SS22 THRU SS2200
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 200 Volts
FEATURES
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
0.110(2.80)
0.100(2.54)
0.067 (1.70)
0.051 (1.30)
Forward Current - 2.0 Amperes
0.181(4.60)
0.157(3.99)
0.012(0.305)
0.006(0.152)
0.096(2.42)
0.078(1.98)
MECHANICAL DATA
0.060(1.52)
0.030(0.76)
Case: JEDEC DO-214AC molded plastic body
Terminals: leads solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.070 grams
0.008(0.203)MAX.
0.222(5.66)
0.194(4.93)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 2.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SYMBOLS SS22 SS23
VRRM
VRMS
VDC
21
30
SS24 SS25 SS26 SS28 SS210 SS2150SS2200 UNITS
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
VOLTS
VOLTS
VOLTS
I(AV)
2.0
Amps
IFSM
50.0
Amps
VF
0.55
IR
CJ
RθJA
TJ,
TSTG
0.70
0.85
0.5
10.0
5.0
180
220
75.0
-65 to +125
-65 to +150
-65 to +150
0.95
0.2
2.0
Volts
mA
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
2014-03 01版
http://www.microdiode.com
FIG. 1- FORWARD CURRENT DERATING CURVE
2.0
1.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
0.8
SS22-SS26
SS28-SS2200
0.4
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES SS22 THRU SS2200
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
50
40
30
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
50
INSTANTANEOUS FORWARD
CURRENT,AMPERES
TJ=25 C
10.0
1
SS22-SS24
SS25-SS26
SS28-SS2150
SS2200
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.2
0.4
0.6
0.8
1.0
1.2
1.4
60
80
100
1.6
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
PERCENT OF PEAK REVERSE VOLTAGE,%
1000
TJ=25 C
100
SS22-SS24
SS25-SS2200
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
2014-03 01版
100
t,PULSE DURATION,sec.
很抱歉,暂时无法提供与“SS22-SMA”相匹配的价格&库存,您可以联系我们找货
