard 19-inch racks, under a counter or on a wall or workbench. Features Reliable Single-Phase 24A 200-240V Power Distribution ● Ideal no-frills PDU for data centers, server rooms and network wiring closets ● 4 rear C19 outlets ● NEMA L6-30P input plug with 12-ft. (3.66 m) power cord ● Rear-panel grounding lug ● Dual 20A circuit breakers protect against overloads Switchless Design ● Prevents accidental shutdowns and costly downtime Versatile Installation Options ● Reversible all-metal housing faces front or rear in rack ● Supports 1U horizontal or 0U vertical mounting in EIA-standard 19 in. racks ● Also mounts on wall, workbench or under a counter 1/3 ● PDUH30HV19 5.8kW SinglePhase 200-240V Basic PDU ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332183194 PDU Type Basic INPUT Input Phase Single-Phase PDU Input Voltage 200; 208; 220; 230; 240 Recommended Electrical Service Single-phase 30A 200-240V service Maximum Input Amps 24 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type NEMA L6-30P Input Cord Length (ft.) 12 Input Cord Length (m) 3.66 OUTPUT Output Capacity (kW) 5800 Output Capacity Details 5.8kW (240V), 5.5kW (230V), 5.3kW (220V), 5kW (208V), 4.8kW (200V) total capacity / 30A max (Agency de-rated to 24A), 20A max per breakered outlet bank; 16A max per C19 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (4) C19 Output Nominal Voltage 200-240V Overload Protection Two 20A breakers protect 2 C19 outlets each SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount, 0U vertical mount, wallmount and under-counter Minimum Required Rack Depth (cm) 17.27 Minimum Required Rack Depth (inches) 6.8 PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 3.00 x 20.25 x 11.25 Shipping Dimensions (hwd / cm) 7.62 x 51.44 x 28.58 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 8.49 Shipping Weight (kg) 3.85 Unit Dimensions (hwd / in.) 1.700 x 17.300 x 3.750 Unit Dimensions (hwd / cm) 4.5 x 44.5 x 9.53 Unit Weight (lbs.) 7.74 Unit Weight (kg) 3.51 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -22° to 122°F (-30° to 50°C) Relative Humidity 5% to 95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS Grounding Grounding lug STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 62368-1 (Canada); NOM (Mexico); UL 62368-1 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUH30HV19 价格&库存
很抱歉,暂时无法提供与“PDUH30HV19”相匹配的价格&库存,您可以联系我们找货
