HE12-1A69-02
HE12-1A69-02
    STANDEX-MEDER(斯丹麦德)
    Reed Relay SPST-NO (1 Form A) 12VDC Coil Through Hole
HE12-1A69-02 数据手册
A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – HE Reed Relays HE Series Reed Relays  Features: High Voltage Relay, Through-Hole / Axial Wire Option, Compact Design, Special Pin-Outs  Applications: High Voltage Test Sets, Cable Testers, Medical Equipment & Others  Markets: Medical, Test and Measurement & Others HE 00-0X-00-00 Part Description: Nominal Voltage Contact QTY Contact Form Switch Model Pin Out 05, 06, 12, 24, 48 1, 2 A, B 69, 83 02, 03, 150, 300 Customer Options Contact Data 69 83 Rated Power (max.) 50 50 W 10,000 7,500 V 3.0 3.0 A 5.0 5.0 A 150 150 mOhm 15 10 kVDC 3.0 3.0 ms 1.5 1.5 ms 1012 1012 Ohm 0.2 0.2 pF Switch Model Any DC combination of V&A not to exceed their individual max.’s Switching Voltage (max.) DC or peak AC Switching Current (max.) DC or peak AC Carry Current (max.) DC or peak AC Contact Resistance (max.) @ 0.5V & 50mA Breakdown Voltage (min.) According to EN60255-5 Operating Time (max.) Incl. Bounce; Measured with w/ Nominal Voltage Release Time (max.) Measured with no Coil Excitation Insulation Resistance (typ.) Rh
HE12-1A69-02 价格&库存
很抱歉,暂时无法提供与“HE12-1A69-02”相匹配的价格&库存,您可以联系我们找货
