7017X3
7017X3
    VCC
    LED ORANGE DIFFUSED 0603 SMD
7017X3 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 7017X Series Surface Mount LEDs 0603 Package Size Description and Features .063 .011 LED DIE CATHODE MARKS .031 Leading Edge LED Optoelectronic Performance • Consistent high brightness. .048 .043 .028 .008 .012 Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 4000 pieces per reel. Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. • Refer to “Solder Pad Geometry 1.pdf” .012 POLARITY MARK ANODE (+) CATHODE (-) All dimensions in inches. Electro-Optical Characteristics and Ratings 7017X7 7017X33 7017X5 7017X1 7017X23 7017X3 7017X15 7017X13 7017X21 P AR T NUMB E R Y ellow/G reen Y ellow R ed G reen Orange Orange G reen Y ellow R ed Output C olor Diffused Diffused Diffused Diffused Diffused Diffused Diffused Diffused Diffused Diffusion White C lear C lear C lear White C lear C lear C lear White P ackage C olor 20 20 20 20 20 20 20 20 20 T est C urrent (mA) 1.7 2.1 1.9 2.1 2.2 1.9 2.1 2.2 1.9 F orward Voltage Typ. (V) 2.3 2.8 2.4 2.8 2.4 2.8 2.8 2.8 2.4 F orward V oltage Max. (V ) 7.0 7.0 16 3.8 16 2.0 1.4 2.0 16 Luminous Intensity Min. (mcd) 6.4 11.7 11.7 65 50 65 3.4 2.4 3.4 Luminous Intensity T yp. (mcd) Luminous Intensity Max. (mcd) 660 570 592 560 P eak Wavelength (nm) 609 605 555 630 580 70 70 70 70 70 70 70 70 70 Viewing Angle 20 1/2 (degrees) 57.5 70 81 70 70 81 70 81 P ower Dissipation (mW) 70 -40 to +85 -40 to +85 -30 to +85 -30 to +85 -30 to +85 -30 to +85 -30 to +85 -30 to +85 -40 to +85 Operating Temperature (°C ) -40 to +100 -40 to +100 -40 to +100 -40 to +100 -40 to +100 -40 to +100 -40 to +100 -40 to +100 -40 to +100 S torage T emperature (°C ) 60 60 100 60 P eak Forward C urrent Max. (1µs @ 10% duty cycle) (mA) 100 60 60 100 60 4 4 4 5 R everse V oltage (IR =100µA) (V ) 5 4 4 5 4 5 5 5 5 Lead S older T ime @ 260°C 5 5 5 5 5 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
7017X3 价格&库存
很抱歉,暂时无法提供与“7017X3”相匹配的价格&库存,您可以联系我们找货
