HX2302(3A)
HX2302(3A)
    HX(恒佳兴)
    SOT-23
    N沟道 VDS=20V VGS=±12V ID=3A P=1W SOT23
HX2302(3A) 数据手册
SOT-23 Plastic-Encapsulate Transistors HX2302 MOSFET(N-Channel) FEATURES TrenchFET Power MOSFET MARKING: A2SHB MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Value Units VDS Symbol Drain-Source voltage Parameter 20 V VGS Gate-Source voltage ±12 V ID Drain current 2.5 A PD Power Dissipation 0.9 W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃unless otherwise specified) Parameter Symbol Test conditions MIN Drain-Source Breakdown Voltage V(BR)DSS VGS=0V,ID=250uA 20 Gate-Threshold Voltage 0.5 Vth(GS) VDS= VGS, ID=250 uA Gate-body Leakage IGSS VDS=0V, VGS=±10V Zero Gate Voltage Drain Current IDSS VDS=20V, VGS=0V Drain-Source On-Resistance rDS(ON) Forward Trans conductance gfs TYP MAX UNIT V 0.75 1.2 V ±100 nA 1 uA VGS=2.5V, ID=2A 58 82 mΩ VGS=4.5V, ID=2.5A 43 59 mΩ VDS=5V, ID=2.9A 9.5 s Dynamic Characteristics Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss 280 VDS=10V, VGS=0V, f=1MHz pF 60 40 Switching Capacitance Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time 6 VDD=10V, ID=2.5A, VGS=4.5V RGEN=2.8Ω tf Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd VDS=10V, ID=2.5A, VGS=4.5V, nS 5 nS 9 nS 1.5 nS 1.7 nC 0.3 nC 0.8 nC Drain-Source Diode Characteristics Diode Forward Voltage VSD Diode Forward Current Is VGS=0V, IS=2.5A 1.2 V 2.5 A 1/2 Typical Characteristics SI2302 2/2
HX2302(3A) 价格&库存
很抱歉,暂时无法提供与“HX2302(3A)”相匹配的价格&库存,您可以联系我们找货
HX2302(3A)
