PDU3V6L2120LV
PDU3V6L2120LV
    TRIPPLITE
    5.7KW 3-PHASE BASIC PDU - 42 NEM
PDU3V6L2120LV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5.7kW 3-Phase Basic PDU - 42 NEMA 5-15/20R 120V Outlets, 208V L21-20P Input, 6 ft. Cord, 70 in. 0U Rack, TAA Highlights ● Ideal no-frills PDU for telecom, security, audio/video and other network applications ● 42 NEMA 5-15/20R 120V outlets distribute AC power to connected equipment ● Switchless design helps prevent accidental shutdowns that can lead to costly downtime ● 6 ft. power cord with NEMA L2120P 3-phase input connects to AC source ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: PDU3V6L2120LV Applications Deliver network-grade power to high-density equipment in networking, telecom, security, audio/video and sound reinforcement applications Delivers 120V AC power to multiple loads from a utility outlet, generator or UPS system in a data center or network closet. Package Includes ● PDU3V6L2120LV 5.7kW 208V 3-Phase Basic PDU with 120V Output ● Cable retention brackets with installation hardware ● Rack-mounting hardware ● Owner’s manual Features 3-Phase 120V PDU Distributes Network-Grade Power to Multiple Loads This basic PDU is an ideal no-frills unit for networking, telecom, security, audio/video and sound reinforcement applications. Recommended for small to mid-sized data centers, computer rooms and network closets, the PDU3V6L2120LV features 42 NEMA 5-15/20R outlets in three single-phase output load banks for connecting equipment. A six-foot (1.8-meter) cord with NEMA L21-20P 3-phase input plug connects to your facility’s AC power source, generator or protected UPS system to distribute power to connected loads. Easy to Install Vertically in an EIA-Standard 19 in. Rack The 70-inch 0U PDU’s all-metal housing mounts vertically using the pre-installed toolless mounting buttons or the included brackets. Spare buttons are also included. Use the included PDUMVROTATEBRKT kit to install the PDU with outlets facing the rear for better airflow or equipment access. Cable retention brackets keep power cords organized and your rack free of clutter. The PDU’s switchless design helps prevent an accidental shutdown, which could lead to costly downtime. TAA-Compliant for GSA Schedule Purchases The PDU3V6L2120LV is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332255709 PDU Type Basic 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Input Phase 3-Phase PDU Input Voltage 208 Recommended Electrical Service Three-phase 20A 208V service Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 12A continuous PDU Plug Type NEMA L21-20P Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 5.7kW (120V) total capacity / 16A max per output phase (L1, L2, L3); 16A max per 5-15/20R outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (42) 5-15/20R Output Nominal Voltage 120V SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 5.40 x 6.80 x 76.00 Shipping Weight (kg) 6.62 Unit Dimensions (hwd / in.) 70.000 x 2.200 x 1.930 Unit Dimensions (hwd / cm) 177.8 x 5.6 x 4.34 Unit Weight (lbs.) 12.7 Unit Weight (kg) 5.76 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -22° to 140°F (-30° to 60°C) Relative Humidity 5% to 95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 62368-1 (Canada); NOM (Mexico); UL 62368-1 Product Compliance RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU3V6L2120LV 价格&库存
很抱歉,暂时无法提供与“PDU3V6L2120LV”相匹配的价格&库存,您可以联系我们找货
