7Φ Series
Metal Oxide Varistors (MOV) Data Sheet
Features
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
Operating Temperature:-40℃ ~ +105℃&-40℃ ~ +125℃
Storage Temperature:-40℃ ~ +125℃
Agency recognition: UL 1449 4th /cUL/TUV/VDE/CQC
Applications
Power supply, Telecommunication, Smart meter, or PLC protection
Surge protection in consumer electronics
Surge protection in industrial electronics
Surge protection in electronic home appliances, gas and petroleum appliances
Relay and electromagnetic valve surge absorption
Part Number Code
F
T
R
2
D
7
1
K
Tolerance
K: ±10%
Product Type
FTR Series
Type
D: Disk
Element Diameter
05:Φ 5mm
07:Φ 7mm
10:Φ 10mm
14:Φ 14mm
20:Φ 25mm
25:Φ 25mm
Revision:18-Dec-19
J
W1
Temperature Type
W1 :
Operating temperature is -40
No Suffix:
~ +125
~ +105
Varistor Voltage Surge Series
No Suffix: Standard Type
180:18x10 V
1
J: High Surge Type
271:27x10 V
2
142:14x10 V
1 / 11
www.ftrqg.com
7Φ Series
Electrical Characteristics
Maximum
Part Number
Maximum
Withstanding
Maximum
Clamping
Surge
Energy
Voltage
current
(10/1000μs)
Varistor
Allowable
Voltage
Voltage
(A)
High
Standard
(A)
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
Dimension
Power
Tmax
(W)
(mm)
(J)
(J)
High
Standard
Surge
Rated
High
Standard
Surge
Surge
FTR07D180K
FTR07D180KJ
11
14
18(15~21.6)
2.5
36
250
500
0.9
2
0.02
5.0
FTR07D220K
FTR07D220KJ
14
18
22(19.5~26)
2.5
43
250
500
1.1
2.4
0.02
5.0
FTR07D270K
FTR07D270KJ
17
22
27(24~31)
2.5
53
250
500
1.4
3
0.02
5.0
FTR07D330K
FTR07D330KJ
33(29.5~36.5)
2.5
65
250
500
1.7
3.5
0.02
5.0
FTR07D390K
FTR07D390KJ
25
31
39(35~43)
2.5
77
250
500
2.1
4
0.02
5.0
FTR07D470K
FTR07D470KJ
30
38
47(42~52)
2.5
93
250
500
2.5
5
0.02
5.0
FTR07D560K
FTR07D560KJ
35
45
56(50~62)
2.5
110
250
500
3.1
6
0.02
5.0
FTR07D680K
FTR07D680KJ
40
56
68(61~75)
2.5
135
250
500
3.6
7
0.02
5.0
FTR07D820K
FTR07D820KJ
50
65
82(74~90)
10
135
1200
1750
5
10
0.25
5.0
FTR07D101K
FTR07D101KJ
60
85
100(90~110)
10
165
1200
1750
6.5
12
0.25
3.8
FTR07D121K
FTR07D121KJ
75
100
120(108~132)
10
200
1200
1750
7.8
13
0.25
4.0
FTR07D151K
FTR07D151KJ
95
125
150(135~165)
10
250
1200
1750
9.7
15
0.25
3.6
FTR07D181K
FTR07D181KJ
115
150
180(162~198)
10
300
1200
1750
11.7
16
0.25
3.7
FTR07D201K
FTR07D201KJ
130
170
200(180~220)
10
340
1200
1750
13
17
0.25
3.8
FTR07D221K
FTR07D221KJ
140
180
220(198~242)
10
360
1200
1750
14
19
0.25
3.9
FTR07D241K
FTR07D241KJ
150
200
240(216~264)
10
395
1200
1750
15
21
0.25
4.0
FTR07D271K
FTR07D271KJ
175
225
270(243~297)
10
455
1200
1750
18
24
0.25
4.2
FTR07D301K
FTR07D301KJ
190
250
300(270~330)
10
500
1200
1750
0.25
4.3
FTR07D331K
FTR07D331KJ
210
275
330(297~363)
10
550
1200
1750
23
28
0.25
4.3
FTR07D361K
FTR07D361KJ
230
300
360(324~396)
10
595
1200
1750
24
32
0.25
4.5
FTR07D391K
FTR07D391KJ
250
320
390(351~429)
10
650
1200
1750
26
35
0.25
4.6
FTR07D431K
FTR07D431KJ
275
350
430(387~473)
10
710
1200
1750
28
40
0.25
4.8
FTR07D471K
FTR07D471KJ
300
385
470(423~517)
10
775
1200
1750
29
42
0.25
5.0
FTR07D511K
FTR07D511KJ
320
415
510(459~561)
10
845
1200
1750
31
45
0.25
5.2
FTR07D561K
FTR07D561KJ
350
460
560(504~616)
10
925
1200
1750
35
49
0.25
5.4
FTR07D621K
FTR07D621KJ
385
505
620(558~682)
10
1025
1200
1750
38
55
0.25
5.7
FTR07D681K
FTR07D681KJ
420
560
680(612~748)
10
1120
1200
1750
42
60
0.25
6.0
FTR07D751K
FTR07D751KJ
460
615
750(675~825)
10
1240
1200
1750
45
64
0.25
6.1
FTR07D781K
FTR07D781KJ
485
640
780(702~858)
10
1290
1200
1750
48
69
0.25
6.2
FTR07D821K
FTR07D821KJ
510
670
820(738~902)
10
1355
1200
1750
52
73
0.25
6.4
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) ; IR≤25μA (820K~112K)
Revision:18-Dec-19
2 / 11
www.ftrqg.com
7Φ Series
Dimensions
D
T
H1
K 3.0
L
K 3.0
L1
L
K 3.0
d
T
H1
D
H
D
d
d
F
O Type
Symbol
H(max.)
Dimension(mm)
H1(Max.)
11.5
13
F Type
L(min.)
L1(min.)
D(max.) F(±0.8)
15
9
d(±0.05)
Tmax
0.6
Please refer to the
Electrical
Characteristics Table
5
Marking Code
① QG Logo
①
② Disk Size
FTR
XXDXXXKJ
③ UL Accreditation Logo
②
③
⑤
⑥
⑦
④
⑧
⑨
X X
④ VDE Accreditation Logo
⑤“J”is High Surge Code,No “J”is Standard Surge
⑥ Varistor Voltage
⑦ CQC Accreditation Logo
⑧ TUV Accreditation Logo
⑨ Date Code
Revision:18-Dec-19
3 / 11
www.ftrqg.com
7Φ Series
Electrical Ratings
Items
Varistor Voltage
Maximum Allowable
Voltage
Test Condition/Description
Requirement
The voltage between two terminals with the specified measuring
current 1mA.DC applied is called Vb.
The recommended maximum sine wave voltage (RMS) or the
Maximum DC voltage can be applied continuously.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
Crest value
Maximum Clamping
Voltage
Current (%)
100
90
To meet the
Specified value
50
20µs
10
8µs
Time
Impulse Width
Rated Wattage
The maximum average power that can be applied within the
specified ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10%
when one impulse of 10/1000μs or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10%
with the standard impulse current (8/20μs) applied one time.
V1mA@85℃-V1mA@25℃
Varistor Voltage
Temp. Coefficient
V1mA@25℃
1
× 100%(%/℃)
60
≤0.05%/℃
V1mA@-40℃-V1mA@25℃
V1mA@25℃
1
× 100%(%/℃)
65
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
Surge Life
7Φ series
Revision:18-Dec-19
180K to 680K
25A (8/20μs)
820K to 112K
60A (8/20μs)
4 / 11
ΔVb
≤ ±10%
Vb
www.ftrqg.com
7Φ Series
Mechanical Characteristics
Items
Test conditions / Methods
Specifications
Tensile Strength
of Terminals
Gradually applying the force specified and keeping the unit fixed
for 10±1 sec.
Terminal diameter (mm)
Froce(kg)
0.5
很抱歉,暂时无法提供与“FTR07D471K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18622
- 200+0.14880
- 1000+0.12443
- 2000+0.11196
- 10000+0.10116
- 20000+0.09532
