PDU3MV6L2120
PDU3MV6L2120
    TRIPPLITE
    PDU 3-PHASE METERED 208/120V
PDU3MV6L2120 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5.7kW 3-Phase Local Metered PDU, 208/120V Outlets (36 C13, 6 C19, 6 5-15/20R), L21-20P, 6 ft. (1.83 m) Cord, 0U Vertical, TAA Highlights ● Local Metered 5.7kW 3 Phase 208/120V PDU; 70 in. / 178cm 0U vertical rackmount ● Reports input current per-phase via built in current meters ● NEMA L21-20P (3P+N+E) 208V 3 phase input; 6-ft. (1.83 m) line cord ● 48 outlets total; 36 C13 (208V), 6 C19 (208V) & 6 NEMA 515/20R (120V) ● Toolless button-mount installation; cord retention brackets included ● TAA Compliant MODEL NUMBER: PDU3MV6L2120 Package Includes Features ● 5.7kW 3 phase 208/120V Local Metered Power Distribution Unit / PDU ● Set of 3 built-in current meters continuously report input current per phase ● Attached NEMA L21-20P 20A (3P+N+E) 208V 3 phase input plug with 6 ft. / 1.8m cord ● 0U, 70 in. / 178cm vertical form factor supports installation in 2 or 4 post equipment racks ● 48 total outlets arranged in three single phase output load banks ● 36 C13 and 6 C19 outlets output 208V ● 6 NEMA 5-20R outlets output 120V ● Included cord retention brackets keep vital network equipment plugged in and continuously powered ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332163929 PDU Type Local Metered INPUT PDU Input Voltage 208 Recommended Electrical Service Three-phase 20A 208V service 1/3 ● Local Metered Rackmount PDU with pre-installed mounting buttons ● Cord retention brackets ● Spare installation buttons (2 9mm / 4 6mm) ● Rack mounting brackets ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous PDU Plug Type NEMA L21-20P Input Phase 3-Phase Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 5.7kW (208/120V) total capacity; 9.2A (208V) max per output phase (L1-L2, L2-L3, L3-L1) / 16A (120V) max per output phase (L1, L2, L3) Frequency Compatibility 50 / 60 Hz Output Receptacle Details 5-15/20R outlets provide 120V output; C13 and C19 outlets provide 208V output Output Receptacles (6) 5-15/20R; (36) C13; (6) C19 Output Nominal Voltage 208/120V USER INTERFACE, ALERTS & CONTROLS Reported Load Segments Supports monitoring of input current per phase (9.2A balanced max. per L1, L2 and L3); Outlets are color-coded and labeled for phase and load bank identification; L1-L2 feeds black C13/C19 outlets; L2-L3 feeds dark-gray C13/C19 outlets; L3-L1 feeds light-gray C13/C19 outlets; L1-N feeds black 5-20R outlets; L2-N feeds dark-gray 5-20R outlets; L3-N feeds light-gray 5-20R outlets Front Panel LCD Display Set of 3 digital current meters report input current per phase SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 5.40 x 6.80 x 76.20 Shipping Dimensions (hwd / cm) 13.72 x 17.27 x 193.55 Shipping Weight (lbs.) 15.40 Shipping Weight (kg) 6.99 Unit Dimensions (hwd / in.) 70.000 x 2.200 x 1.930 Unit Dimensions (hwd / cm) 177.8 x 6.73 x 4.34 Unit Weight (lbs.) 12.6 Unit Weight (kg) 5.72 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +60°C (-22°F to +140°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); NOM (Mexico); UL 62368-1 Product Compliance RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU3MV6L2120 价格&库存
很抱歉,暂时无法提供与“PDU3MV6L2120”相匹配的价格&库存,您可以联系我们找货
