HEF4021BT,653
HEF4021BT,653
    NEXPERIA(安世)
    SOIC16_150MIL
    8位静态移位寄存器
HEF4021BT,653 数据手册
HEF4021B 8-bit static shift register Rev. 10 — 21 March 2016 Product data sheet 1. General description The HEF4021B is an 8-bit static shift register (parallel-to-serial converter) with a synchronous serial data input (DS), a clock input (CP), an asynchronous active HIGH parallel load input (PL), eight asynchronous parallel data inputs (D0 to D7) and buffered parallel outputs from the last three stages (Q5 to Q7). Each register stage is a D-type master-slave flip-flop with a set direct (SD) and clear direct (CD) input. Information on D0 to D7 is asynchronously loaded into the register while PL is HIGH, independent of CP and DS. When PL is LOW, data on DS is shifted into the first register position and all the data in the register is shifted one position to the right on the LOW-to-HIGH transition of CP. Schmitt trigger action makes the clock input highly tolerant of slower rise and fall times. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits       Tolerant of slower rise and fall times Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +125 C Complies with JEDEC standard JESD 13-B 3. Ordering information Table 1. Ordering information All types operate from 40 C to +125 C. Type number Package Name Description Version HEF4021BT SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4021BTT TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 HEF4021B Nexperia 8-bit static shift register 4. Functional diagram         ' ' ' ' ' ' ' '  3/ 6'&' '  '6  &3 &3 6+,)75(*,67(5 %,76 4 4 4    DDH Fig 1. Functional diagram ' ' 6' 6' '6 2 ' &3 ' 6' 2 ' ' &3 6' 2 ' 2 ' &3 &3 )) )) )) )) &' &' &' &' 3/ &3 4 4 4 DDH Fig 2. Logic diagram HEF4021B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 2 of 15 HEF4021B Nexperia 8-bit static shift register 5. Pinning information 5.1 Pinning +()% '   9'' 4   ' 4   ' '   ' '   4 '   '6 '   &3 966   3/ DDH Fig 3. Pin configuration 5.2 Pin description Table 2. Pin description Symbol Pin Description Q5 to Q7 2, 12, 3 buffered parallel output from the last three stages D0 to D7 7, 6, 5, 4, 13, 14,15, 1 parallel data input VSS 8 ground supply voltage PL 9 parallel load input CP 10 clock input (LOW-to-HIGH edge-triggered) DS 11 serial data input VDD 16 supply voltage HEF4021B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 3 of 15 HEF4021B Nexperia 8-bit static shift register 6. Functional description Table 3. Function table[1] Number of clock Inputs transitions CP Outputs DS PL Q5 Q6 Q7 Serial operation 1  data 1 L X X X 2  data 2 L X X X 3  data 3 L X X X 6  X L data 1 X X 7  X L data 2 data 1 X 8  X L data 3 data 2 data 1  X L no change no change no change X X H D5 D6 D7 Parallel operation [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care;  = LOW to HIGH clock transition; = HIGH to LOW clock transition; data n = data (HIGH or LOW) on the DS input at the nth  CP transition. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O Conditions VI < 0.5 V or VI > VDD + 0.5 V Min Max Unit 0.5 +18 V - 10 mA 0.5 VO < 0.5 V or VO > VDD + 0.5 V VDD + 0.5 V - 10 mA input/output current - 10 mA IDD supply current - 50 mA Tstg storage temperature 65 +150 C Tamb ambient temperature 40 +125 C Ptot total power dissipation - 500 mW - 100 mW Tamb 40 C to +125 C SO16 and TSSOP16 package P [1] power dissipation per output [1] For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. For TSSOP16 package: Ptot derates linearly with 5.5 mW/K above 60 C. HEF4021B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 4 of 15 HEF4021B Nexperia 8-bit static shift register 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VDD VI Conditions Min Typ Max Unit supply voltage 3 - 15 V input voltage 0 - VDD V Tamb ambient temperature in free air 40 - +125 C t/V input transition rise and fall rate VDD = 5 V - - 3.75 s/V VDD = 10 V - - 0.5 s/V VDD = 15 V - - 0.08 s/V 9. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL Conditions HIGH-level input voltage IO < 1 A LOW-level input voltage IO < 1 A Tamb = 25 C Tamb = 85 C Min Max Min Max Min Max Min Max 5V 3.5 - 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - 7.0 - V VDD Tamb = 40 C Tamb = 125 C Unit 15 V 11.0 - 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 - 0.05 V 5V - 1.7 - 1.4 - 1.1 - 1.1 mA 5V - 0.64 - 0.5 - 0.36 - 0.36 mA VO = 9.5 V 10 V - 1.6 - 1.3 - 0.9 - 0.9 mA VO = 13.5 V 15 V - 4.2 - 3.4 - 2.4 - 2.4 mA HIGH-level output voltage IO < 1 A LOW-level output voltage IO < 1 A HIGH-level VO = 2.5 V output current V = 4.6 V O LOW-level VO = 0.4 V output current V = 0.5 V O 5V 0.64 - 0.5 - 0.36 - 0.36 - mA 10 V 1.6 - 1.3 - 0.9 - 0.9 - mA VO = 1.5 V 15 V 4.2 - 3.4 - 2.4 - 2.4 - mA II input leakage VDD = 15 V current 15 V - 0.1 - 0.1 - 1.0 - 1.0 A IDD supply current 5V - 5 - 5 - 150 - 150 A CI input capacitance HEF4021B Product data sheet IO = 0 A 10 V - 10 - 10 - 300 - 300 A 15 V - 20 - 20 - 600 - 600 A - - - - 7.5 - - - - pF All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 5 of 15 HEF4021B Nexperia 8-bit static shift register 10. Dynamic characteristics Table 7. Dynamic characteristics VSS = 0 V; Tamb = 25 C; for test circuit see Figure 7; unless otherwise specified. Symbol tPHL Parameter HIGH to LOW propagation delay Conditions VDD CP to Qn see Figure 4 Extrapolation formula Min Typ Max Unit 98 ns + (0.55 ns/pF)CL - 125 250 ns 10 V 44 ns + (0.23 ns/pF)CL - 55 110 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns 5V 93 ns + (0.55 ns/pF)CL - 120 240 ns 10 V 44 ns + (0.23 ns/pF)CL - 55 110 ns 32 ns + (0.16 ns/pF)CL - 40 80 ns 88 ns + (0.55 ns/pF)CL - 115 230 ns 10 V 39 ns + (0.23 ns/pF)CL - 50 100 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns 5V 78 ns + (0.55 ns/pF)CL - 105 210 ns 10 V 39 ns + (0.23 ns/pF)CL - 50 100 ns 32 ns + (0.16 ns/pF)C - 40 80 ns 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 5V +25 15 - ns 10 V +25 10 - ns 15 V +15 5 - ns 5V 50 25 - ns 10 V 30 10 - ns 15 V 20 5 - ns 5V PL to Qn see Figure 4 [1] 15 V tPLH LOW to HIGH propagation delay CP to Qn see Figure 4 5V PL to Qn see Figure 4 [1] 15 V tt tsu transition time set-up time Qn; see Figure 4 DS to CP; see Figure 5 Dn to PL; see Figure 6 th hold time DS to CP; see Figure 5 5V 40 20 - ns 10 V 20 10 - ns 15 V 15 8 - ns 5V +15 10 - ns 10 V 15 0 - ns 15 V 15 0 - ns CP = LOW; minimum width; see Figure 5 5V 70 35 - ns 10 V 30 15 - ns 15 V 24 12 - ns PL = HIGH; minimum width; see Figure 6 5V 70 35 - ns 10 V 30 15 - ns 15 V 24 12 - ns PL input; see Figure 6 5V 50 10 - ns 10 V 40 5 - ns 15 V 35 5 - ns Dn to PL; see Figure 6 tW trec pulse width recovery time HEF4021B Product data sheet 5V [1] All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 6 of 15 HEF4021B Nexperia 8-bit static shift register Table 7. Dynamic characteristics …continued VSS = 0 V; Tamb = 25 C; for test circuit see Figure 7; unless otherwise specified. Symbol Parameter Conditions VDD fclk(max) maximum clock frequency CP input; see Figure 5 [1] Extrapolation formula Min Typ Max Unit 5V 6 13 - MHz 10 V 15 30 - MHz 15 V 20 40 - MHz The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol PD Parameter dynamic power dissipation VDD Typical formula for PD (W) where: 5V PD = 900  fi + (fo  CL)  VDD 10 V PD = 4300  fi + (fo  CL)  VDD 15 V PD = 12000  fi + (fo  CL)  2 fi = input frequency in MHz, 2 VDD2 fo = output frequency in MHz, CL = output load capacitance in pF, VDD = supply voltage in V, (fo  CL) = sum of the outputs. 11. Waveforms 9'' &3RU3/,1387 90 966 W3+/ 92+ 9< 4Q287387 90 9; 92/ Fig 4. W3/+ WW WW DDM Waveforms showing propagation delays for CP and PL inputs to Qn output and Qn transition times IFON PD[ 9'' &3,1387 90 966 WVX WK W: 9'' '6,1387 90 966 DDH Fig 5. Waveforms showing minimum clock pulse width, set-up time, and hold time for CP and DS. HEF4021B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 7 of 15 HEF4021B Nexperia 8-bit static shift register 9'' &3,1387 90 966 W: WUHF 9'' 90 3/,1387 966 WVX 9'' 'Q,1387 966 WK  90  WI WU DDH Set-up times and hold times are shown as positive values but may be specified as negative values; Measurement points are given in Table 9. Fig 6. Waveforms showing minimum pulse width and recovery time for PL; set-up and hold times for Dn to PL. Table 9. Measurement points Supply voltage Input Output VDD VM VM VX VY 5 V to 15 V 0.5VDD 0.5VDD 0.1VDD 0.9VDD HEF4021B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 8 of 15 HEF4021B Nexperia 8-bit static shift register W: 9,   QHJDWLYH SXOVH 90 90  9 9,  WI WU WU WI  SRVLWLYH SXOVH  90 90  9  W: DDM a. Input waveform 9'' * 9, 92 '87 &/ 57 DDJ b. Test circuit Test data is given in Table 10. Definitions for test circuit: DUT = Device Under Test. CL = load capacitance including jig and probe capacitance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Fig 7. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VDD VI tr, tf CL 5 V to 15 V VSS or VDD  20 ns 50 pF HEF4021B Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 9 of 15 HEF4021B Nexperia 8-bit static shift register 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG Fig 8. 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Package outline SOT109-1 (SO16) HEF4021B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 10 of 15 HEF4021B Nexperia 8-bit static shift register 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 Fig 9. 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Package outline SOT403-1 (TSSOP16) HEF4021B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 11 of 15 HEF4021B Nexperia 8-bit static shift register 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4021B v.10 20160321 Product data sheet - HEF4021B v.9 Modifications: HEF4021B v.9 Modifications: HEF4021B v.8 Modifications: • Type number HEF4021BP (SOT38-4) removed. 20130830 • 20111118 • • • Product data sheet - HEF4021B v.8 - HEF4021B v.7 added type number HEF4021BTT. Product data sheet Legal pages updated. Changes in “General description” and “Features and benefits”. Section “Applications” removed. HEF4021B v.7 20111010 Product data sheet - HEF4021B v.6 HEF4021B v.6 20091127 Product data sheet - HEF4021B v.5 HEF4021B v.5 20090707 Product data sheet - HEF4021B v.4 HEF4021B v.4 20081110 Product data sheet - HEF4021B_CNV v.3 HEF4021B_CNV v.3 19950101 Product specification - HEF4021B_CNV v.2 HEF4021B_CNV v.2 19950101 Product specification - - HEF4021B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 12 of 15 HEF4021B Nexperia 8-bit static shift register 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. HEF4021B Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 13 of 15 HEF4021B Nexperia 8-bit static shift register Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com HEF4021B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia HEF4021B 8-bit static shift register 16. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 14.1 14.2 14.3 14.4 15 16 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 March 2016
HEF4021BT,653 价格&库存
很抱歉,暂时无法提供与“HEF4021BT,653”相匹配的价格&库存,您可以联系我们找货
HEF4021BT,653
  • 55+3.0433055+0.36883
  • 100+2.21463100+0.26840
  • 250+1.10096250+0.13343
库存:374
HEF4021BT,653
  • 2500+1.081082500+0.13102
  • 5000+1.076035000+0.13041
  • 10000+1.0760110000+0.13041
  • 12500+1.0759812500+0.13041
  • 37500+1.0759637500+0.13040
HEF4021BT,653
  • 1+1.32000
  • 100+1.23200
  • 300+1.14400
  • 500+1.05600
  • 2000+1.01200
  • 5000+0.98560
