1000 Eaton Boulevard
Cleveland, OH 44122
United States
11kW 3-Phase Monitored PDU, 220/230V (30 C13
& 6 C19), IEC-309 16A Red, 380/400V Input, 3ft
Cord, 0U Vertical
MODEL NUMBER: PDU3XVN3G16
Highlights
Monitored 11kW 3 Phase
380/400V input, 220/230V
output PDU; 178cm 0U vertical
rackmount
Reports voltage, frequency and
load per-phase via built in
ethernet interface
Visual current meter; Toolless
button-mount installation
IEC-309 Red 16A (3P+N+E)
380/400V 3 phase input; .9m
line cord
30 C13 & 6 C19 single phase
220/230V outlets; Included cord
retention brackets
Temperature, humidity and
contact closure monitoring
options
Package Includes
Monitored rackmount PDU with
pre-installed mounting buttons
Cord retention brackets
Spare installation buttons (2
9mm / 4 6mm)
Tripp Lite 3 phase Monitored PDU / Power Distribution Unit offers real-time remote monitoring of voltage,
Rack mounting brackets
frequency and load levels via built-in network connection. PowerAlert interface supports custom
Owner's manual
Description
notification of user-specified remote conditions via email, secure web, SNMP, Telnet or SSH interface.
PDU output current consumption in amps is displayed per-phase via front panel lighted digital display and
can be monitored remotely to warn of potential overloads before critical IT mains breakers trip.
Features
11kW 3 phase 380/400V input, 220/230V output Monitored Power Distribution Unit (PDU) with built-in
web/network interface
Attached IEC-309 Red 16A (3P+N+E) 380/400V 3 phase input plug with .9m cord
0U / 178cm vertical form factor supports installation in 2 or 4 post equipment racks
36 total 220/230V outlets (30 C13, 6 C19) arranged in 3 single-phase output load banks
Lighted display with scroll-button reports power consumption in amps for all 3 loading banks, IP-address
self-identification and 180 degree display rotation for overhead or raised floor power feeds.
Built-in SNMP/Ethernet interface reports voltage, frequency and PDU loading per-phase via network or
secure web browser interface with options for user specified alarm and notification thresholds
Supports in-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor
and rack access notification with up to 4 optional SRSWITCH door sensors
DHCP/Manual configuration support
10/100 Mbps auto-sensing allows optimal communication with 10/100 Base-T networks
Real-time clock backup maintains the time of day and date even if the PDU is not powered on
Tiered access privileges allow an administrator and a guest to login via web browser for monitoring
Alert notifications via email or SNMP traps offer immediate event notification
Firmware upgrade ability supports future product enhancements.
Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2,
SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols
1/3
Cleveland, OH 44122
United States
Fully compatible with FREE PowerAlert Network Management System / NMS Software
Included cord retention brackets keep vital network equipment plugged in and continuously powered
Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for
other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons
included)
Specifications
OVERVIEW
UPC Code
037332158376
PDU Type
Monitored
INPUT
Recommended Electrical Service
16A 400/230V with IEC309 16A Red (3P+N+E) outlet
Maximum Input Amps
16
PDU Plug Type
IEC-309 16/20A RED (3P+N+E)
Input Phase
3-Phase
Input Cord Length (ft.)
3
Input Cord Length (m)
0.91
OUTPUT
Output Capacity Details
11.5kW (415/240V), 11.1kW (400/230V), 10.5kW (380/220V) total capacity; 16A max per output phase (L1-L2, L2L3, L3-L1); 16A max per C19 outlet; 10A max per C13 outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(30) C13; (6) C19
Output Nominal Voltage
220 (380V input); 230 (400V input)
USER INTERFACE, ALERTS & CONTROLS
Reported Load Segments
Supports local monitoring of current for each output phase (16A balanced max per output load banks L1, L2 and L3);
BANK "L1" is powered by L1-N (outlets 1-12); BANK "L2" is powered by L2-N (outlets 13-24); BANK "L3" is powered
by L3-N (outlets 25-36)
Front Panel LCD Display
Digital display reports output load level in amps separately for each output phase; Can also be used to scroll the
configured IP address
Front Panel LEDs
Set of 3 LEDs (L1, L2, L3) indicate the output load segment the digital current display is reporting
Switches
SELECT switch advances the digital display and LED to report power consumption for load segments L1, L2 and L3
(short press); SELECT switch also rotates the local display 90 degrees for overhead power input (long press);
SCROLL IP button scrolls the configured IP address (long press)
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
2/3
Cleveland, OH 44122
United States
Material of Construction
Metal
Form Factors Supported
Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
6.30 x 9.60 x 75.00
Shipping Dimensions (hwd / cm)
16.00 x 24.38 x 190.50
Shipping Weight (lbs.)
16.30
Shipping Weight (kg)
7.39
Unit Dimensions (hwd / in.)
70.000 x 2.200 x 3.580
Unit Dimensions (hwd / cm)
177.8 x 5.6 x 9.1
Unit Weight (lbs.)
12.6
Unit Weight (kg)
5.72
ENVIRONMENTAL
Storage Temperature Range
-30°C to +50°C (-22°F to +122°F)
Relative Humidity
5-95% non condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
COMMUNICATIONS
PowerAlert Software
SNMPWEBCARD Interface: PowerAlert 12
Communications Cable
RJ45-to-DB9 configuration/console Access cable
Network Compatibility
10 Mbps; 100 Mbps (Fast Ethernet)
STANDARDS & COMPLIANCE
TAA Compliant Option
TAA Compliant Version Available - Order Tripp Lite PDU3XEVN6G20
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDU3XVN3G16”相匹配的价格&库存,您可以联系我们找货
