Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
74AHC1G07; 74AHCT1G07
Buffer with open-drain output
Rev. 7 — 18 November 2014
Product data sheet
1. General description
74AHC1G07 and 74AHCT1G07 are high-speed Si-gate CMOS devices. They provide a
non-inverting buffer.
The output of these devices is open-drain and can be connected to other open-drain
outputs to implement active-LOW wired-OR or active-HIGH wired-AND functions. For
digital operation this device must have a pull-up resistor to establish a logic HIGH-level.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
2. Features and benefits
High noise immunity
Low power dissipation
SOT353-1 and SOT753 package options
ESD protection:
HBM JESD22-A114E: exceeds 2000 V
MM JESD22-A115-A: exceeds 200 V
CDM JESD22-C101C: exceeds 1000 V
Specified from 40 C to +125 C
3. Ordering information
Table 1.
Type number
74AHC1G07GW
Package
Temperature range
Name
Description
Version
40 C to +125 C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74AHCT1G07GW
74AHC1G07GV
74AHCT1G07GV
NXP Semiconductors
4. Marking
Table 2.
Marking codes
Type number
Marking[1]
74AHC1G07GW
AS
74AHC1G07GV
A07
74AHCT1G07GW
CS
74AHCT1G07GV
C07
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Logic symbol
*1'
PQD
PQD
Fig 1.
Fig 2.
IEC logic symbol
Fig 3.
PQD
Logic diagram
6. Pinning information
6.1 Pinning
$+&7*
QF
*1'
9&&
DDI
Fig 4.
Pin configuration
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
n.c.
1
not connected
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
74AHC_AHCT1G07
Product data sheet
All information provided in this document is subject to legal disclaimers.
© NXP Semiconductors N.V. 2014. All rights reserved.
2 of 12
NXP Semiconductors
7. Functional description
Table 4.
Function table
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state
Input
Output
A
Y
L
L
H
Z
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
IIK
input clamping current
VI < 0.5 V
IOK
output clamping current
VO < 0.5 V
IO
output current
VO > 0.5 V
output voltage
VO
Conditions
[1]
Min
Max
Unit
0.5
+7.0
V
0.5
+7.0
V
mA
mA
25
mA
active mode
[1]
0.5
+7.0
V
high-impedance mode
[1]
0.5
+7.0
V
ICC
supply current
75
mA
IGND
ground current
75
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
Tamb = 40 C to +125 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For both TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
9. Recommended operating conditions
Table 6.
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
t/V
input transition rise
and fall rate
74AHC_AHCT1G07
Product data sheet
Conditions
74AHC1G07
74AHCT1G07
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
5.5
4.5
5.0
5.5
V
V
active mode
VCC
VCC
V
high-impedance mode
V
40
+25
+125
40
+25
+125
C
VCC = 3.3 V 0.3 V
100
ns/V
VCC = 5.0 V 0.5 V
ns/V
3 of 12
NXP Semiconductors
10. Static characteristics
Table 7.
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
For type 74AHC1G07
VIH
VIL
VOL
HIGH-level
input voltage
LOW-level
input voltage
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 A; VCC = 2.0 V
0.1
0.1
V
IO = 50 A; VCC = 3.0 V
0.1
0.1
V
IO = 50 A; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
0.1
1.0
2.0
A
10.0
A
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
IOZ
OFF-state
VI = VIH or VIL; VO = VCC or
output current GND; VCC = 5.5 V
0.25
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
A
CI
input
capacitance
1.5
10
10
10
pF
2.5
For type 74AHCT1G07
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOL
LOW-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = 50 A
0.1
0.1
V
IO = 8.0 mA
0.36
0.44
0.55
V
0.1
1.0
2.0
A
OFF-state
0.25
10.0
A
ICC
VCC = 5.5 V
1.0
10
A
ICC
additional
per input pin; VI = 3.4 V;
supply current other inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
1.5
10
10
10
pF
II
input leakage
current
IOZ
74AHC_AHCT1G07
Product data sheet
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
2.5
4 of 12
NXP Semiconductors
11. Dynamic characteristics
Table 8.
GND = 0 V; tr = tf = 3.0 ns. For test circuit see Figure 6.
Symbol
Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
3.5
5.6
1.0
6.3
1.0
7.0
ns
5.0
8.0
1.0
9.0
1.0
10.0
ns
CL = 15 pF
2.5
3.9
1.0
4.6
1.0
4.9
ns
CL = 50 pF
3.6
5.5
1.0
6.5
1.0
7.0
ns
5.8
7.9
1.0
8.4
1.0
8.9
ns
8.3
11.5
1.0
12.0
1.0
12.5
ns
4.2
5.1
1.0
5.6
1.0
6.1
ns
6.0
7.5
1.0
8.0
1.0
8.5
ns
5
pF
CL = 15 pF
2.8
4.6
1.0
5.3
1.0
5.6
ns
CL = 50 pF
4.0
6.5
1.0
7.5
1.0
8.0
ns
3.9
5.6
1.0
6.1
1.0
6.6
ns
5.5
8.0
1.0
8.5
1.0
9.0
ns
6.5
pF
For type 74AHC1G07
tPZL
OFF-state
to LOW
propagation
delay
A to Y; see Figure 5
VCC = 3.0 V to 3.6 V
[1]
CL = 15 pF
CL = 50 pF
tPLZ
LOW to
OFF-state
propagation
delay
[2]
[1]
CL = 15 pF
CL = 50 pF
[2]
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
capacitance
per buffer;
CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[3]
For type 74AHCT1G07
tPZL
tPLZ
OFF-state
to LOW
propagation
delay
LOW to
OFF-state
propagation
delay
[2]
[2]
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
capacitance
per buffer;
VI = GND to VCC
[1]
Typical values are measured at VCC = 3.3 V.
[2]
Typical values are measured at VCC = 5.0 V.
[3]
[3]
CPD is used to determine the dynamic power dissipation PD (W).
PD = CPD VCC2 fi + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts
74AHC_AHCT1G07
Product data sheet
5 of 12
NXP Semiconductors
12. Waveforms
9,
90
$LQSXW
*1'
W 3=/
W 3/=
9&&
很抱歉,暂时无法提供与“74AHC1G07GW,165”相匹配的价格&库存,您可以联系我们找货
