Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
74AHC1G32; 74AHCT1G32
2-input OR gate
Rev. 8 — 18 November 2014
Product data sheet
1. General description
74AHC1G32 and 74AHCT1G32 are high-speed Si-gate CMOS devices. They provide a
2-input OR function.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
2. Features and benefits
Symmetrical output impedance
High noise immunity
ESD protection:
HBM JESD22-A114E: exceeds 2000 V
MM JESD22-A115-A: exceeds 200 V
CDM JESD22-C101C: exceeds 1000 V
Low power dissipation
Balanced propagation delays
SOT353-1 and SOT753 package options
Specified from 40 C to +125 C
3. Ordering information
Table 1.
Type number
74AHC1G32GW
Package
Temperature range
Name
Description
Version
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74AHCT1G32GW
74AHC1G32GV
74AHCT1G32GV
NXP Semiconductors
2-input OR gate
4. Marking
Table 2.
Marking codes
Type number
Marking code[1]
74AHC1G32GW
AG
74AHCT1G32GW
CG
74AHC1G32GV
A32
74AHCT1G32GV
C32
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
PQD
PQD
Fig 1.
Logic symbol
Fig 2.
IEC logic symbol
PQD
Fig 3.
Logic diagram
6. Pinning information
6.1 Pinning
$+&7*
*1'
9&&
DDN
Fig 4.
Pin configuration SOT353-1 (TSSOP5) and SOT753 (SC-74A)
74AHC_AHCT1G32
Product data sheet
All information provided in this document is subject to legal disclaimers.
© NXP Semiconductors N.V. 2014. All rights reserved.
2 of 13
NXP Semiconductors
2-input OR gate
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
B
1
data input
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
7. Functional description
Table 4.
Function table
H = HIGH voltage level; L = LOW voltage level
Inputs
Output
A
B
Y
L
L
L
L
H
H
H
L
H
H
H
H
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
0.5
+7.0
V
VI
input voltage
0.5
+7.0
V
mA
mA
25
mA
IIK
input clamping current
VI < 0.5 V
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
IO
output current
0.5 V < VO < VCC + 0.5 V
ICC
supply current
75
mA
IGND
ground current
75
mA
Tstg
storage temperature
65
+150
C
250
mW
total power dissipation
Ptot
Tamb = 40 C to +125 C
[1]
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For both TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
74AHC_AHCT1G32
Product data sheet
3 of 13
NXP Semiconductors
2-input OR gate
9. Recommended operating conditions
Table 6.
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
74AHC1G32
Min
Typ
74AHCT1G32
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
5.5
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise
and fall rate
VCC = 3.3 V 0.3 V
100
ns/V
VCC = 5.0 V 0.5 V
ns/V
10. Static characteristics
Table 7.
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = 50 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 50 A; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = 50 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = 8.0 mA; VCC = 4.5 V
For type 74AHC1G32
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
3.94
3.8
3.70
V
LOW-level
VI = VIH or VIL
output voltage
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.36
0.44
0.55
V
0.36
0.44
0.55
V
0.1
1.0
2.0
A
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
A
CI
input
capacitance
1.5
10
10
10
pF
74AHC_AHCT1G32
Product data sheet
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
4 of 13
NXP Semiconductors
2-input OR gate
Table 7.
Static characteristics …continued
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
For type 74AHCT1G32
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = 50 A
4.4
4.5
4.4
4.4
V
3.94
3.8
3.70
V
IO = 8.0 mA
VOL
LOW-level
output voltage
IO = 50 A
IO = 8.0 mA
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
A
II
input leakage
current
ICC
VCC = 5.5 V
1.0
10
40
A
ICC
additional
per input pin; VI = 3.4 V;
supply current other inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
1.5
10
10
10
pF
11. Dynamic characteristics
Table 8.
GND = 0 V; tr = tf = 3.0 ns. For waveform see Figure 5. For test circuit see Figure 6.
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
For type 74AHC1G32
tpd
propagation
delay
[1]
A and B to Y
VCC = 3.0 V to 3.6 V
[2]
CL = 15 pF
4.4
7.9
1.0
9.5
1.0
10.0
ns
CL = 50 pF
6.3
11.4
1.0
13.0
1.0
14.5
ns
3.2
5.5
1.0
6.5
1.0
7.0
ns
4.6
7.5
1.0
8.5
1.0
9.5
ns
16
pF
[3]
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
capacitance
74AHC_AHCT1G32
Product data sheet
per buffer;
CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[4]
5 of 13
NXP Semiconductors
2-input OR gate
Table 8.
Dynamic characteristics …continued
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
3.3
6.9
1.0
8.0
1.0
9.0
ns
4.8
7.9
1.0
9.0
1.0
10
ns
17
pF
For type 74AHCT1G32
propagation
delay
tpd
[1]
A and B to Y
[3]
CL = 15 pF
CL = 50 pF
power
dissipation
capacitance
CPD
per buffer;
VI = GND to VCC
[1]
tpd is the same as tPLH and tPHL.
[2]
Typical values are measured at VCC = 3.3 V.
[4]
[3]
Typical values are measured at VCC = 5.0 V.
[4]
CPD is used to determine the dynamic power dissipation PD (W).
PD = CPD VCC2 fi + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts.
12. Waveforms
$%LQSXW
90
W3+/
很抱歉,暂时无法提供与“74AHC1G32GW,165”相匹配的价格&库存,您可以联系我们找货
