20Φ Series
Metal Oxide Varistors (MOV) Data Sheet
Features
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
Operating Temperature:-40℃ ~ +105℃&-40℃ ~ +125℃
Storage Temperature:-40℃ ~ +125℃
Agency recognition: UL 1449 4th /cUL/TUV/CQC
Applications
Power supply, Telecommunication, Smart meter, or PLC protection
Surge protection in consumer electronics
Surge protection in industrial electronics
Surge protection in electronic home appliances, gas and petroleum appliances
Relay and electromagnetic valve surge absorption
Part Number Code
F
T
R
2
D
7
1
K
Tolerance
K: ±10%
Product Type
FTR Series
Type
D: Disk
Element Diameter
05:Φ 5mm
07:Φ 7mm
10:Φ 10mm
14:Φ 14mm
20:Φ 25mm
25:Φ 25mm
Revision:18-Dec-19
J
W1
Temperature Type
W1 :
Operating temperature is -40
No Suffix:
~ +125
~ +105
Varistor Voltage Surge Series
No Suffix: Standard Type
180:18x10 V
1
J: High Surge Type
271:27x10 V
2
142:14x10 V
1 / 11
www.ftrqg.com
20Φ Series
Electrical Characteristics
Maximum
Part Number
Maximum
Withstanding
Maximum
Clamping
Surge
Energy
Voltage
current
(10/1000μs)
Varistor
Allowable
Voltage
Voltage
(A)
High
Standard
(A)
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
Dimension
Power
Tmax
(W)
(mm)
(J)
(J)
High
Standard
Surge
Rated
High
Standard
Surge
Surge
FTR20D180K
FTR20D180KJ
11
14
18(15~21.6)
2000
3000
11
13
0.2
5.0
FTR20D220K
FTR20D220KJ
14
18
22(19.5~26)
2000
3000
14
16
0.2
5.0
FTR20D270K
FTR20D270KJ
17
22
27(24~31)
2000
3000
16
19
0.2
5.0
FTR20D330K
FTR20D330KJ
33(29.5~36.5)
2000
3000
23
24
0.2
5.0
FTR20D390K
FTR20D390KJ
25
31
39(35~43)
2000
3000
26
28
0.2
5.0
FTR20D470K
FTR20D470KJ
30
38
47(42~52)
2000
3000
30
34
0.2
5.0
FTR20D560K
FTR20D560KJ
35
45
56(50~62)
2000
3000
38
44
0.2
5.0
FTR20D680K
FTR20D680KJ
40
56
68(61~75)
2000
3000
41
49
0.2
5.0
FTR20D820K
FTR20D820KJ
50
65
82(74~90)
100
135
6500
10000
45
56
1.0
5.0
FTR20D101K
FTR20D101KJ
60
85
100(90~110)
100
165
6500
10000
50
70
1.0
4.6
FTR20D121K
FTR20D121KJ
75
100
120(108~132)
100
200
6500
10000
55
85
1.0
4.8
FTR20D151K
FTR20D151KJ
95
125
150(135~165)
100
250
6500
10000
70
106
1.0
4.4
FTR20D181K
FTR20D181KJ
115
150
180(162~198)
100
300
6500
10000
85
130
1.0
4.5
FTR20D201K
FTR20D201KJ
130
170
200(180~220)
100
340
6500
10000
95
140
1.0
4.6
FTR20D221K
FTR20D221KJ
140
180
220(198~242)
100
360
6500
10000
100
155
1.0
4.7
FTR20D241K
FTR20D241KJ
150
200
240(216~264)
100
395
6500
10000
108
168
1.0
4.8
FTR20D271K
FTR20D271KJ
175
225
270(243~297)
100
455
6500
10000
127
190
1.0
5.0
FTR20D301K
FTR20D301KJ
190
250
300(270~330)
100
500
6500
10000
136
210
1.0
5.0
FTR20D331K
FTR20D331KJ
210
275
330(297~363)
100
550
6500
10000
150
228
1.0
5.1
FTR20D361K
FTR20D361KJ
230
300
360(324~396)
100
595
6500
10000
163
255
1.0
5.3
FTR20D391K
FTR20D391KJ
250
320
390(351~429)
100
650
6500
10000
180
275
1.0
5.4
FTR20D431K
FTR20D431KJ
275
350
430(387~473)
100
710
6500
10000
190
305
1.0
5.6
FTR20D471K
FTR20D471KJ
300
385
470(423~517)
100
775
6500
10000
204
350
1.0
5.8
FTR20D511K
FTR20D511KJ
320
415
510(459~561)
100
845
6500
10000
210
360
1.0
6.0
FTR20D561K
FTR20D561KJ
350
460
560(504~616)
100
925
6500
10000
215
380
1.0
6.4
FTR20D621K
FTR20D621KJ
385
505
620(558~682)
100
1025
6500
10000
224
390
1.0
6.7
FTR20D681K
FTR20D681KJ
420
560
680(612~748)
100
1120
6500
10000
230
400
1.0
7.0
FTR20D751K
FTR20D751KJ
460
615
750(675~825)
100
1240
6500
10000
255
420
1.0
7.1
FTR20D781K
FTR20D781KJ
485
640
780(702~858)
100
1290
6500
10000
265
440
1.0
7.2
FTR20D821K
FTR20D821KJ
510
670
820(738~902)
100
1355
6500
10000
282
460
1.0
7.4
FTR20D911K
FTR20D911KJ
550
745
910(819~1001)
100
1500
6500
10000
310
510
1.0
7.8
FTR20D102K
FTR20D102KJ
625
825
1000(900~1100)
100
1650
6500
10000
342
565
1.0
7.8
FTR20D112K
FTR20D112KJ
680
895
1100(990~1210)
100
1815
6500
10000
383
620
1.0
8.2
FTR20D122K
FTR20D122KJ
750
990
1200(1080~1320)
100
1980
6500
10000
408
660
1.0
8.6
FTR20D142K
FTR20D142KJ
880
1140
1400(1260~1540)
100
2310
6500
10000
532
784
1.0
9.1
Revision:18-Dec-19
2 / 11
www.ftrqg.com
20Φ Series
Maximum
Maximum
Withstanding
Maximum
Clamping
Surge
Energy
Voltage
current
(10/1000μs)
Varistor
Part Number
Allowable
Voltage
Voltage
(A)
High
VAC(V)
VDC(V)
V1mA(V)
IP(A)
Power
Tmax
(W)
(mm)
(J)
VC(V)
High
High
Standard
Surge
Dimension
(J)
(A)
Standard
Rated
Standard
Surge
Surge
FTR20D162K
FTR20D162KJ
1000
1280
1600(1440~1760)
100
2640
6500
10000
606
896
1.0
10.2
FTR20D182K
FTR20D182KJ
1100
1465
1800(1620~1980)
100
2970
6500
10000
625
990
1.0
10.8
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Varistor voltage≥1200V, structure diagram is F type.
3. Leakage Current (@83% of V1mA):IR≤50μ A (180K~680K) ; IR≤25μ A (820K~182K)
Dimensions
D
T
H1
K 3.0
L
K 3.0
L1
L
K 3.0
d
T
H1
D
H
D
d
d
F
O Type
F Type
Symbol
H(max.)
H1(Max.)
L(min.)
L1(min.)
Dimension(mm)
25.5
28
D(max.) F(±0.8)
22.5
d(±0.05)
Tmax
1
Please refer to the
Electrical
Characteristics Table
10
Marking Code
① QG Logo
①
② Disk Size
FTR
XXDXXXKJ
③ UL Accreditation Logo
②
③
⑤
⑥
⑦
④
⑧
⑨
X X
④ VDE Accreditation Logo
⑤“J”is High Surge Code,No “J”is Standard Surge
⑥ Varistor Voltage
⑦ CQC Accreditation Logo
⑧ TUV Accreditation Logo
⑨ Date Code
Revision:18-Dec-19
3 / 11
www.ftrqg.com
20Φ Series
Electrical Ratings
Items
Varistor Voltage
Maximum Allowable
Voltage
Test Condition/Description
Requirement
The voltage between two terminals with the specified measuring
current 1mA.DC applied is called Vb.
The recommended maximum sine wave voltage (RMS) or the
Maximum DC voltage can be applied continuously.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
Crest value
Maximum Clamping
Voltage
Current (%)
100
90
To meet the
Specified value
50
20µs
10
8µs
Time
Impulse Width
Rated Wattage
The maximum average power that can be applied within the
specified ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10%
when one impulse of 10/1000μs or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10%
with the standard impulse current (8/20μs) applied one time.
V1mA@85℃-V1mA@25℃
Varistor Voltage
Temp. Coefficient
V1mA@25℃
1
× 100%(%/℃)
60
≤0.05%/℃
V1mA@-40℃-V1mA@25℃
V1mA@25℃
1
× 100%(%/℃)
65
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
Surge Life
20Φ series
Revision:18-Dec-19
180K to 680K
100A (8/20μs)
820K to 182K
200A (8/20μs)
4 / 11
ΔVb
≤ ±10%
Vb
www.ftrqg.com
20Φ Series
Mechanical Characteristics
Items
Test conditions / Methods
Specifications
Tensile Strength
of Terminals
Gradually applying the force specified and keeping the unit fixed
for 10±1 sec.
Terminal diameter (mm)
Froce(kg)
0.5
很抱歉,暂时无法提供与“FTR20D471K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.20874
- 50+0.96552
- 200+0.83646
- 400+0.70643
- 2400+0.64854
- 5000+0.61377
