S9014
S9014
    TK(通科)
    SOT-23
    NPN Ic=100mA Vceo=45V hfe=200~1000 fT=150MHz P=200mW
S9014 数据手册
东莞市通科电子有限公司 S9014 DongGuan Tongke Electronic Co.,LTD TRANSISTOR (NPN) SOT-23 Plastic-Encapsulate Transistors SOT-23 FEATURES z Complementary to S9015 1. BASE 2. EMITTER 3. COLLECTOR MARKING: J6 MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage 50 V VCEO Collector-Emitter Voltage 45 V VEBO Emitter-Base Voltage 5 V IC Collector Current 100 mA PC Collector Power Dissipation 200 mW Thermal Resistance From Junction To Ambient 625 ℃/W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ RΘJA ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Test conditions Min Typ Collector-base breakdown voltage V(BR)CBO IC= 100μA, IE=0 50 V Collector-emitter breakdown voltage V(BR)CEO IC= 0.1mA, IB=0 45 V Emitter-base breakdown voltage V(BR)EBO IE=100μA, IC=0 5 V Collector cut-off current ICBO VCB=50 V , IE=0 0.1 μA Collector cut-off current ICEO VCE=35V , IB=0 1 μA Emitter cut-off current IEBO VEB= 3V , IC=0 0.1 μA DC current gain hFE VCE=5V, IC= 1mA 200 Max Unit 1000 Collector-emitter saturation voltage VCE(sat) IC=100 mA, IB= 5mA 0.3 V Base-emitter saturation voltage VBE(sat) IC=100 mA, IB= 5mA 1 V fT Transition frequency VCE=5V, IC= 10mA f=30MHz 150 MHz CLASSIFICATION OF hFE Rank Range L H 200-450 450-1000 1 A,Jun,2014 www.tongke888.com 400-6922-883 Typical Characteristics S9014 hFE Static Characteristic 8 1000 Ta=100℃ 18uA Ta=25℃ hFE 16uA DC CURRENT GAIN (mA) 20uA 6 IC COLLECTOR CURRENT COMMON EMITTER Ta=25℃ 14uA 4 12uA 10uA 8uA 2 —— IC 6uA 100 4uA COMMON EMITTER VCE= 5V IB=2uA 0 0 2 6 4 COLLECTOR-EMITTER VOLTAGE VCEsat —— 1 (V) 10 COLLECTOR CURRENT IC VBEsat —— IC 100 (mA) IC 2 1 0.1 Ta=25℃ BASE-EMITTER SATURATION VOLTAGE VBEsat (V) COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (V) 1 VCE 10 0.1 8 Ta=100℃ Ta=25℃ Ta=100℃ β=20 β=20 0.01 0.1 1 10 COLLECTOR CURRENT IC (mA) 10 COLLECTOR CURRENT —— VBE fT 1000 Ta=25℃ 1 COMMON EMITTER VCE= 5V 0.1 0.0 0.6 0.3 0.9 fT Ta=100℃ 10 100 TRANSITION FREQUENCY (mA) IC COLLECTOR CURRENT 1 IC 100 (mA) —— IC (MHz) 100 IC 0.1 0.1 100 10 COMMON EMITTER VCE=5V Ta=25℃ 1 0.1 1.2 1 BASE-EMMITER VOLTAGE VBE (V) 100 Cob/ Cib —— 10 COLLECTOR CURRENT VCB/ VEB PC 250 —— IC 100 (mA) Ta f=1MHz IE=0/IC=0 COLLECTOR POWER DISSIPATION PC (mW) Cib 10 CAPACITANCE C (pF) Ta=25 ℃ Cob 1 0.1 0.1 1 REVERSE VOLTAGE www.cj-elec.com 10 VR 200 150 100 50 0 20 0 (V) 25 50 75 AMBIENT TEMPERATURE 2 125 100 Ta 150 (℃ ) www.tongke888.com 400-6922-883 SOT-23 Package Outline Dimensions Symbol A A1 A2 b c D E E1 e e1 L L1 θ Dimensions In Millimeters Min Max 0.900 1.150 0.000 0.100 0.900 1.050 0.300 0.500 0.080 0.150 2.800 3.000 1.200 1.400 2.250 2.550 0.950 TYP 1.800 2.000 0.550 REF 0.300 0.500 0° 8° Dimensions In Inches Min Max 0.035 0.045 0.000 0.004 0.035 0.041 0.012 0.020 0.003 0.006 0.110 0.118 0.047 0.055 0.089 0.100 0.037 TYP 0.071 0.079 0.022 REF 0.012 0.020 0° 8° SOT-23 Suggested Pad Layout www.cj-elec.com 3 www.tongke888.com 400-6922-883
S9014 价格&库存
很抱歉,暂时无法提供与“S9014”相匹配的价格&库存,您可以联系我们找货
