LMV321/LMV358/LMV324
LMV321/LMV358/LMV324 Single/Dual/Quad
General Purpose, Low Voltage, Rail-to-Rail Output
Operational Amplifiers
General Description
Features
The LMV358/324 are low voltage (2.7–5.5V) versions of the
dual and quad commodity op amps, LM358/324, which currently operate at 5–30V. The LMV321 is the single version.
(For V+ = 5V and V− = 0V, Typical Unless Otherwise Noted)
n Guaranteed 2.7V and 5V Performance
n No Crossover Distortion
n Space Saving Package
SC70-5 2.0x2.1x1.0mm
n Industrial Temp. Range
−40˚C to +85˚C
n Gain-Bandwidth Product
1MHz
n Low Supply Current
— LMV321
130µA
— LMV358
210µA
— LMV324
410µA
n Rail-to-Rail Output Swing @ 10kΩ
V+ −10mV
V− +65mV
−0.2V to V+−0.8V
n VCM
The LMV321/358/324 are the most cost effective solutions
for the applications where low voltage operation, space saving and low price are needed. They offer specifications that
meet or exceed the familiar LM358/324. The LMV321/358/
324 have rail-to-rail output swing capability and the input
common-mode voltage range includes ground. They all exhibit excellent speed-power ratio, achieving 1MHz of bandwidth and 1V/µs of slew rate with low supply current.
The LMV321 is available in space saving SC70-5, which is
approximately half the size of SOT23-5. The small package
saves space on pc boards, and enables the design of small
portable electronic devices. It also allows the designer to
place the device closer to the signal source to reduce noise
pickup and increase signal integrity.
The chips are built with National’s advanced submicron
silicon-gate BiCMOS process. The LMV321/358/324 have
bipolar input and output stages for improved noise performance and higher output current drive.
Applications
n ActiveFilters
n GeneralPurposeLowVoltageApplications
n GeneralPurposePortableDevices
Output Voltage Swing vs. Supply Voltage
Gain and Phase vs. Capacitive Load
10006045
http:www.hgsemi.com.cn
10006067
1
2018 AUG
Absolute Maximum Ratings
Storage Temp. Range
(Note 1)
Supply Voltage
100V
2.7V to 5.5V
Temperature Range
Human Body Model
LMV358/324
LMV321, LMV358, LMV324
2000V
LMV321
Thermal Resistance (θ
900V
± Supply Voltage
Differential Input Voltage
150˚C
Operating Ratings (Note 1)
ESD Tolerance (Note 2)
Machine Model
−65˚C to 150˚C
Junction Temperature(Note 5)
If Military/Aerospace specified devices are required,
please contact the National Semiconductor Sales Office/
Distributors for availability and specifications.
Supply Voltage (V –V )
5.5V
JA)(Note
−40˚C to +85˚C
10)
5-pin SC70-5
478˚C/W
5-pin SOT23-5
265˚C/W
190˚C/W
Output Short Circuit to V
(Note 3)
8-Pin SOIC
(Note 4)
8-Pin MSOP
235˚C/W
14-Pin SOIC
145˚C/W
14-Pin TSSOP
155˚C/W
Soldering Information
Infrared or Convection (20 sec)
235˚C
2.7V DC Electrical Characteristics
Unless otherwise specified, all limits guaranteed for T
Symbol
Parameter
J
= 25˚C, V+ = 2.7V, V− = 0V, VCM = 1.0V, VO = V+/2 and RL > 1MΩ.
Conditions
Typ
(Note 6)
Limit
(Note 7)
1.7
7
Units
VOS
Input Offset Voltage
TCVOS
Input Offset Voltage Average
Drift
5
IB
Input Bias Current
11
250
nA
max
IOS
Input Offset Current
5
50
nA
max
CMRR
Common Mode Rejection Ratio
0V ≤ VCM ≤ 1.7V
63
50
dB
min
PSRR
Power Supply Rejection Ratio
2.7V ≤ V+ ≤ 5V
VO = 1V
60
50
dB
min
VCM
Input Common-Mode Voltage
Range
For CMRR≥50dB
−0.2
V
min
1.9
1.7
V
max
V+ -10
V+ -100
mV
min
60
180
mV
max
LMV321
80
170
µA
max
LMV358
Both amplifiers
140
340
µA
max
LMV324
All four amplifiers
260
680
µA
max
VO
IS
Output Swing
Supply Current
RL = 10kΩ to 1.35V
2
mV
max
µV/˚C
2018 AUG
2.7V AC Electrical Characteristics
Symbol
Parameter
J
Conditions
CL = 200pF
Typ
(Note 6)
Limit
(Note 7)
Units
GBWP
1
MHz
Φm
Phase Margin
60
Deg
Gm
Gain Margin
10
dB
en
Input-Referred Voltage Noise
f = 1kHz
46
in
Input-Referred Current Noise
f = 1kHz
0.17
5V DC Electrical Characteristics
Boldface limits apply at the temperature extremes.
Symbol
Parameter
J
= 25˚C, V+ = 5V, V− = 0V, VCM = 2.0V, VO = V+/2 and R
Conditions
L
> 1MΩ.
Typ
(Note 6)
Limit
(Note 7)
1.7
7
9
mV
max
µV/˚C
250
500
50
150
nA
max
nA
max
Units
VOS
TCVOS
Drift
Input Bias Current
15
IOS
5
CMRR
0V ≤ VCM ≤ 4V
65
50
dB
min
PSRR
2.7V ≤ V+ ≤ 5V
VO = 1V VCM = 1V
60
50
dB
min
For CMRR≥50dB
−0.2
V
min
4.2
4
100
15
V
max
V/mV
min
IB
VCM
AV
5
Range
Large Signal Voltage Gain (Note
RL = 2kΩ
8)
Output Swing
V+ -40
RL = 2kΩ to 2.5V
VO
120
RL = 10kΩ to 2.5V
IO
Output Short Circuit Current
Supply Current
IS
V+ -10
10
V+ -300
V+ -400
300
400
V+ -100
mV
min
mV
max
mV
min
65
V+ -200
180
280
Sourcing, VO = 0V
60
5
Sinking, VO = 5V
160
10
LMV321
130
LMV358
Both amplifiers
210
250
350
440
615
µA
max
µA
max
LMV324
All four amplifiers 3
410
830
1160
µA
max
3
mV
max
m
min
mA
min
2018 AUG
5V AC Electrical Characteristics
Symbol
Parameter
J
Conditions
Typ
(Note 6)
Limit
(Note 7)
L
> 1MΩ.
Units
SR
Slew Rate
(Note 9)
1
V/µs
GBWP
CL = 200pF
1
MHz
Φm
Phase Margin
60
Deg
Gm
Gain Margin
10
dB
en
f = 1kHz
39
in
f = 1kHz
0.21
Note 1: Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is
intended to be functional, but specific performance is not guaranteed. For guaranteed specifications and the test conditions, see the Electrical Characteristics.
Note 2: Human body model, 1.5kΩ in series with 100pF. Machine model, 0Ω in series with 200pF.
Note 3: Shorting output to V+ will adversely affect reliability.
Note 4: Shorting output to V- will adversely affect reliability.
Note 5: The maximum power dissipation is a function of TJ(MAX), θJA, and TA. The maximum allowable power dissipation at any ambient temperature is PD =
(TJ(MAX)–TA)/θJA. All numbers apply for packages soldered directly into a PC board.
Note 6: Typical values represent the most likely parametric norm.
Note 7: All limits are guaranteed by testing or statistical analysis.
Note 8: RL is connected to V-. The output voltage is 0.5V ≤ VO ≤ 4.5V.
Note 9: Connected as voltage follower with 3V step input. Number specified is the slower of the positive and negative slew rates.
Note 10: All numbers are typical, and apply for packages soldered directly onto a PC board in still air.
4
2018 AUG
Typical Performance Characteristics
Unless otherwise specified, VS = +5V, single supply,
TA = 25˚C.
Supply Current vs. Supply Voltage (LMV321)
Input Current vs. Temperature
100060A9
10006073
Sourcing Current vs. Output Voltage
10006069
10006068
Sinking Current vs. Output Voltage
10006070
10006071
5
2018 AUG
Typical Performance Characteristics Unless otherwise specified, VS = +5V, single supply,
TA = 25˚C. (Continued)
Input Voltage Noise vs. Frequency
10006056
10006067
Input Current Noise vs. Frequency
10006060
10006058
Crosstalk Rejection vs. Frequency
PSRR vs. Frequency
10006051
10006061
6
2018 AUG
CMRR vs. Frequency
CMRR vs. Input Common Mode Voltage
10006064
10006062
∆VOS vs. CMR
10006063
∆V
OS
10006053
vs. CMR
Input Voltage vs. Output Voltage
10006054
10006050
7
2018 AUG
Open Loop Frequency Response
10006052
10006042
Open Loop Frequency Response vs. Temperature
10006041
10006043
10006045
10006044
8
2018 AUG
Slew Rate vs. Supply Voltage
Non-Inverting Large Signal Pulse Response
10006088
10006057
100060A1
100060A0
Non-Inverting Small Signal Pulse Response
10006089
100060A2
9
2018 AUG
100060A3
10006090
100060A4
100060A5
10006091
100060A6
10
2018 AUG
Stability vs. Capacitive Load
100060A7
10006046
10006049
10006047
THD vs. Frequency
10006059
10006048
1
2018 AUG
Open Loop Output Impedance vs. Frequency
Short Circuit Current vs. Temperature (Sinking)
10006055
10006065
Short Circuit Current vs. Temperature (Sourcing)
10006066
12
2018 AUG
Application Notes
Output Voltage (500mV/div)
1.0 BENEFITS OF THE LMV321/358/324
Size: The small footprints of the LMV321/358/324 packages
save space on printed circuit boards, and enable the design
of smaller electronic products, such as cellular phones, pagers, or other portable systems. The low profile of the
LMV321/358/324 make them possible to use in PCMCIA
type III cards.
Signal Integrity
Signals can pick up noise between the signal source and the
amplifier. By using a physically smaller amplifier package,
the LMV321/358/324 can be placed closer to the signal
source, reducing noise pickup and increasing signal integrity.
Time (50µs/div)
10006097
Simplified Board Layout
These products help you to avoid using long pc traces in
your pc board layout. This means that no additional components, such as capacitors and resistors, are needed to filter
out the unwanted signals due to the interference between
the long pc traces.
FIGURE 1. Output Swing of LMV324
Low Supply Current
These devices will help you to maximize battery life. They
are ideal for battery powered systems.
Low Supply Voltage
National provides guaranteed performance at 2.7V and 5V.
These guarantees ensure operation throughout the battery
lifetime.
Rail-to-Rail Output
Rail-to-rail output swing provides maximum possible dynamic range at the output. This is particularly important
when operating on low supply voltages.
Time (50µs/div)
10006098
FIGURE 2. Output Swing of LM324
Input Includes Ground
Allows direct sensing near GND in single supply operation.
The differential input voltage may be larger than V+ without
damaging the device. Protection should be provided to prevent the input voltages from going negative more than −0.3V
(at 25˚C). An input clamp diode with a resistor to the IC input
terminal can be used.
2.0 CAPACITIVE LOAD TOLERANCE
The LMV321/358/324 can directly drive 200pF in unity-gain
without oscillation. The unity-gain follower is the most sensitive configuration to capacitive loading. Direct capacitive
loading reduces the phase margin of amplifiers. The combination of the amplifier’s output impedance and the capacitive
load induces phase lag. This results in either an underdamped pulse response or oscillation. To drive a heavier
capacitive load, circuit in Figure 3 can be used.
Ease Of Use & Crossover Distortion
The LMV321/358/324 offer specifications similar to the familiar LM324. In addition, the new LMV321/358/324 effectively eliminate the output crossover distortion. The scope
photos in Figure 1 and Figure 2 compare the output swing of
the LMV324 and the LM324 in a voltage follower configuration, with V S = ± 2.5V and RL (= 2kΩ) connected to GND. It
is apparent that the crossover distortion has been eliminated
in the new LMV324.
10006004
FIGURE 3. Indirectly Driving A Capacitive Load Using
Resistive Isolation
13
2018 AUG
Application Notes
input bias current will be reduced. The circuit in Figure 6
shows how to cancel the error caused by input bias current.
(Continued)
(1v/div)
Input Signal
In Figure 3 , the isolation resistor RISO and the load capacitor
CL form a pole to increase stability by adding more phase
margin to the overall system. The desired performance depends on the value of RISO. The bigger the RISO resistor
value, the more stable VOUT will be. Figure 4 is an output
waveform of Figure 3 using 620Ω for RISO and 510pF for CL..
10006006
Output Signal
FIGURE 6. Cancelling the Error Caused by Input Bias
Current
4.0 TYPICAL SINGLE-SUPPLY APPLICATION CIRCUITS
4.1 Difference Amplifier
The difference amplifier allows the subtraction of two voltages or, as a special case, the cancellation of a signal
common to two inputs. It is useful as a computational amplifier, in making a differential to single-ended conversion or in
rejecting a common mode signal.
Time (2µs/div)
10006099
FIGURE 4. Pulse Response of the LMV324 Circuit in
Figure 3
The circuit in Figure 5 is an improvement to the one in Figure
3 because it provides DC accuracy as well as AC stability. If
there were a load resistor in Figure 3, the output would be
voltage divided by RISO and the load resistor. Instead, in
Figure 5, RF provides the DC accuracy by using feedforward techniques to connect VIN to RL. Caution is needed
in choosing the value of RF due to the input bias current of
the LMV321/358/324. CF and RISO serve to counteract the
loss of phase margin by feeding the high frequency component of the output signal back to the amplifier’s inverting
input, thereby preserving phase margin in the overall feedback loop. Increased capacitive drive is possible by increasing the value of C F . This in turn will slow down the pulse
response.
10006007
10006019
FIGURE 7. Difference Amplifier
4.2 Instrumentation Circuits
The input impedance of the previous difference amplifier is
set by the resistors R1, R2, R3, and R4. To eliminate the
problems of low input impedance, one way is to use a
voltage follower ahead of each input as shown in the following two instrumentation amplifiers.
10006005
FIGURE 5. Indirectly Driving A Capacitive Load with
DC Accuracy
3.0 INPUT BIAS CURRENT CANCELLATION
The LMV321/358/324 family has a bipolar input stage. The
typical input bias current of LMV321/358/324 is 15nA with 5V
supply. Thus a 100kΩ input resistor will cause 1.5mV of error
voltage. By balancing the resistor values at both inverting
and non-inverting inputs, the error caused by the amplifier’s
14
2018 AUG
Application Notes
4.3 Single-Supply Inverting Amplifier
(Continued)
4.2.1 Three-Op-Amp Instrumentation Amplifier
The quad LMV324 can be used to build a three-op-amp
instrumentation amplifier as shown in Figure 8.
There may be cases where the input signal going into the
amplifier is negative. Because the amplifier is operating in
single supply voltage, a voltage divider using R3 and R4 is
implemented to bias the amplifier so the input signal is within
the input common-mode voltage range of the amplifier. The
capacitor C1 is placed between the inverting input and resistor R1 to block the DC signal going into the AC signal source,
VIN. The values of R1 and C1 affect the cutoff frequency, fc =
1/2πR1C1.
As a result, the output signal is centered around mid-supply
(if the voltage divider provides V+/2 at the non-inverting
input). The output can swing to both rails, maximizing the
signal-to-noise ratio in a low voltage system.
10006085
FIGURE 8. Three-op-amp Instrumentation Amplifier
The first stage of this instrumentation amplifier is a
differential-input, differential-output amplifier, with two voltage followers. These two voltage followers assure that the
input impedance is over 100 MΩ. The gain of this instrumentation amplifier is set by the ratio of R2/R1. R3 should equal
R1, and R4 equal R2. Matching of R3 to R1 and R4 to R2
affects the CMRR. For good CMRR over temperature, low
drift resistors should be used. Making R4 slightly smaller
than R2 and adding a trim pot equal to twice the difference
between R2 and R4 will allow the CMRR to be adjusted for
optimum.
10006013
10006020
FIGURE 10. Single-Supply Inverting Amplifier
4.4 ACTIVE FILTER
4.2.2 Two-op-amp Instrumentation Amplifier
A two-op-amp instrumentation amplifier can also be used to
make a high-input-impedance dc differential amplifier (Figure 9) . As in the three-op-amp circuit, this instrumentation
amplifier requires precise resistor matching for good CMRR.
R4 should equal to R1 and R3 should equal R2.
4.4.1 Simple Low-Pass Active Filter
The simple low-pass filter is shown in Figure 11. Its lowfrequency gain (ω → 0) is defined by -R3/R1. This allows
low-frequency gains other than unity to be obtained. The
filter has a -20dB/decade roll-off after its corner frequency fc.
R2 should be chosen equal to the parallel combination of R1
and R3 to minimize errors due to bias current. The frequency
response of the filter is shown in Figure 12.
10006011
10006035
FIGURE 9. Two-Op-amp Instrumentation Amplifier
15
2018 AUG
Application Notes
Its transfer function is
(Continued)
(2)
10006014
10006016
FIGURE 13. Sallen-Key 2nd-Order Active Low-Pass
Filter
The following paragraphs explain how to select values for
R1, R2, R3, R4, C1, and C 2 for given filter requirements, such
as ALP, Q, and f c.
The standard form for a 2nd-order low pass filter is
10006037
FIGURE 11. Simple Low-Pass Active Filter
(3)
where
Q: Pole Quality Factor
ωC: Corner Frequency
Comparison between the Equation (2) and Equation (3)
yields
10006015
FIGURE 12. Frequency Response of Simple Low-Pass
Active Filter in Figure 11
(4)
Note that the single-op-amp active filters are used in to the
applications that require low quality factor, Q( ≤ 10), low
frequency (≤ 5 kHz), and low gain (≤ 10), or a small value for
the product of gain times Q (≤ 100). The op amp should have
an open loop voltage gain at the highest frequency of interest at least 50 times larger than the gain of the filter at this
frequency. In addition, the selected op amp should have a
slew rate that meets the following requirement:
Slew Rate ≥ 0.5 x (ω HVOPP) x 10−6 V/µsec
where ωH is the highest frequency of interest, and Vopp is the
output peak-to-peak voltage.
(5)
To reduce the required calculations in filter design, it is
convenient to introduce normalization into the components
and design parameters. To normalize, let ωC = ωn = 1rad/s,
and C1 = C2 = Cn = 1F, and substitute these values into
Equation (4) and Equation (5). From Equation (4), we obtain
4.4.2 Sallen-Key 2nd-Order Active Low-Pass Filter
The Sallen-Key 2nd-order active low-pass filter is illustrated
in Figure 13. The dc gain of the filter is expressed as
(6)
From Equation (5), we obtain
(7)
(1)
16
2018 AUG
Application Notes
An adjustment to the scaling may be made in order to have
realistic values for resistors and capacitors. The actual value
used for each component is shown in the circuit.
(Continued)
For minimum dc offset, V+ = V−, the resistor values at both
inverting and non-inverting inputs should be equal, which
means
4.4.3 2nd-order High Pass Filter
A 2nd-order high pass filter can be built by simply interchanging those frequency selective components (R1, R 2,
C1, C2) in the Sallen-Key 2nd-order active low pass filter. As
shown in Figure 14, resistors become capacitors, and capacitors become resistors. The resulted high pass filter has
the same corner frequency and the same maximum gain as
the previous 2nd-order low pass filter if the same components are chosen.
(8)
From Equation (1) and Equation (8), we obtain
(9)
(10)
The values of C1 and C2 are normally close to or equal to
As a design example:
Require: ALP = 2, Q = 1, fc = 1KHz
Start by selecting C1 and C2. Choose a standard value that
is close to
10006083
FIGURE 14. Sallen-Key 2nd-Order Active High-Pass
Filter
From Equations (6), (7), (9), (10),
R1= 1Ω
R2= 1Ω
R3= 4Ω
R4= 4Ω
The above resistor values are normalized values with ωn =
1rad/s and C1 = C2 = Cn = 1F. To scale the normalized cut-off
frequency and resistances to the real values, two scaling
factors are introduced, frequency scaling factor (kf) and impedance scaling factor (km).
4.4.4 State Variable Filter
A state variable filter requires three op amps. One convenient way to build state variable filters is with a quad op amp,
such as the LMV324 (Figure 15).
This circuit can simultaneously represent a low-pass filter,
high-pass filter, and bandpass filter at three different outputs.
The equations for these functions are listed below. It is also
called "Bi-Quad" active filter as it can produce a transfer
function which is quadratic in both numerator and
denominator.
Scaled values:
R2 = R1 = 15.9 kΩ
R3 = R4 = 63.6 kΩ
C1 = C2 = 0.01 µF
17
2018 AUG
Application Notes
(Continued)
10006039
FIGURE 15. State Variable Active Filter
A design example for a bandpass filter is shown below:
Assume the system design requires a bandpass filter with f O
= 1kHz and Q = 50. What needs to be calculated are
capacitor and resistor values.
First choose convenient values for C1, R1 and R2:
C1 = 1200pF
2R2 = R1 = 30kΩ
Then from Equation (11),
From Equation (12),
where for all three filters,
(11)
From the above calculated values, the midband gain is H 0 =
R3/R2 = 100 (40dB). The nearest 5% standard values have
been added to Figure 15.
(12)
4.5 PULSE GENERATORS AND OSCILLATORS
A pulse generator is shown in Figure 16. Two diodes have
been used to separate the charge and discharge paths to
capacitor C.
18
2018 AUG
Application Notes
(Continued)
10006081
FIGURE 16. Pulse Generator
10006086
When the output voltage VO is first at its high, VOH, the
capacitor C is charged toward VOH through R2. The voltage
across C rises exponentially with a time constant τ = R2C,
and this voltage is applied to the inverting input of the op
amp. Meanwhile, the voltage at the non-inverting input is set
at the positive threshold voltage (VTH+) of the generator. The
capacitor voltage continually increases until it reaches VTH+,
at which point the output of the generator will switch to its
low, VOL (= 0V in this case). The voltage at the non-inverting
input is switched to the negative threshold voltage (VTH-) of
the generator. The capacitor then starts to discharge toward
VOL exponentially through R1, with a time constant τ = R1C.
When the capacitor voltage reaches VTH-, the output of the
pulse generator switches to V OH. The capacitor starts to
charge, and the cycle repeats itself.
FIGURE 17. Waveforms of the Circuit in Figure 16
As shown in the waveforms in Figure 17, the pulse width (T1)
is set by R2, C and VOH, and the time between pulses (T2) is
set by R 1, C and VOL. This pulse generator can be made to
have different frequencies and pulse width by selecting different capacitor value and resistor values.
Figure 18 shows another pulse generator, with separate
charge and discharge paths. The capacitor is charged
through R1 and is discharged through R2.
10006077
FIGURE 18. Pulse Generator
Figure 19 is a squarewave generator with the same path for
charging and discharging the capacitor.
19
2018 AUG
Application Notes
(Continued)
4.6.2 High Compliance Current Sink
A current sink circuit is shown in Figure 21. The circuit
requires only one resistor (RE) and supplies an output current which is directly proportional to this resistor value.
10006076
FIGURE 19. Squarewave Generator
10006082
4.6 CURRENT SOURCE AND SINK
The LMV321/358/324 can be used in feedback loops which
regulate the current in external PNP transistors to provide
current sources or in external NPN transistors to provide
current sinks.
FIGURE 21. High Compliance Current Sink
4.7 POWER AMPLIFIER
A power amplifier is illustrated in Figure 22. This circuit can
provide a higher output current because a transistor follower
is added to the output of the op amp.
4.6.1 Fixed Current Source
A multiple fixed current source is show in Figure 20. A
voltage (VREF = 2V) is established across resistor R3 by the
voltage divider (R3 and R 4). Negative feedback is used to
cause the voltage drop across R 1 to be equal to VREF. This
controls the emitter current of transistor Q1 and if we neglect
the base current of Q1 and Q2, essentially this same current
is available out of the collector of Q1.
Large input resistors can be used to reduce current loss and
a Darlington connection can be used to reduce errors due to
the β of Q1.
The resistor, R2, can be used to scale the collector current of
Q2 either above or below the 1mA reference value.
10006079
FIGURE 22. Power Amplifier
4.8 LED DRIVER
The LMV321/358/324 can be used to drive an LED as shown
in Figure 23.
10006084
10006080
FIGURE 20. Fixed Current Source
FIGURE 23. LED Driver
2018 AUG
Application Notes
The differential voltage at the input of the op amp should not
exceed the specified absolute maximum ratings. For real
comparators that are much faster, we recommend you to use
National’s LMV331/393/339, which are single, dual and quad
general purpose comparators for low voltage operation.
(Continued)
4.9 COMPARATOR WITH HYSTERESIS
The LMV321/358/324 can be used as a low power comparator. Figure 24 shows a comparator with hysteresis. The
hysteresis is determined by the ratio of the two resistors.
VTH+ = VREF/(1+R 1/R2)+VOH/(1+R2/R1)
VTH− = VREF/(1+R 1/R2)+VOL/(1+R2/R1)
VH = (VOH−VOL)/(1+R 2/R1)
where
VTH+: Positive Threshold Voltage
VTH−: Negative Threshold Voltage
VOH: Output Voltage at High
VOL: Output Voltage at Low
VH: Hysteresis Voltage
Since LMV321/358/324 have rail-to-rail output,
(VOH−VOL) equals to VS, which is the supply voltage.
10006078
FIGURE 24. Comparator with Hysteresis
the
VH = VS/(1+R2/R 1)
Connection Diagrams
5-Pin SC70-5/SOT23-5
8-Pin SO/MSOP
14-Pin SO/TSSOP
10006001
Top View
10006002
Top View
10006003
Top View
21
2018 AUG
