Surface Mount Transient Voltage Suppressors (TVS)
SMBJ Series
5.0 To 440 V
600W
Description
Uni-directional
Bi-directional
The SMBJ series is designed specifically to protect sensitive electronic
equipment from voltage transients induced by lightning and other transient
voltage events.
Features
For surface mounted applications in order to optimize board space
Low leakage
Uni and Bidirectional unit
Glass passivated junction
Low inductance
Excellent clamping capability
600W Peak power capability at 10 × 1000µs waveform Repetition rate
(duty cycle):0.01%
Fast response time: typically less than 1.0ps from 0 Volts to VBR min
Typical IR less than 5μA above 12V.
High Temperature soldering: 260°C/40 seconds at terminals
Typical maximum temperature coefficient ΔVBR = 0.1% ×
VBR@25°C× ΔT
Plastic package has Underwriters Laboratory Flammability 94V-0
Matte tin lead–free Plated
Halogen free and RoHS compliant
Typical failure mode is short from over-specified voltage or current
Whisker test is conducted based on JEDEC JESD201A per its table
4a and 4c
IEC-61000-4-2 ESD 15kV(Air), 8kV (Contact)
ESD protection of data lines in accordance with IEC 61000-4-2
(IEC801-2)
EFT protection of data lines in accordance with IEC 61000-4-4
(IEC801-4)
Functional Diagram
Bi-directional
Cathode
Anode
Uni-direction
Agency Approvals
AGENCY
AGENCY FILE NUMBER
E341027
Applications
TVS devices are ideal for the protection of I/O interfaces,
VCC bus and other vulnerable circuits used in Telecom,
Computer, Industrial and Consumer electronic applications.
Maximum Ratings
(TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Peak Pulse Power Dissipation with a 10/1000µs waveform (Fig.1)(Note
1), (Note 2)
PPPM
600
Watts
Amps
Peak Pulse Current with a 10/1000µs waveform.(Note1,Fig.3)
IPP
See Next Table
PM(AV)
5.0
Watt
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3)
IFSM
100
Amps
Maximum Instantaneous Forward Voltage at 25A for Unidirectional Only
(Note 4)
VF
3.5/5.0
Voltage
TJ , TSTG
-55 to +150
Power Dissipation on Infinite Heat Sink at TL=75°C
Operating junction and Storage Temperature Range.
Notes:
1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25℃ per Fig. 2.
2. Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum.
4. VF < 3.5V for VBR < 200V and VF< 6.5V for VBR > 201V.
SOCAY Electronics Corp., Ltd.
Revision March 28, 2017
www.socay.com
1/7
@ SOCAY Electronics Corp., Ltd. 2017
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
SMBJ Series
5.0 To 440 V
600W
Electrical Characteristics (TA=25℃ unless otherwise noted)
Part Number
Marking
Uni
Bi
Uni
Bi
SMBJ5.0A
SMBJ5.0CA
KE
AE
Reverse
Stand-Off
Voltage
VRWM (V)
Breakdown
Voltage VBR (V)
@IT
Test
Current
IT
(mA)
Maximum
Clamping
Voltage
VC
@IPP (V)
Maximum
Peak
Pulse
Current
IPP (A)
Maximum
Reverse
Leakage IR
@VRWM
(μA)
MIN
MAX
5.0
6.40
7.00
10
9.2
65.22
800
6.67
7.37
10
10.3
58.25
800
SMBJ6.0A
SMBJ6.0CA
KG
AG
6.0
SMBJ6.5A
SMBJ6.5CA
KK
AK
6.5
7.22
7.98
10
11.2
53.57
500
SMBJ7.0A
SMBJ7.0CA
KM
AM
7.0
7.78
8.60
10
12.0
50.00
200
SMBJ7.5A
SMBJ7.5CA
KP
AP
7.5
8.33
9.21
1
12.9
46.51
100
8.89
9.83
1
13.6
44.12
50
SMBJ8.0A
SMBJ8.0CA
KR
AR
8.0
SMBJ8.5A
SMBJ8.5CA
KT
AT
8.5
9.44
10.40
1
14.4
41.67
10
SMBJ9.0A
SMBJ9.0CA
KV
AV
9.0
10.00
11.10
1
15.4
38.96
5
SMBJ10A
SMBJ10CA
KX
AX
10.0
11.10
12.30
1
17.0
35.29
5
SMBJ11A
SMBJ11CA
KZ
WZ
11.0
12.20
13.50
1
18.2
32.97
5
SMBJ12A
SMBJ12CA
LE
BE
12.0
13.30
14.70
1
19.9
30.15
5
SMBJ13A
SMBJ13CA
LG
BG
13.0
14.40
15.90
1
21.5
27.91
5
SMBJ14A
SMBJ14CA
LK
BK
14.0
15.60
17.20
1
23.2
25.86
5
SMBJ15A
SMBJ15CA
LM
BM
15.0
16.70
18.50
1
24.4
24.59
5
SMBJ16A
SMBJ16CA
LP
BP
16.0
17.80
19.70
1
26.0
23.08
5
SMBJ17A
SMBJ17CA
LR
BR
17.0
18.90
20.90
1
27.6
21.74
5
SMBJ18A
SMBJ18CA
LT
BT
18.0
20.00
22.10
1
29.2
20.55
5
SMBJ19A
SMBJ19CA
LB
BB
19.0
21.10
23.30
1
30.8
19.49
5
SMBJ20A
SMBJ20CA
LV
BV
20.0
22.20
24.50
1
32.4
18.52
5
SMBJ22A
SMBJ22CA
LX
BX
22.0
24.40
26.90
1
35.5
16.90
5
SMBJ24A
SMBJ24CA
LZ
BZ
24.0
26.70
29.50
1
38.9
15.42
5
SMBJ26A
SMBJ26CA
ME
CE
26.0
28.90
31.90
1
42.1
14.25
5
SMBJ28A
SMBJ28CA
MG
CG
28.0
31.10
34.40
1
45.4
13.22
5
SMBJ30A
SMBJ30CA
MK
CK
30.0
33.30
36.80
1
48.4
12.40
5
SMBJ33A
SMBJ33CA
MM
CM
33.0
36.70
40.60
1
53.3
11.26
5
SMBJ36A
SMBJ36CA
MP
CP
36.0
40.00
44.20
1
58.1
10.33
5
SMBJ40A
SMBJ40CA
MR
CR
40.0
44.40
49.10
1
64.5
9.30
5
SMBJ43A
SMBJ43CA
MT
CT
43.0
47.80
52.80
1
69.4
8.65
5
www.socay.com
2/7
SMBJ Series
5.0 To 440 V
600W
(TA=25℃ unless otherwise noted) (Continue)
Uni
Bi
Uni
Bi
Reverse
Stand-Off
Voltage
VRWM (V)
SMBJ45A
SMBJ45CA
MV
CV
SMBJ48A
SMBJ48CA
MX
SMBJ51A
SMBJ51CA
SMBJ54A
Breakdown
Voltage VBR (V)
@IT
Maximum
Clamping
Voltage
VC
@IPP (V)
Maximum
Peak
Pulse
Current
IPP (A)
Maximum
Reverse
Leakage IR
@VRWM
(μA)
MIN
MAX
Test
Current
IT
(mA)
45.0
50.00
55.30
1
72.7
8.25
5
CX
48.0
53.30
58.90
1
77.4
7.75
5
MZ
CZ
51.0
56.70
62.70
1
82.4
7.28
5
SMBJ54CA
NE
DE
54.0
60.00
66.30
1
87.1
6.89
5
SMBJ58A
SMBJ58CA
NG
DG
58.0
64.40
71.20
1
93.6
6.41
5
SMBJ60A
SMBJ60CA
NK
DK
60.0
66.70
73.70
1
96.8
6.20
5
SMBJ64A
SMBJ64CA
NM
DM
64.0
71.10
78.60
1
103.0
5.83
5
SMBJ70A
SMBJ70CA
NP
DP
70.0
77.80
86.00
1
113.0
5.31
5
SMBJ75A
SMBJ75CA
NR
DR
75.0
83.30
92.10
1
121.0
4.96
5
SMBJ78A
SMBJ78CA
NT
DT
78.0
86.70
95.80
1
126.0
4.76
5
SMBJ80A
SMBJ80CA
NB
DB
80.0
88.80
97.60
1
129.6
4.63
5
SMBJ85A
SMBJ85CA
NV
DV
85.0
94.40
104.00
1
137.0
4.38
5
SMBJ90A
SMBJ90CA
NX
DX
90.0
100.00
111.00
1
146.0
4.11
5
SMBJ100A
SMBJ100CA
NZ
DZ
100.0
111.00
123.00
1
162.0
3.70
5
SMBJ110A
SMBJ110CA
PE
EE
110.0
122.00
135.00
1
177.0
3.39
5
SMBJ120A
SMBJ120CA
PG
EG
120.0
133.00
147.00
1
193.0
3.11
5
SMBJ130A
SMBJ130CA
PK
EK
130.0
144.00
159.00
1
209.0
2.87
5
SMBJ140A
SMBJ140CA
PB
EB
140.0
155.00
171.00
1
226.8
2.65
5
SMBJ150A
SMBJ150CA
PM
EM
150.0
167.00
185.00
1
243.0
2.47
5
SMBJ160A
SMBJ160CA
PP
EP
160.0
178.00
197.00
1
259.0
2.32
5
SMBJ170A
SMBJ170CA
PR
ER
170.0
189.00
209.00
1
275.0
2.18
5
SMBJ180A
SMBJ180CA
PT
ET
180.0
201.00
220.00
1
291.6
2.06
5
SMBJ190A
SMBJ190CA
PV
EV
190.0
211.00
232.00
1
307.8
1.95
5
SMBJ200A
SMBJ200CA
PW
EW
200.0
224.00
247.00
1
324.0
1.85
5
SMBJ220A
SMBJ220CA
PX
EX
220.0
246.00
272.00
1
356.0
1.69
5
SMBJ250A
SMBJ250CA
PZ
EZ
250.0
279.00
309.00
1
405.0
1.48
5
SMBJ300A
SMBJ300CA
QE
FE
300.0
335.00
371.00
1
486.0
1.23
5
SMBJ350A
SMBJ350CA
QG
FG
350.0
391.00
432.00
1
567.0
1.06
5
SMBJ400A
SMBJ400CA
QK
FK
400.0
447.00
494.00
1
648.0
0.93
5
SMBJ440A
SMBJ440CA
QM
FM
440.0
492.00
543.00
1
713.0
0.84
5
Part Number
Marking
Note:
1. Suffix 'A ' denotes 5% tolerance device.
2. Add suffix ' CA ' after part number to specify Bi-directional devices.
3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is double.
www.socay.com
3/7
SMBJ Series
5.0 To 440 V
600W
Ratings and Characteristic Curves (TA=25°C unless otherwise noted)
Figure 1 - Peak Pulse Power Rating Curve
Figure 2 - Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power
(kW)
10
10
1
0.1
0.1
1
10
100
td - Pulse Width (μs)
1000
60
40
50
75
100
125
TA-Ambient temperature(°C)
150
175
Figure 4 - Typical Junction Capacitance
10000
150
tr=10µsec
Bi-directional
@zero bins
TJ=25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
Peak Value
IPPM
Uni-directional
@zero bins
1000
100
Cj (pF)
IPPM - Peak Pulse Current, % IRSM
80
10000
Figure 3 - Pulse Waveform
Half Value
IPPM (IPPM/2)
50
tc
t - Time (ms)
3.0
4.0
1.0
IFSM-Peak Forward Surge Current
(A)
4.0
3.0
2.0
1.0
25
50
75
100
125
150
175
100.0
1000.0
TJ=TJ max.
8.3 ms Single Half Sine-Wave
80
60
40
TL - Lead Temperature(°C)
10.0
Figure 6 - Maximum Non-Repetitive Surge Current
100
Bi-directional @VRWM
VBR-Reverse Breakdown Voltage (V)
5.0
0.0
Tj=25°C
f=1.0MHz
Vsig=50mVp-p
1
1.0
Uni-directional @VRWM
100
10/1000µsec. Waveform
as defined by R.E.A
Figure 5 - Steady State Power Derating Curve
PM(AV), Steady State Power Dissipation (W)
100
1
10
Number of Cycles at 60Hz
100
www.socay.com
4/7
SMBJ Series
5.0 To 440 V
600W
I-V Curve Characteristics
Uni-directional
Bi-directional
I
I
IPP
IF
VC
V
VBR VRW
R M
VF
IT
IPP
VC
C
r
i
t
i
c
a
l
IR
IT
IT
V
IR
VRW VBR VC
R
M
IPP
Z
o
n
e
T
Physical Specifications
VBR VRW
R M
Environmental Specifications
L
Weight
0.003 ounce, 0.093 gram
Case
JEDEC DO-214AA Molded Plastic over
T
glass passivated junction
t
o
P
Color band denotes cathode except
Bipolar
Matte Tin-plated leads, Solderable per
JESD22-B102D
Polarity
Terminal
Temperature Cycle
JESD22-A104
Pressure Cooker
JESD22-A102
High Temp. Storage
JESD22-A103
HTRB
JESD22-A108
Thermal Shock
JESD22-A106
Soldering Parameters
Reflow Condition
Pre Heat
TP
Ramp-up
TL
Critical Zone
TL to TP
Temperature
TS(max)
Ramp-down
TS(min)
25
-Temperature Min (Ts(min))
150°C
-Temperature Max (Ts(max))
200°C
- Time (min to max) (Ts)
60 -180 Seconds
Average ramp up rate ( Liquidus Temp TL)
to peak
3°C/second max
TS(max) to TL - Ramp-up Rate
3°C/second max
Reflow
Preheat
Lead–free assembly
- Temperature (TL) (Liquidus)
217°C
- Time (min to max) (TL)
60 -150 Seconds
Peak Temperature (TP)
Time to peak temperature
(t 25℃ to peak)
Time
Time within 5°C
Temperature (tp)
260 +0/-5°C
of
actual
peak
20 -40 Seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max
Do not exceed
280°C
www.socay.com
5/7
SMBJ Series
5.0 To 440 V
600W
Dimensions
Dimensions
DO-214AA (SMB)
Cathode Band
Part Numbering
Inches
Millimeters
Min
Max
Min
Max
A
0.073
0.087
1.85
2.21
B
0.167
0.187
4.25
4.75
C
0.130
0.155
3.30
3.94
D
0.083
0.096
2.11
2.44
E
0.030
0.060
0.76
1.52
F
0.002
0.008
0.051
0.203
G
0.200
0.220
5.08
5.59
H
0.006
0.012
0.15
0.31
I
0.090
2.40
J
0.085
2.10
K
0.100
2.60
L
0.085
2.10
Part Marking
SMBJ×××CA
Socay Logo
5% VBR VOLTAGE TOLERANCE
BI-DIRECTIONAL
VR VOLTAGE
Cathode Band
SERIES
Marking Code
www.socay.com
6/7
SMBJ Series
5.0 To 440 V
600W
Packaging
Part Number
Component
Package
Quantity
Packaging Option
Reel Diameters
(mm)
SMBJXXXXX
DO-214AA (SMB)
500 pcs
Tape & Reel -12mm/7″tape
177.8
SMBJXXXXX
DO-214AA (SMB)
3000 pcs
Tape & Reel -12mm/13″tape
330.0
Tape and Reel Specifications
7.0/13.0
(177.8/330.0)
0.157
(4.0)
0.059 Diameter
(1.5)
0.472
(12.0)
0.36
(9.2)
0.512(13.0)
Arbor Hole Diameter
0.315
(8.0)
0.49
(12.4)
Cover tape
Direction of Feed
Dimensions are in inches
(and millimeters)
www.socay.com
7/7
很抱歉,暂时无法提供与“SMBJ250CA”相匹配的价格&库存,您可以联系我们找货
