MEY473K275A01
MEY473K275A01
    TENTA(天泰)
    CAP_18X8.5MM_TM
    安规电容 CAP_18X8.5MM_TM 47nF ±10% 275V
MEY473K275A01 数据手册
客户 CUSTOMER 品名 PART NAME 天泰料号 TENTA Material Number 客户料号 CUSTOMER Material Number 编制/Edition 检查/Checked 确认/Confirmed 陆伟 徐志钦 廖小春 承认/Admit 审核/Auditing 批准/Approved 天泰電機工業有限公司 TENTA ELECTRIC INDUSTRIAL CO., LTD. 台中縣梧棲区自強二街 86 巷 61 號 NO.61, Lane 86, Tzchiang 2st St. Wu-Chi Township, Taichung County 435, TAIWAN R.O.C TEL:(886-04)26398618 FAX:(886-04)26392549 深圳天泰電器元件有限公司 SHEN ZHEN TENTA ELECTRICAL APPLIANCE LTD. 公司:深圳市南山區白石洲中國原子能第二工業區第二棟六樓 6/F NO.2, Pirector Atom 2th Industry, Baishizhou , Shenzhen, CHINA TEL:(0755)86327963、26921158 FAX:(0755)86297411 工厂:深圳市寶安區福永街道橋頭社區富橋第四工業區 A5 棟 No.A5,FU Qiao 4th Industrial area,Qiaotou Community,Fuyong Street,Bao An District,Shen Zhen TEL:(0755)29604898 FAX:(0755)29604891 TENTA ELECTRIC INDUSTRIAL CO., LTD. Y2-Class Film Capacitor, TYPE-MEY SPECIFICATION: 1. REFERENCE STANDARDS: VDE DIN EN132400(1999-06)/IEC 60384-14: 1993-07, Table II + A1:1995-06 NEMKO IEC 384-14(ed.3) DEMKO DIN EN 132 400 1994/A2:1991+A3:1998dan IEC60384-14 1993+A:1995 SEMKO DIN EN 132 400 1994/A2:1998+A3:1998/IEC60384-14.Second edition:1993/A1:1995 FIMKO DIN EN 60384-14:2005 UL (250V/275V AC) USED FOR ACROSS-THE-LINE CAPACITORS, ANDTENNA-COUPLINE, LINE-BY-PASS COMPONENTS, RADIO INTERFERENCE SUPPRESSION, ELECTRONMAGNETIC INTERFERENCE FILTERS. 2. RATED VOLTAGE: 275V AC 50/ 60 Hz 3. CAPACITANCE RANGE: 0.001µF to 0.1 µF 4. CAPACITANCE TOLERANCE: ± 5% (J) ± 10% (K) ± 20% (M) 5. DIELECTRIC: METALLIZED POLYPROPYLENE FILM 6. DISSIPATION FACTOR Tan δ: LESS THAN 0.1% at 1 kHz AND 20℃ 7. INSULATION RESISTANCE: BETWEEN ELECTRODES LESS THAN OR EAUAL TO ≧ 15,000 MΩ MEASURED AT 100VDC, 60 SEC. AND 20℃ 8. WITHSTAND VOLTAGE: APPLIED 2500V.DC FOR 60 SEC. OR 4000V.DC FOR 1 SEC 9. CLIMATE CATEGORY: IN ACCORDANCE WITH DIN40040 GMF G (MINIMUM LIMIT TEMPERATURE)= -40℃ M (MAXIMUM LIMIT TEMPERATURE)= +100℃ F (HUMIDITY CATEGORY)=AVERAGE RELATEIVE HVMIDITY ≦75%, 95% FOR 30 DAYS PER YEAR, CONTINUOUSLY; 85% FOR THE REMATINING DAYS, OCCASIONALLY 10. HUMIDITY TEST: TEST CONDIDITON TEST TEMPER ATURE : 40±2℃ RELATIVE HUMIDITY : 90 TO 95% TEST DURATION : 500 HRS TEST CRITERIA : ≦ 5% OF THE INITIAL VALUE (1) CAPACITANCE DRIFT (2) INSULATION RESISTANCE : ≦ 50% OF SPECIFIED VALUE 11. LIFE TEST: TEST CONDITION TEST TEMPERATURE : 100±3℃ TEST VOLTAGE :468VAC AND 1000VDC 60HZ FOR A PERIOD OF 0.1 SEC. ONCE EACH HOUR TEST DURATION : 1008 HRS TEST CRITERIA (1) CAPACITANCE DRIFT : ≦10% OF THE INITIAL VALUE (2) INSULATION RESISTANCE : ≧50% OF SPECIFIED VALUE (3) VISUAL INSPECTION : NO DETECTABLE DAMAGE 12. SOLDERABILITY: TEST CONDITIONS SOLDER BATH TEMPERATURE : 260±5℃ SOLDER : Sn/Cu=99.3%/0.7% SOLDER TIME : 3±0.5 SEC TEST CRITERIA 75% OF THE SURFACE TINNING 13. VIBRATION RESISTANCE: (JIS 5115) TEST CONDITIONS FREQUENCY CYCLE : 1 MINUTE PER CYCLE 10-55-10 HZ TEST DURATION : PERPENDICULAR DIRECTION WITH THE SAME METHOD FOR 45 MINUTES EACH, TOTAL 90 MINUTES TEST CRITERIA (1) APPERANCE : NO VISUAL DAMAGE (2) CONTACT : NORMAL 14. TENSILE STRENGTH OF ELECTRODES: TEST CONDITIONS LOAD CONDITIONS : 1.0KGS HOLDING TIME : 10±1 SEC TEST CRITERIA NO WIRE BROKEN AND NO DAMAGE OF THE CAPACITOR 15. MARKING: CAPACITORS ARE MARKED WITH TYPE IDENTIFICATION, CAPACITANCE, CAPACITANCE TOLERANCE, VOLTAGE AND APPROVED CERTIFICATION MARK 16. APPROVED BY: VDE:: NEMKO: DEMKO; SEMKO; FIMKO; UL : VDE FILE NO. 40000362 NEMKO FILE NO. 48891 DEMKO FILE NO. 311148-01 SEMKO FILE NO. 0202066/01 FIMKO FILE NO.2011061 UL FILE NO. E222911 W ± 0.5 ± 0 .5 MARKING d ± 0.05 L0 L0 20 min MARKING T H ±0.5 ± 0 .5 H ±0.5 W P ± 0.5 P ± 0.5 Pediform .E#( 短 脚 ) Pediform.A#( 长 脚 ) Y2-class film Capacitor size. Capacitance Dimennsions Capacitance C(UF) symbol C(UF) symbol W H T P dØ 0.001 102 13.0 9.0 4.0 10.0 0.6 0.01 0.0015 152 13.0 9.0 4.0 10.0 0.6 0.0022 222 13.0 9.0 4.0 10.0 0.0027 272 13.0 11.0 5.0 0.0033 332 13.0 11.0 0.0047 472 13.0 0.0056 562 0.0068 682 Dimennsions W H T P dØ 103 18.0 11.0 5.0 15.0 0.8 0.015 153 18.0 12.0 6.0 15.0 0.8 0.6 0.022 223 18.0 13.0 7.5 15.0 0.8 10.0 0.6 0.033 333 18.0 13.0 7.5 15.0 0.8 5.0 10.0 0.6 0.047 473 18.0 14.5 8.5 15.0 0.8 11.0 5.0 10.0 0.6 0.068 683 18.0 16.0 10.0 15.0 0.8 13.0 12.0 6.0 10.0 0.6 0.1 104 18.0 19.0 11.0 15.0 0.8 18.0 11.0 5.0 15.0 0.6 *Please contact us for special item or size not listed. µF / V Tolerance W H Part Numbering : MEY-222K/275VAC W.V ±10% Symbol-0.0022UF TYPE T Pediform P L0 dØ
MEY473K275A01 价格&库存
很抱歉,暂时无法提供与“MEY473K275A01”相匹配的价格&库存,您可以联系我们找货
