客户
CUSTOMER
品名
PART NAME
天泰料号
TENTA Material Number
客户料号
CUSTOMER Material Number
编制/Edition
检查/Checked
确认/Confirmed
陆伟
徐志钦
廖小春
承认/Admit
审核/Auditing
批准/Approved
天泰電機工業有限公司
TENTA ELECTRIC INDUSTRIAL CO., LTD.
台中縣梧棲区自強二街 86 巷 61 號
NO.61, Lane 86, Tzchiang 2st St. Wu-Chi Township, Taichung County 435, TAIWAN R.O.C
TEL:(886-04)26398618 FAX:(886-04)26392549
深圳天泰電器元件有限公司
SHEN ZHEN TENTA ELECTRICAL APPLIANCE LTD.
公司:深圳市南山區白石洲中國原子能第二工業區第二棟六樓
6/F NO.2, Pirector Atom 2th Industry, Baishizhou , Shenzhen, CHINA
TEL:(0755)86327963、26921158 FAX:(0755)86297411
工厂:深圳市寶安區福永街道橋頭社區富橋第四工業區 A5 棟
No.A5,FU Qiao 4th Industrial area,Qiaotou Community,Fuyong Street,Bao An District,Shen Zhen
TEL:(0755)29604898 FAX:(0755)29604891
Y2-Class Film Capacitor, TYPE-MEY
SPECIFICATION:
1. REFERENCE STANDARDS:
VDE
DIN EN132400(1999-06)/IEC 60384-14: 1993-07, Table II + A1:1995-06
NEMKO IEC 384-14(ed.3)
DEMKO DIN EN 132 400 1994/A2:1991+A3:1998dan IEC60384-14 1993+A:1995
SEMKO DIN EN 132 400 1994/A2:1998+A3:1998/IEC60384-14.Second edition:1993/A1:1995
FIMKO DIN EN 60384-14:2005
UL (250V/275V AC)
USED FOR ACROSS-THE-LINE CAPACITORS,
ANDTENNA-COUPLINE,
LINE-BY-PASS COMPONENTS,
RADIO INTERFERENCE SUPPRESSION,
ELECTRONMAGNETIC INTERFERENCE FILTERS.
2. RATED VOLTAGE:
275V AC
50/ 60 Hz
3. CAPACITANCE RANGE:
0.001µF to 0.1 µF
4. CAPACITANCE TOLERANCE:
± 5% (J) ± 10% (K)
± 20% (M)
5. DIELECTRIC:
METALLIZED
POLYPROPYLENE
FILM
6. DISSIPATION FACTOR Tan δ:
LESS
THAN 0.1% at 1 kHz AND
20℃
7. INSULATION RESISTANCE:
BETWEEN ELECTRODES
LESS THAN OR EAUAL TO ≧ 15,000 MΩ
MEASURED AT 100VDC, 60 SEC. AND 20℃
8. WITHSTAND VOLTAGE:
APPLIED 2500V.DC FOR 60 SEC. OR 4000V.DC FOR 1 SEC
9. CLIMATE CATEGORY: IN ACCORDANCE WITH DIN40040 GMF
G (MINIMUM LIMIT TEMPERATURE)= -40℃
M (MAXIMUM LIMIT TEMPERATURE)= +100℃
F (HUMIDITY CATEGORY)=AVERAGE RELATEIVE HVMIDITY ≦75%, 95% FOR 30
DAYS PER YEAR, CONTINUOUSLY; 85% FOR THE
REMATINING DAYS, OCCASIONALLY
10. HUMIDITY TEST:
TEST CONDIDITON
TEST TEMPER ATURE
: 40±2℃
RELATIVE HUMIDITY
: 90 TO 95%
TEST DURATION
: 500 HRS
TEST CRITERIA
: ≦ 5% OF THE INITIAL VALUE
(1) CAPACITANCE DRIFT
(2) INSULATION RESISTANCE : ≦ 50% OF SPECIFIED VALUE
11. LIFE TEST:
TEST CONDITION
TEST TEMPERATURE
: 100±3℃
TEST VOLTAGE
:468VAC AND 1000VDC 60HZ FOR A PERIOD OF
0.1 SEC. ONCE EACH HOUR
TEST DURATION
: 1008 HRS
TEST CRITERIA
: ≦10% OF THE INITIAL VALUE
(2) INSULATION RESISTANCE : ≧50% OF SPECIFIED VALUE
(3) VISUAL INSPECTION
: NO DETECTABLE DAMAGE
12. SOLDERABILITY:
TEST CONDITIONS
SOLDER BATH TEMPERATURE : 260±5℃
SOLDER
: Sn/Cu=99.3%/0.7%
SOLDER TIME
: 3±0.5 SEC
TEST CRITERIA
75% OF THE SURFACE TINNING
13. VIBRATION RESISTANCE: (JIS 5115)
TEST CONDITIONS
FREQUENCY CYCLE : 1 MINUTE PER CYCLE 10-55-10 HZ
TEST DURATION
: PERPENDICULAR DIRECTION WITH THE SAME
METHOD FOR 45 MINUTES EACH, TOTAL 90 MINUTES
TEST CRITERIA
(1) APPERANCE
: NO VISUAL DAMAGE
(2) CONTACT
: NORMAL
14. TENSILE STRENGTH OF ELECTRODES:
TEST CONDITIONS
LOAD CONDITIONS
: 1.0KGS
HOLDING TIME
: 10±1 SEC
TEST CRITERIA
NO WIRE BROKEN AND NO DAMAGE OF THE CAPACITOR
15. MARKING:
CAPACITORS ARE MARKED WITH TYPE IDENTIFICATION, CAPACITANCE,
CAPACITANCE TOLERANCE, VOLTAGE AND APPROVED CERTIFICATION MARK
16. APPROVED BY: VDE:: NEMKO: DEMKO; SEMKO; FIMKO; UL :
VDE
FILE NO. 40000362
NEMKO FILE NO. 48891
DEMKO FILE NO. 311148-01
SEMKO FILE NO. 0202066/01
FIMKO FILE NO.2011061
UL
FILE NO. E222911
W
± 0.5
± 0 .5
MARKING
d
± 0.05
L0
L0 20 min
MARKING
T
H ±0.5
± 0 .5
H ±0.5
W
P ± 0.5
P ± 0.5
Pediform .E#( 短 脚 )
Pediform.A#( 长 脚 )
Y2-class film Capacitor size.
Capacitance
Dimennsions
Capacitance
C(UF) symbol
C(UF)
symbol
W
H
T
P
dØ
0.001
102
13.0
9.0
4.0
10.0
0.6
0.01
0.0015
152
13.0
9.0
4.0
10.0
0.6
0.0022
222
13.0
9.0
4.0
10.0
0.0027
272
13.0
11.0
5.0
0.0033
332
13.0
11.0
0.0047
472
13.0
0.0056
562
0.0068
682
Dimennsions
W
H
T
P
dØ
103
18.0
11.0
5.0
15.0
0.8
0.015
153
18.0
12.0
6.0
15.0
0.8
0.6
0.022
223
18.0
13.0
7.5
15.0
0.8
10.0
0.6
0.033
333
18.0
13.0
7.5
15.0
0.8
5.0
10.0
0.6
0.047
473
18.0
14.5
8.5
15.0
0.8
11.0
5.0
10.0
0.6
0.068
683
18.0
16.0
10.0
15.0
0.8
13.0
12.0
6.0
10.0
0.6
0.1
104
18.0
19.0
11.0
15.0
0.8
18.0
11.0
5.0
15.0
0.6
*Please contact us for special item or size not listed.
µF / V
Tolerance
W
H
Part Numbering : MEY-222K/275VAC
W.V
±10%
Symbol-0.0022UF
TYPE
T
Pediform
P
L0
dØ
很抱歉,暂时无法提供与“MEY272K275A01”相匹配的价格&库存,您可以联系我们找货
