2N2907A
2N2907A
    BLUEROCKET(蓝箭电子)
    TO-92-3
    通用三极管 PNP Vcbo=60V Vceo=60v Vebo=5V Ic=600mA Pc=625mW TO92
2N2907A 数据手册
2N2907A Rev.E Mar.-2016 描述 / DATA SHEET Descriptions TO-92 塑封封装 PNP 半导体三极管。Silicon PNP transistor in a TO-92 Plastic Package.  特征 / Features 低漏电流,低集电极饱和电压 Low Leakage current, Low collector saturation voltage.  用途 / Applications 用于一般放大。 General amplifier. 内部等效电路 引脚排列 12 / Equivalent Circuit / Pinning 3 PIN1:Collector 放大及印章代码 PIN 2:Base PIN 3:Emitter / hFE Classifications & Marking 见印章说明。See Marking Instructions http://www.fsbrec.com 1/6 2N2907A Rev.E Mar.-2016 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit Collector to Base Voltage VCBO -60 V Collector to Emitter Voltage VCEO -60 V Emitter to Base Voltage VEBO -5.0 V Collector Current - Continuous IC -600 mA Collector Power Dissipation PC 625 mW Junction Temperature Tj 150 ℃ Tstg -55~150 ℃ Storage Temperature Range 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Collector to Base Breakdown Voltage Collector to Emitter Breakdown Voltage Emitter to Base Breakdown Voltage Collector Cut-Off Current DC Current Gain Collector-Emitter Saturation Voltage Base-Emitter Saturation Voltage 符号 Symbol 测试条件 Test Conditions VCBO IC=-10μA IE=0 -60 V VCEO IC=-10mA IB=0 -60 V VEBO IE=-10μA IC=0 -5.0 V ICBO VCB=-50V IE=0 hFE(1)* VCE=-10V IC=-150mA 100 hFE(2)* VCE=-10V IC=-500mA 50 hFE(3) VCE=-10V IC=-10mA 100 hFE(4) VCE=-10V IC=-1.0mA 100 hFE(5) VCE=-10V IC=-0.1mA 75 VCE(sat)(1)* IC=-150mA IB=-15mA -0.4 V VCE(sat)(2)* IC=-500mA IB=-50mA -1.6 V VBE(sat)(1)* IC=-150mA IB=-15mA -1.3 V VBE(sat)(2)* IC=-500mA IB=-50mA -2.6 V VCE=-20V IC=-50mA f=100MHz VCB=-10V IE=0 Collector Output Capacitance Cob f=0.1MHz VCC=-30V Turn-On Time Ton VBE(off)=-1.5V IC=-150mA IB1=-15mA VCC=-30V IC=-150mA Turn-Off Time Toff IB1=IB2=-15mA *Pulse test: pulse width≤300μs,duty cycle≤2.0% *脉冲测试:脉宽≤300μs,占空比≤2.0% Transition Frequency http://www.fsbrec.com 最小值 典型值 最大值 单位 Min Typ Max Unit fT -0.1 μA 300 200 MHz 30 pF 0.05 μs 0.1 μs 2/6 2N2907A Rev.E Mar.-2016 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 2N2907A Rev.E Mar.-2016 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 2N2907A Rev.E Mar.-2016 印章说明 / DATA SHEET Marking Instructions BR N2907A **** 说明: BR:    为公司代码 N2907A: 为型号代码 ****: 为生产批号代码,随生产批号变化。  Note: BR: Company Code. N2907A: Product Type. ****: Lot No. Code,code change with Lot No. http://www.fsbrec.com 5/6 2N2907A Rev.E Mar.-2016 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:270±5℃ 包装规格 散件包装 Units 包装数量 Units/Bag 只/袋 Bags/Inner Box 袋/盒 Units/Inner Box 只/盒 Dimension Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Bag 袋 包装尺寸 Inner Box 盒 (unit:mm3) Outer Box 箱 1,000 10 10,000 5 50,000 135×190 237×172×102 560×245×195 1,000 10 10,000 10 100,000 135×190 237×172×102 560×245×375 Units/tape 只/纸带 Tape/Inner Box 纸带/盒 Rows/Inner Box 纸带层/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Inner Box 盒 3,000 1 120 10 30,000 328×230×42 / AMMO Package Type 封装形式 使用说明 Time:10±1 sec / BULK TO-92 TO-92 Temp:270±5℃ / Packaging SPEC. Package Type 封装形式 编带包装 时间:10±1 sec. Units 包装数量 Dimension 包装尺寸 (unit:mm3) Outer Box 箱 小箱 480×346×235, 大箱 547×407×268 / Notices http://www.fsbrec.com 6/6
2N2907A 价格&库存
很抱歉,暂时无法提供与“2N2907A”相匹配的价格&库存,您可以联系我们找货
2N2907A
    • 20+0.17218
    • 200+0.13558
    • 600+0.11525
    • 3000+0.10247
    • 9000+0.09190
    2N2907A
    库存:3000
