74LVC2G04
Dual inverter
Rev. 9 — 12 December 2016
Product data sheet
1. General description
The 74LVC2G04 provides the dual inverting buffer.
Inputs can be driven from either 3.3 V or 5 V devices. These features allow the use of
these devices in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant inputs for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C.
74LVC2G04
Nexperia
Dual inverter
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC2G04GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC2G04GV
40 C to +125 C
TSOP6
plastic surface-mounted package (TSOP6); 6 leads
SOT457
74LVC2G04GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74LVC2G04GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
74LVC2G04GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74LVC2G04GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74LVC2G04GX
40 C to +125 C
X2SON6
plastic thermal extremely thin small outline package;
no leads; 6 terminals; body 1 0.8 0.35 mm
SOT1255
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC2G04GW
V4
74LVC2G04GV
V04
74LVC2G04GM
V4
74LVC2G04GF
V4
74LVC2G04GN
V4
74LVC2G04GS
V4
74LVC2G04GX
V4
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Logic symbol
74LVC2G04
Product data sheet
PQE
PQE
Fig 1.
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
PQD
Fig 3.
Logic diagram (one gate)
Nexperia B.V. 2017. All rights reserved
2 of 18
74LVC2G04
Nexperia
Dual inverter
6. Pinning information
6.1 Pinning
/9&*
/9&*
VCC or VO < 0 V
output voltage
VO
Min
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
mA
For X2SON6 and XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
Conditions
VI
input voltage
VO
output voltage
Tamb
ambient temperature
t/V
input transition rise and fall rate
Active mode
Power-down mode; VCC = 0 V
74LVC2G04
Product data sheet
Min
Typ
Max
Unit
1.65
5.5
V
V
VCC
V
V
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
4 of 18
74LVC2G04
Nexperia
Dual inverter
10. Static characteristics
Table 7.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
HIGH-level
input voltage
VIH
40 C to +85 C
Conditions
VCC = 1.65 V to 1.95 V
VOH
HIGH-level
output voltage
LOW-level
output voltage
Max
Min
Max
0.65VCC
0.65VCC
V
1.7
1.7
V
VCC = 2.7 V to 3.6 V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
0.35VCC
0.7
0.7
V
0.8
0.8
V
0.3VCC
0.3VCC
V
VCC 0.1
VCC 0.1
V
1.2
0.95
V
0.35VCC V
VI = VIH or VIL
IO = 100 A;
VCC = 1.65 V to 5.5 V
IO = 4 mA; VCC = 1.65 V
VOL
Min
Unit
VCC = 2.3 V to 2.7 V
LOW-level input VCC = 1.65 V to 1.95 V
voltage
VIL
40 C to +125 C
Typ[1]
IO = 8 mA; VCC = 2.3 V
1.9
1.7
V
IO = 12 mA; VCC = 2.7 V
2.2
1.9
V
IO = 24 mA; VCC = 3.0 V
2.3
2.0
V
IO = 32 mA; VCC = 4.5 V
3.8
3.4
V
IO = 100 A;
0.10
0.10
V
0.45
0.70
V
VI = VIH or VIL
0.30
0.45
V
0.40
0.60
V
0.55
0.80
V
0.55
0.80
V
0.1
1
1
A
II
input leakage
current
IOFF
power-off
VCC = 0 V; VI or VO = 5.5 V
leakage current
0.1
2
2
A
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
4
A
ICC
additional
supply current
per pin; VCC = 2.3 V to 5.5 V;
VI = VCC 0.6 V; IO = 0 A
5
500
500
A
CI
input
capacitance
VCC = 3.3 V; VI = GND to VCC
2.5
pF
[1]
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
All typical values are measured at VCC = 3.3 V and Tamb = 25 C.
74LVC2G04
Product data sheet
5 of 18
74LVC2G04
Nexperia
Dual inverter
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for load circuit see Figure 9.
Symbol Parameter
40 C to +85 C
Conditions
power dissipation
capacitance
CPD
Unit
Min
Max
Min
Max
1.0
3.5
8.0
1.0
9.5
ns
1.0
2.2
4.4
1.0
5.4
ns
VCC = 2.7 V
1.0
2.7
5.2
1.0
7.0
ns
VCC = 3.0 V to 3.6 V
0.5
2.7
4.1
0.5
5.5
ns
1.0
1.9
3.2
1.0
3.8
ns
13.5
pF
[2]
propagation delay nA to nY; see Figure 8
tpd
40 C to +125 C
Typ[1]
[3]
VI = GND to VCC; VCC = 3.3 V
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
12. AC waveforms
9,
90
Q$LQSXW
90
*1'
W 3+/
W 3/+
92+
90
Q
很抱歉,暂时无法提供与“74LVC2G04GV,165”相匹配的价格&库存,您可以联系我们找货
