1000 Eaton Boulevard
Cleveland, OH 44122
United States
11.5kW 3-Phase Monitored PDU, 208-240V
Outlets (42 C13, 6 C19), IEC309 16/20A Red, 360415V Input, 0U, TAA
Highlights
Monitored 11.5kW 3-Phase 360415V input 208-240V output
PDU
Reports voltage & load perphase via ethernet interface
1% billing-grade accuracy;
Digital display reports detailed
status and loading information
70in / 1778mm 0U vertical
format; Toolless button-mount
installation
42 C13 & 6 C19 single phase
outlets; Plug-lock cable retention
inserts keep power cables
secure
IEC309 16A Red (3P+N+E) 3
phase input; 6-ft. (1.83 m) line
cord
TAA Compliant
MODEL NUMBER: PDU3XVN6G20
Package Includes
Features
11.5kW Monitored 360-415V input 208-240V output PDU with built-in web/network interface
IEC309 16/20A Red (3P+N+E) 360-415V 3 phase input with 6 ft. / 1.8m line cord
0U, 70 inch / 178cm vertical form factor
48 208-240V outlets (42 C13, 6 C19) in 3 single phase load banks
Lighted display with scroll-button reports power consumption in amps for all 3 loading banks, IP-address
self-identification and 180 degree display rotation for overhead or raised floor power feeds
Built-in SNMP/ethernet interface reports voltage and PDU loading per-phase via network or secure web
browser interface with options for user specified alarm and notification thresholds
Supports in-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor
and rack access notification with up to 4 optional SRSWITCH door sensors
DHCP/Manual configuration support
10/100 Mbps auto-sensing allows optimal communication with 10/100 Base-T networks
Real-time clock backup maintains the time of day and date even if the PDU is unpowered
Tiered access privileges allow an administrator and a guest to login via web browser for monitoring
Alert notifications via email or SNMP traps offer immediate event notification
Firmware upgrade ability supports future product enhancements
Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2,
SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols
Fully compatible with FREE PowerAlert Network Management System / NMS Software
Included set of plug-lock inserts keep C14 & C20 power cords solidly connected to PDU outlets
Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for
other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons
included)
Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases
1/4
Monitored PDU with preinstalled mounting buttons
Plug-lock C14 and C20 cable
retention inserts
Spare installation buttons (2
9mm / 4 6mm), Mounting
brackets
Configuration cable
Owner's manual
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332182975
PDU Type
Monitored
INPUT
PDU Input Voltage
360; 380; 400; 415
Recommended Electrical Service
Three-phase 16A 360-415V service
Maximum Input Amps
16
Maximum Input Amps Details
Agency de-rated to 16A continuous (North America)
PDU Plug Type
IEC-309 16/20A RED (3P+N+E)
Input Phase
3-Phase
Input Cord Length (ft.)
6
Input Cord Length (m)
1.83
OUTPUT
Output Capacity Details
11.5kW (415/240V), 11.1kW (400/230V), 10.5kW (380/220V), 10kW (360/208V) total capacity; 16A max per output
phase (L1-L2, L2-L3, L3-L1); 16A max per C19 outlet; 12A max (10A CE) max per C13 outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(42) C13; (6) C19
Output Nominal Voltage
208-240V
USER INTERFACE, ALERTS & CONTROLS
Reported Load Segments
Supports local monitoring of current for each input phase (L1, L2 and L3) and output current for each output load
bank (16A balanced max per B1, B2 and B3); Outlets are color-coded and labeled for phase and load bank
identification; L1-N feeds black outlets (B1); L2-N feeds dark-gray outlets (B2); L3-N feeds light-gray outlets (B3)
Front Panel LCD Display
Large digital display reports Amperage, Kilowatts, Voltage, Unbalance percentage, Temperature* and Humidity*
information (*requires ENIVIROSENSE option); Small digital display provides detail on the measurement the large
display is reporting: Input-phase (L#), Load bank (B#), Sensor (S#), Load unbalance (UB), Output power (OP)
Front Panel LEDs
Set of 6 LEDs identify the value displayed on the large digital display: Amperage (A), Kilowatts (kW), Voltage (V),
Unbalance percentage (%UB), Temperature (T), Humidity (%RH); One additional LED for each output load bank
(B1-B3) offers information power availability: GREEN (80% load), RED (Power OFF), RED
FLASHING (Power OFF/breaker trip)
Switches
Set of UP/DOWN arrow buttons scroll through available Input, Bank, Power, Load balance and Sensor options;
Additional MODE button
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
2/4
Cleveland, OH 44122
United States
Form Factors Supported
Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
6.89 x 9.65 x 75.87
Shipping Dimensions (hwd / cm)
17.50 x 24.51 x 192.71
Shipping Weight (lbs.)
20.26
Shipping Weight (kg)
9.19
Unit Dimensions (hwd / in.)
70.000 x 2.170 x 2.860
Unit Dimensions (hwd / cm)
177.8 x 5.51 x 7.3
Unit Weight (lbs.)
13.50
Unit Weight (kg)
6.12
ENVIRONMENTAL
Operating Temperature Range
0C ~ 50C (32F ~ 122F)
Storage Temperature Range
-30°C to +60°C (-22°F to +140°F)
Relative Humidity
5-95% non condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
COMMUNICATIONS
PowerAlert Software
SNMPWEBCARD Interface: PowerAlert 12
Communications Cable
RJ45-to-DB9 configuration/console Access cable
Network Compatibility
10 Mbps; 100 Mbps (Fast Ethernet)
FEATURES & SPECIFICATIONS
High Availability PDU Features
Remote Network Notifications
STANDARDS & COMPLIANCE
Product Certifications
EN 60950-1; CSA (Canada); NOM (Mexico); UL 60950-1
Product Compliance
RoHS; CE (Europe); FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
