20D471K
20D471K
    SOCAY(硕凯)
    VAR_D23X6.7MM_TM
    压敏电阻 VAR_D23X6.7MM_TM 钳位电压:775V 峰值浪涌电流:6.5kA
20D471K 数据手册
Radial Lead Metal Oxide Varistor (MOV) 20D Series Description The 20D series radial leaded varistors provides an ideal circuit protection solution for lower DC voltage applications by offering higher surge ratings than ever before available in such small discs. The maximum peak surge current rating can reach up to 10KA (8/20 μs pulse) to protect against high peak surges, including indirect lightning strike interference, system switching transients and abnormal fast transients from the power source. Features Applications  Wide operating voltage (V1mA) range from 18V to 1800V  Fast responding to transient over-voltage  Large absorbing transient energy capability  Surge protection in consumer electronics  Low clamping ratio and no following-on current  Surge protection in industrial electronics  Meets MSL level 1, per J-STD-020  Surge protection in electronic home appliances, gas and  Transistor, diode, IC, thyristor or triac semiconductor protection petroleum appliances  Relay and electromagnetic valve surge absorption General Characteristics Material No Radioactive Material Operating Temperature -40℃ ~ +85℃ Storage Temperature -55℃ ~ +125℃ Body Nickel Plated Leads Tin Plated Devices with No lead Nickel Plated SOCAY Electronics Corp., Ltd. Revision June 23, 2017 www.socay.com 1/4 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Radial Lead Metal Oxide Varistor (MOV) 20D Series Specifications – General Characteristics (25±5℃) VAC (V) VDC (V) V1mA (V) IP (A) VC (V) 20D180K 20D180KJ 11 14 18(15~21.6) 20 36 Withstanding Maximum Typical Rated Surge Energy Capacitance Power Current (10/1000μs) (Reference) I(A) I(A) (J) @1KHZ Standard High Surge (J) High (W) Standard (pf) 1 2 1 2 Surge Time Times Time Times 2000 1000 3000 1000 11 13 0.2 28500 20D220K 20D220KJ 14 18 22(19.5~26) 20 43 2000 1000 3000 1000 14 16 0.2 18500 20D270K 20D270KJ 17 22 27(24~30) 20 53 2000 1000 3000 1000 16 19 0.2 13000 20D330K 20D330KJ 20 26 33(29.5~36.5) 20 66 2000 1000 3000 1000 23 24 0.2 11500 20D390K 20D390KJ 25 31 39(35~43) 20 77 2000 1000 3000 1000 26 28 0.2 8500 20D470K 20D470KJ 30 38 47(42~54) 20 93 2000 1000 3000 1000 30 34 0.2 7400 20D560K 20D560KJ 35 45 56(50~62) 20 100 2000 1000 3000 1000 41 41 0.2 6500 20D680K 20D680KJ 40 56 68(61~75) 20 135 2000 1000 3000 1000 46 49 0.2 5800 20D820K 20D820KJ 50 65 82(74~90) 100 135 6500 4000 10000 7000 38 56 1.0 4900 20D101K 20D101KJ 60 85 100(90~110) 100 165 6500 4000 10000 7000 45 70 1.0 4000 20D121K 20D121KJ 75 100 120(108~132) 100 200 6500 4000 10000 7000 55 85 1.0 3300 20D151K 20D151KJ 95 125 150(135~165) 100 250 6500 4000 10000 7000 70 106 1.0 2700 20D181K 20D181KJ 115 150 180(162~198) 100 300 6500 4000 10000 7000 85 130 1.0 2200 20D201K 20D201KJ 130 170 200(180~220) 100 340 6500 4000 10000 7000 95 140 1.0 2000 20D221K 20D221KJ 140 180 220(198~242) 100 360 6500 4000 10000 7000 100 155 1.0 1800 20D241K 20D241KJ 150 200 240(216~264) 100 395 6500 4000 10000 7000 108 168 1.0 1650 20D271K 20D271KJ 175 225 270(243~297) 100 455 6500 4000 10000 7000 127 190 1.0 1500 20D301K 20D301KJ 190 250 300(270~330) 100 500 6500 4000 10000 7000 136 210 1.0 1300 20D331K 20D331KJ 210 275 330(297~363) 100 550 6500 4000 10000 7000 150 228 1.0 1200 20D361K 20D361KJ 230 300 360(324~396) 100 595 6500 4000 10000 7000 163 255 1.0 1100 20D391K 20D391KJ 250 320 390(351~429) 100 650 6500 4000 10000 7000 180 275 1.0 1000 20D431K 20D431KJ 275 350 430(387~473 100 710 6500 4000 10000 7000 190 305 1.0 930 20D471K 20D471KJ 300 385 470(423~517) 100 775 6500 4000 10000 7000 220 350 1.0 850 20D511K 20D511KJ 320 415 510(459~561) 100 845 6500 4000 10000 7000 220 360 1.0 780 20D561K 20D561KJ 350 460 560(504~616) 100 925 6500 4000 10000 7000 220 380 1.0 710 20D621K 20D621KJ 385 505 620(558~682) 100 1025 6500 4000 10000 7000 220 390 1.0 650 20D681K 20D681KJ 420 560 680(612~748) 100 1120 6500 4000 10000 7000 230 400 1.0 600 20D751K 20D751KJ 460 615 750(675~825) 100 1240 6500 4000 10000 7000 255 420 1.0 530 20D781K 20D781KJ 485 640 780(702~858) 100 1290 6500 4000 10000 7000 265 440 1.0 510 20D821K 20D821KJ 510 670 820(738~902) 100 1355 6500 4000 10000 7000 282 460 1.0 500 20D911K 20D911KJ 550 745 910(819~1001) 100 1500 6500 4000 10000 7000 310 510 1.0 440 20D102K 20D102KJ 625 825 1000(900~1100) 100 1650 6500 4000 10000 7000 342 565 1.0 400 20D112K 20D112KJ 680 895 1100(990~1210) 100 1814 6500 4000 10000 7000 383 620 1.0 460 20D122K 20D122KJ 750 990 1200(1080~1320) 100 1980 6500 4000 10000 7000 408 660 1.0 320 20D152K 20D152KJ 900 1200 1500(1350~1650) 100 2475 6500 4000 10000 7000 420 660 1.0 260 20D162K 20D162KJ 1000 1280 1600(1440~1760) 100 2640 6500 4000 10000 7000 606 660 1.0 320 20D182K 20D182KJ 1000 1465 1800(1620~1980) 100 2970 6500 4000 10000 7000 625 660 1.0 320 Type Number Standard High Surge Maximum Allowable voltage Varistor Voltage Maximum Clamping Voltage SOCAY Electronics Corp., Ltd. Revision June 23, 2017 www.socay.com 2/4 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Radial Lead Metal Oxide Varistor (MOV) 20D Series Electrical Rating Item Test Condition / Description Maximum Allowable Voltage The recommended maximum sine wave voltage (RMS) or the maximum DC voltage can be applied continuously. Varistor Voltage Requirement The voltage between two terminals with the specified measuring current 1mA.DC applied is call Vb. The maximum voltage between two terminals with the specification standard impulse current. Applied waveform: 8/20μs I 1.0 0.9 Maximum Clamping Voltage To meet the specified value 0.5 0.1 0.0 8μsec 20μsec 30% Max T Rated Wattage The maximum average power that can be applied within the specified ambient temperature. Energy The maximum energy within the varistor voltage change of ±10% when one impulse of 10/1000μs. or 2 msec. is applied. Withstanding Surge Current The maximum current within the varistor voltage change of ±10% with the standard impulse current (8/20ȝsec.) applied one time Vb at 20℃-Vb at 70℃ Varistor Voltage Temp. Coefficient Vb at 20℃ × 1 50 × 100(% / ℃) 0.05% / ℃ max The change of Vb shall be measured after the impulse listed below is applied 10,000 times continuously with the interval of ten seconds at room temperature. 5D Series 7D Series Surge Life 10D Series 14D Series 20D Series 180K to 680K 100A (8/20μs) 820K to 751K 400A (8/20μs) 180K to 680K 250A (8/20μs) 820K to 821K 1200A (8/20μs) 180K to 680K 500A (8/20μs) 820K to 112K 2500A (8/20μs) 180K to 680K 1000A (8/20μs) 820K to 182K 4500A (8/20μs) 180K to 680K 2000A (8/20μs) 820K to 182K 6500A (8/20μs) SOCAY Electronics Corp., Ltd. Revision June 23, 2017 △Vb / Vb ≤ ±10% www.socay.com 3/4 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Radial Lead Metal Oxide Varistor (MOV) 20D Series Part Numbering Part Marking 20 D XXX K J J: High Surge, without: Standard Tolerance: K: ±10%, L: ±15%, M: Logo Product Type ±20% VDE Accreditation Logo UL Accreditation Logo Varistor Voltage Type: D: Disk, S: Square Element Diameter Packaging Information Part Number Quantity Packaging Option Packaging Specification 20DXXXXX 250 Plastic Bag Bulk Pack Package Dimensions Unit: mm TABLE1 TABLE2 Symbol Dimensions Model T(max.) Model T(max.) H(max.) H1(max.) L(min.) L1(min.) D(max.) P(±0.8) T(max.) d(±0.05) d1(±0.05) 27.0 27.0 15.0 15.0 23.0 7.5/10.0 TABLE2 0.8/1.0 0.8/1.0 180K 220K 270K 330K 390K 470K 560K 680K 820K 101K 121K 151K 181K 201K 221K 241K 271K 301K 4.8 4.9 5.0 5.2 5.5 5.6 5.7 5.08 4.9 5.1 5.3 5.6 5.0 5.2 5.3 5.4 5.6 5.7 331K 361K 391K 431K 471K 511K 561K 621K 681K 751K 781K 821K 911K 102K 112K 122K 182K - 5.8 6.0 6.2 6.5 6.7 6.9 7.0 7.2 7.5 8.2 5.3 8.5 9.0 9.5 10.1 10.6 13.2 - SOCAY Electronics Corp., Ltd. Revision June 23, 2017 www.socay.com 4/4 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
20D471K 价格&库存
很抱歉,暂时无法提供与“20D471K”相匹配的价格&库存,您可以联系我们找货
