1000 Eaton Boulevard
Cleveland, OH 44122
United States
Highlights
PowerAlert Console LauncherSNMPWEBCARDPowerAlert Console
LauncherSNMPWEBCARDSNMPWEBCARD Support
5.7kW 3-Phase Monitored PDU, 120V Outlets (36
5-15/20R), 208V L21-20P, 10 ft. (3.05 m) Cord, 0U
Vertical, TAA
Monitored 5.7kW 3 Phase 208V
input PDU; 70 in. / 178cm 0U
vertical rackmount
Reports voltage, frequency and
load per-phase via built in
ethernet interface
Visual current meter; Toolless
button-mount installation
NEMA L21-20P 20A (3P+N+E)
208V 3 phase input; 10-ft. (3.05
m) line cord
36 5-15/20R single phase 120V
outlets; Included cord retention
brackets
Temperature, humidity and
contact closure monitoring
options
Federal Trade Agreements Act /
TAA Compliant for GSA
Schedule purchases
MODEL NUMBER: PDU3VN10L2120LV
Package Includes
Monitored rackmount PDU with
pre-installed mounting buttons
Cord retention brackets
Spare installation buttons (2
9mm / 4 6mm)
5.7kW 3 phase 208V Monitored Power Distribution Unit / PDU with built-in web/network interface
Rack mounting brackets
Attached NEMA L21-20P 20A (3P+N+E) 208V 3 phase input plug with 10-ft. / 3.05 m cord
Owner's manual
0U, 70 in. / 178cm vertical form factor supports installation in 2 or 4 post equipment racks
36 total 120V NEMA 5-15/20R outlets arranged in three single phase output load banks
Lighted display with scroll-button reports power consumption in amps for all 3 loading banks, IP-address
self-identification and 180 degree display rotation for overhead or raised floor power feeds
Built-in SNMP/ethernet interface reports voltage, frequency and PDU loading per-phase via network or
secure web browser interface with options for user specified alarm and notification thresholds
Supports in-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor
and rack access notification with up to 4 optional SRSWITCH door sensors
DHCP/Manual configuration support
10/100 Mbps auto-sensing allows optimal communication with 10/100 Base-T networks
Real-time clock backup maintains the time of day and date even if the PDU is unpowered
Tiered access privileges allow an administrator and a guest to login via web browser for monitoring
Alert notifications via email or SNMP traps offer immediate event notification
Firmware upgrade ability supports future product enhancements
Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2,
SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols
Fully compatible with FREE PowerAlert Network Management System / NMS Software
Included cord retention brackets keep vital network equipment plugged in and continuously powered
Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for
other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons
included)
Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases
Features
1/4
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332157928
PDU Type
Monitored
INPUT
PDU Input Voltage
208
Recommended Electrical Service
Three-phase 20A 208V service
Maximum Input Amps
16
Maximum Input Amps Details
Agency de-rated to 16A continuous
PDU Plug Type
NEMA L21-20P
Input Phase
3-Phase
Input Cord Length (ft.)
10
Input Cord Length (m)
3.05
OUTPUT
Output Capacity Details
5.7kW (120V) total capacity / 16A max per output phase (L1, L2, L3); 16A max per outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(36) 5-15/20R
Output Nominal Voltage
120V
USER INTERFACE, ALERTS & CONTROLS
Reported Load Segments
Supports local monitoring of current for each output phase (16A max per L1, L2, L3); BANK "L1" is powered by L1-N;
BANK "L2" is powered by L2-N; BANK "L3" is powered by L3-N
Front Panel LCD Display
Digital display reports output load level in amps separately for each output phase; Can also be used to scroll the
configured IP address
Front Panel LEDs
Set of 3 LEDs (L1, L2, L3) indicate the output load segment the digital current display is reporting
Switches
SELECT switch advances the digital display and LED to report power consumption for load segments L1, L2 and L3;
Press and hold the SELECT switch to rotate the digital display 90 degrees for overhead power input; Press and hold
the SCROLL IP button to scroll the configured IP address
Current Measurement Accuracy
(Amps)
+/-1%
Voltage Measurement Accuracy
(Volts)
+/-1%
Power Measurement Accuracy
(Watts)
+/-1%
SURGE / NOISE SUPPRESSION
2/4
Cleveland, OH 44122
United States
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
Form Factors Supported
Vertical rackmount installation supported with included mounting brackets; supports tooless mounting in buttonmount compatible racks
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
6.50 x 9.60 x 75.40
Shipping Dimensions (hwd / cm)
16.51 x 24.38 x 191.52
Shipping Weight (lbs.)
18.10
Shipping Weight (kg)
8.21
Unit Dimensions (hwd / in.)
70.000 x 1.750 x 2.200
Unit Dimensions (hwd / cm)
177.8 x 5.6 x 4.24
Unit Weight (lbs.)
10.1
Unit Weight (kg)
4.58
ENVIRONMENTAL
Operating Temperature Range
0C ~ 40C (32F ~ 104F)
Storage Temperature Range
-30°C to +50°C (-22°F to +122°F)
Relative Humidity
5-95% non-condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
COMMUNICATIONS
PowerAlert Software
SNMPWEBCARD Interface: PowerAlert 12
Communications Cable
RJ45-to-DB9 configuration/console Access cable
Network Compatibility
10 Mbps; 100 Mbps (Fast Ethernet)
FEATURES & SPECIFICATIONS
High Availability PDU Features
Remote Network Notifications
STANDARDS & COMPLIANCE
Product Certifications
NOM (Mexico); UL 60950-1
Product Compliance
RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“PDU3VN10L2120LV”相匹配的价格&库存,您可以联系我们找货
