engineered to light up your design
www.vcclite.com
1.800.522.5546
7017X Series Surface Mount LEDs 0603 Package Size
Description and Features
.063
.011
LED DIE
CATHODE
MARKS
.031
Leading Edge LED Optoelectronic Performance
• Consistent high brightness.
.048
.043
.028
.008
.012
Surface Mount Technology
• Tape and reel packaged for high-speed autoinsertion.
• Convection and vapor-phase reflow compatible.
• Compact form enables high density placement.
• Packaged 4000 pieces per reel.
Exceptional Reliability
• Stringent process controls assure quality.
• Extensive qualification testing to meet strictest requirements.
• Designed to permit easy post-reflow solder joint inspection.
• Refer to “Solder Pad Geometry 1.pdf”
.012
POLARITY MARK
ANODE (+)
CATHODE (-)
All dimensions
in inches.
Electro-Optical Characteristics and Ratings
7017X7
7017X33
7017X5
7017X1
7017X23
7017X3
7017X15
7017X13
7017X21
P AR T NUMB E R
Y ellow/G reen Y ellow
R ed
G reen
Orange
Orange
G reen
Y ellow
R ed
Output C olor
Diffused
Diffused
Diffused
Diffused
Diffused
Diffused
Diffused
Diffused
Diffused
Diffusion
White
C lear
C lear
C lear
White
C lear
C lear
C lear
White
P ackage C olor
T est C urrent (mA)
1.7
2.1
1.9
2.1
2.2
1.9
2.1
2.2
1.9
F orward Voltage Typ. (V)
2.3
2.8
2.4
2.8
2.4
2.8
2.8
2.8
2.4
F orward V oltage Max. (V )
7.0
7.0
16
3.8
16
2.0
1.4
2.0
16
Luminous Intensity Min. (mcd)
6.4
11.7
11.7
65
50
65
3.4
2.4
3.4
Luminous Intensity T yp. (mcd)
Luminous Intensity Max. (mcd)
660
570
592
560
P eak Wavelength (nm)
609
605
555
630
580
70
70
70
70
70
70
70
70
70
Viewing Angle 20 1/2 (degrees)
57.5
70
81
70
70
81
70
81
P ower Dissipation (mW)
70
-40 to +85 -40 to +85 -30 to +85 -30 to +85 -30 to +85 -30 to +85 -30 to +85 -30 to +85 -40 to +85
Operating Temperature (°C )
-40 to +100 -40 to +100 -40 to +100 -40 to +100 -40 to +100 -40 to +100 -40 to +100 -40 to +100 -40 to +100
S torage T emperature (°C )
60
60
100
60
P eak Forward C urrent Max. (1µs @ 10% duty cycle) (mA)
100
60
60
100
60
4
4
4
5
R everse V oltage (IR =100µA) (V )
5
4
4
5
4
5
5
5
5
Lead S older T ime @ 260°C
5
5
5
5
5
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“7017X5”相匹配的价格&库存,您可以联系我们找货
