austriamicrosystems
AS3527
Product Brief
Product Brief
AS3527
Advanced Audio Processor System
å
AS3527 also contains a charger for Li-Io batteries.
1 Description
This highly flexible and fully integrated audio processor system
(AS3527) combines strong calculating power, high performance
audio features with system power management options for battery
powered devices.
Using advanced process technology and large on chip RAM unique
power management techniques leads to outstanding system level
low power consumption of 52mW for a complete flash-player during
MP3 playback.
The single supply voltage may vary from 3.0V to 5.5V.
2
Key Features
2.1
Digital Core
Embedded 32-Bit RISC Controller
Based on a powerful ARM9TDMI capable of performing up to
200MIPS it is suited to run MP3, AAC, WMA, OGG… decoders and
encoders and, in addition, it can perform advanced user interfaces,
motion graphics support, video playback and much more.
The AS3527 SOC (system-on-a-Chip) features dedicated high
speed interfaces for ATA IDE, USB2.0 HS-OTG and SDRAM
ensuring maximum performance for download, upload, and
playback.
Furthermore interfaces for NAND flashes, MMC/SD cards and
Memory Stick ensure most flexible system design possibilities.
Hardware support for parallel interfaces lower the CPU load serving
complex and/or colour user interfaces.
Additional SPI, Fast UARTs and configurable serial high-speed data
and control interfaces enable the addition of a number of
connectivity options, radio broadcast and communication front ends:
Satellite radio (XM-Radio, HD-Radio, Sirius, DAB)
BT2.0 radio front ends or complete chip sets
WiFi chip sets
Comm receivers (i.e. GSM, etc)
GPS radio or complete chip set
Two independently programmable PLLs generate the required
frequencies for audio playback/recording, for the processor core and
for the USB interface at the same time. An additional external clock
input eliminates the use of external crystals when used in multiprocessor systems like mobile phones.
It has a variety of audio inputs and outputs to directly connect
electret microphones, and auxiliary signal sources via a 10-channel
mixer to a headset 16Ω/32Ω or auxiliary audio peripherals.
Selectable mixer bypasses lower the power consumption for simple
playback operations and enlarger the system design flexibility.
Further the device offers advanced power management functions.
All necessary ICs and peripherals in a Digital Audio Player with flash
or hard-disk memory are supplied by the AS3527. The different
regulated supply voltages are fully programmable. The power
management block generates 11 different supply voltages out of a
single battery supply. CPU, NAND flash, SRAM, memory cards,
harddisk, LCD, LCD back-light, USB-HOST and USB-OTG can be
powered.
The AS3527 has an independent 32kHz real time clock (RTC) on
chip, which allows a complete power down of the system CPU and
peripherals.
ARM922TDMI RISC CPU
2.5Mbit on-chip RAM
1Mbit on chip ROM
Clock speed max. 250MHz (200MIPS)
Standard JTAG interface
USB 2.0 HS & OTG Interface
Up to 480Mbit/s transfer speed
USB 2.0 HS/FS physical inlcuding OTG support
USB 2.0 HS/FS digital core including OTG host
Dedicated dual port buffer RAM
DMA bus master functionality
IDE Host Controller
Supporting Ultra ATA 33/66/100/133 modes
Programmable IO and Multi-word DMA capability
External Memory Controller
Dynamic memory interface
Asynchronous static memory
DMA Controller
Single Master DMA controller
2 DMA channels possible at the same time
16 DMA requests supported
Interrupt Controller
Support for 32 standard interrupts
Support for 16 vectored IRQ interrupts
Audio Subsystem Interface
Dedicated 2 wire serial control master
I2S input and output with dual port buffer RAM
Nand Flash Interface
8 and 16bit flash support
3, 4 & 5 byte address support
hardware ECC
© 2005-2006, austriamicrosystems AG, 8141 Unterpremstaetten, Austria-Europe. All Rights Reserved.
www.austriamicrosystems.com
1-4
austriamicrosystems
AS3527
Product Brief
MMC/SD Interface
MMC/SD Card host for multiple card support
4 data line support for SD cards
MS / MS Pro Interface
Display Interface
Serial and parallel controller supported
FiFo buffered
Programmable timing
Synchronous Serial Interface
Master and slave operation
8 and 16 bit support
Several protocol standards supported
I2S Interface
Input multiplexed with audio subsystem
selectable SPDIF input conversion
2 Wire Serial Control Interface
Standard and fast mode support
General Purpose IO Interface
4x 8-bit ports
Multiple Boot Options
Selection of internal ROM or external boot device
Internal boot loader supporting boot from external
NorFlash, NandFlash, IDE, SPI host
Internal USB boot loader with USB promer supporting
initial factory programming and firmware update
2.2
Audio
Multi-bit Sigma Delta Converters
DAC: 18bit with 94dB SNR (‘A’ weighted)
ADC: 20bit with 90dB SNR (‘A’ weighted)
Sampling Frequency: 8-48kHz
32 gain steps @ 1.5dB and MUTE
2 Line Inputs
stereo, 2x mono or mono differential inputs
2 Microphone Inputs
differential inputs
3 gain pre-sets (28/34/40 dB) and OFF with AGC
microphone detection with about 50uA
supply for electret microphone max 1mA
voice activation and remote control by switch
2 Line Outputs
max 1Vp @ 10kΩ in single ended stereo mode
>32Ω in mono differential mode to drive ear-pieces
Mixer bypass
Stereo Headphone Audio Amplifier
2x 60mW @ 16Ω driver capacity
Click- and pop-less start-up and power down
Headphone and over-current detection
Phantom ground eliminates large capacitors
Mixer bypass
10 Channel Audio Mixer
mixes Line inputs, Mic inputs and DAC output
separate selectable source for right and left channel
possibility to select AGC to prevent clipping
2-4
austriamicrosystems
AS3527
Product Brief
2.3
Power Management
2.4
System
Li-Io Battery Charger
RTC
automatic 50mA trickle charging
prog. constant current charging (50 – 400mA)
prog. constant voltage charging (3.9 - 4.25V)
Voltage Generation
ultra low power 32kHz oscillator
32bit RTC second counter, 96 days auto wake-up
selectable alarm (seconds or minutes)
trim able oscillator
128bit free SRAM for random settings
32kHz clock output to peripherals
Oscillator
step down for harddisk (0.65V-3.4V, 500mA)
step down for CPUcore (1.05V-1.2V, 250mA)
step down for peripheral (0.65V-3.4V, 250mA)
charge pump for USB OTG (5V, 10mA)
step up for USB HOST/OTG (5V, 500mA)
LDO for digital supply (2.9V, 200mA)
LDO for analog supply (2.9V, 200mA)
LDO for peripherals (1.2V-3.5V, 200mA)
LDO for USB transceiver (3.26V, 200mA)
LDO for RTC (1.0V-2.5V, 2mA)
25V Back-light step up converter
for driving up to 6 white LEDs in series to achieve a
uniform illumination
current programmable up to 40mA (1.25mA steps)
dimming with selectable timing
low power 12-24MHz Oscillator
generating main system clock
Supervisor
automatic battery monitoring with interrupt generation
and selectable warning level
automatic temp supervision with interrupt generation
and selectable warning and shutdown levels
power rail monitoring
General Purpose ADC
10bit resolution
21 inputs analog multiplexer
UID
Unique Identification Number in OTP ROM for DRM
General
Reset pin, watchdog, power good pin
PWM output
hibernation modes
5sec and 10sec emergency shut-down
Wide battery supply range 3V – 5.5V
MP3 playback with 52mW
Packages:
AS3527-A: CTBGA224 13x13mm, 0.8mm pitch
3 Application
Portable Digital Audio Player and Recorder
Portable Digital Media Player
PDA
Smartphone
3-4
AS3527
Product Brief
austriamicrosystems
4 Block Diagram
Figure 1
AS3527 Block Diagram
4-4
