LMV321/LMV358/LMV324
1.5MHz, Low Cost
Micro Power Operational Amplifiers
Features
General Description
Operates on 2.1V ~ 5.5V Supplies
The LMV321 (single), LMV358 (dual) and
Low Quiescent Current: 85μA
LMV324 (quad) are micro-power, low cost
Gain Bandwidth Product: 1.5MHz
amplifiers operated on 2.1V to 5.5V supplies.
Slew Rate: 1V/µs
Despite their
Rail-to-Rail Output
LMV358 family provides excellent overall
Unity Gain Stable
performance
No Phase Reversal
rail-to-rail output voltage range which extends
Extended Temperature Ranges
to within 10mV of each rail, providing the
From -40°C to +125°C
maximum output dynamic range with excellent
Small Packaging
overdrive recovery.
low quiescent
and
versatility.
current, the
They
have
LMV321 available in SOT23-5/SOP8
LMV358 available in SOP8/MSOP8
LMV358 family is unity gain stable and has a
LMV324 available in SOP14/TSSOP14
gain bandwidth product of 1.5MHz (typical).
They
Applications
Portable Equipment
Sensor Conditioning
Analog Active Filters
Medical Equipment
Audio Output
White Goods
Battery or Solar Powered Systems
provide
high
CMRR
and
PRSS
performance and can operate from a single
supply voltage as low as 2.1V. These features
make the LMV358 family well suited for
single-supply,
battery-powered
applications.
They can be used as plus-in replacements for
many commercially available op-amps to
reduce power and improve output range and
performance.
Rev1.0
Copyright@2018 Cosine Nanoelectronics Inc. All rights reserved
The information provided here is believed to be accurate and reliable. Cosine Nanoelectronics assumes
no reliability for inaccuracies and omissions. Specifications described and contained here are subjected
to change without notice on the purpose of improving the design and performance. All of this information
described herein should not be implied or granted for any third party.
www.cosine-ic.com
1
1. Pin Configuration and Functions
LMV321
LMV321
LMV358
LMV324
Pin Functions
Name
Description
Note
A bypass capacitor of 0.1μF as close to the part as
possible should be placed between power supply pins
or between supply pins and ground.
Negative power supply If it is not connected to ground, bypass it with a
or ground
capacitor of 0.1μF as close to the part as possible.
Inverting input of the amplifier. Voltage range of this
Negative input
pin can go from -Vs -0.3V to +Vs - 1V.
Non-inverting input of the amplifier. This pin has the
Positive input
same voltage range as –IN.
The output voltage range extends to within millivolts
Output
of each supply rail.
+Vs
Positive power supply
-Vs
-IN
+IN
OUT
NC
No connection
2. Package and Ordering Information
Model
Channel
LMV321
1
LMV358
2
LMV324
4
www.cosine-ic.com
Order Number
Package
Package Option
Marking
Information
LMV321TR
SOT23-5
Tape and Reel, 3000
C321
LMV321SR
SOP-8
Tape and Reel, 3000
COS321
LMV358SR
SOP-8
Tape and Reel, 3000
COS358
LMV358MR
MSOP-8
Tape and Reel, 3000
COS358
LMV324SR
SOP-14
Tape and Reel, 3000
COS324
LMV324TR
TSSOP-14
Tape and Reel, 3000
COS324
2
3. Product Specification
3.1 Absolute Maximum Ratings (1)
Parameter
Power Supply: +Vs to -Vs
Input Voltage
Input Current (2)
Storage Temperature Range
Junction Temperature
Operating Temperature Range
ESD Susceptibility, HBM
Rating
Units
6.0
V
-Vs -0.5V to +Vs + 0.5V
V
10
mA
-65 to 150
°C
150
°C
-40 to 125
°C
2000
V
(1) Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable
above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition,
extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute
maximum ratings are stress ratings only.
(2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the
supply rails should be current-limited to 10mA or less.
3.2 Thermal Data
Parameter
Rating
Unit
Package Thermal Resistance
190 (SOT23-5)
206 (MSOP8)
155 (SOP8)
105 (TSSOP14)
82 (SOP14)
°C/W
Rating
Unit
2.1V ~ 5.5V
V
Input common-mode voltage range
-Vs ~ +Vs
V
Operating ambient temperature
-40 to +85
°C
3.3 Recommended Operating Conditions
Parameter
DC Supply Voltage
www.cosine-ic.com
3
3.4 Electrical Characteristics
(+VS=+5V, -VS=0, VCM=VS/2, TA=+25°C, RL=10kΩ to VS/2, unless otherwise noted)
Parameter
Symbol
Conditions
Min
Typ
Max
Unit
1.0
5.0
mV
Input Characteristics
Input Offset Voltage
VOS
Input Offset Voltage Drift
ΔVOS/ΔT
Input Bias Current
-40 to 125°C
5
μV/°C
IB
2.5
pA
Input Offset Current
IOS
2.5
pA
Common-Mode Voltage Range
VCM
VS = 5.5V
Common-Mode Rejection Ratio
CMRR
VCM =0.1V to 4.5V
125
dB
Open-Loop Voltage Gain
AOL
VO=0.2V to 4.5V
120
dB
RL=100kΩ
1
mV
RL=10kΩ
10
mV
RL=2kΩ
40
mV
ISR
Sourcing
45
mA
ISK
Sinking
50
mA
-0.1
4.5
V
Output Characteristics
Output Voltage Swing from Rail
Short-Circuit Current
Power Supply
Operating Voltage Range
2.1
Power Supply Rejection Ratio
PSRR
Quiescent Current / Amplifier
IQ
VS = +1.8V to +5.5V
80
5.5
V
100
dB
85
μA
1.5
MHz
Dynamic Performance
GBWP
G=+1
Slew Rate
SR
G = +1 , 2V Output Step
1
V/μs
en
f=1kHz
28
nV/√Hz
Noise Performance
Voltage Noise Density
www.cosine-ic.com
4
4.0 Application Notes
Driving Capacitive Loads
Driving large capacitive loads can cause stability problems for voltage feedback op amps. As the
load capacitance increases, the feedback loop’s phase margin decreases, and the closed loop
bandwidth is reduced. This produces gain peaking in the frequency response, with overshoot and
ringing in the step response. A unity gain buffer (G = +1) is the most sensitive to capacitive loads, but
all gains show the same general behavior.
When driving large capacitive loads with these op amps (e.g., > 100 pF when G = +1), a small series
resistor at the output (RISO in Figure 1) improves the feedback loop’s phase margin (stability) by
making the output load resistive at higher frequencies. It does not, however, improve the bandwidth.
To select RISO, check the frequency response peaking (or step response overshoot) on the bench. If
the response is reasonable, you do not need RISO. Otherwise, start RISO at 1 kΩ and modify its value
until the response is reasonable.
Figure 1. Indirectly Driving Heavy Capacitive Load
An improvement circuit is shown in Figure 2. It provides DC accuracy as well as AC stability. RF
provides the DC accuracy by connecting the inverting signal with the output, CF and RISO serve to
counteract the loss of phase margin by feeding the high frequency component of the output signal
back to the amplifier’s inverting input, thereby preserving phase margin in the overall feedback loop.
Figure 2. Indirectly Driving Heavy Capacitive Load with DC Accuracy
www.cosine-ic.com
5
For noninverting configuration, there are two others ways to increase the phase margin: (a) by
increasing the amplifier’s gain or (b) by placing a capacitor in parallel with the feedback resistor to
counteract the parasitic capacitance associated with inverting node, as shown in Figure 3.
Figure 3. Adding a Feedback Capacitor in the Noninverting Configuration
Power-Supply Bypassing and Layout
The LMV321/2/4 operates from a single +2.1V to +5.5V supply or dual ±1.05V to ±2.75V supplies.
For single-supply operation, bypass the power supply +Vs with a 0.1μF ceramic capacitor which
should be placed close to the +Vs pin. For dual-supply operation, both the +Vs and the -Vs supplies
should be bypassed to ground with separate 0.1μF ceramic capacitors. 2.2μF tantalum capacitor can
be added for better performance.
The length of the current path is directly proportional to the magnitude of parasitic inductances and
thus the high frequency impedance of the path. High speed currents in an inductive ground return
create an unwanted voltage noise. Broad ground plane areas will reduce the parasitic inductance.
Thus a ground plane layer is important for high speed circuit design.
Typical Application Circuits
Differential Amplifier
The circuit shown in Figure 4 performs the differential function. If the resistors ratios are equal (R4 /
R3 = R2 / R1), then VOUT = (VIP – VIN) × R2 / R1 + VREF.
www.cosine-ic.com
6
Figure 4. Differential Amplifier
Low Pass Active Filter
When receiving low-level signals, limiting the bandwidth of the incoming signals into the system is
often required. The simplest way to establish this limited bandwidth is to place an RC filter at the
noninverting terminal of the amplifier. If even more attenuation is needed, a multiple pole filter is
required. The Sallen-Key filter can be used for this task, as Figure 5. For best results, the amplifier
should have a bandwidth that is 8 to 10 times the filter frequency bandwidth. Failure to follow this
guideline can result in reduction of phase margin. The large values of feedback resistors can couple
with parasitic capacitance and cause undesired effects such as ringing or oscillation in high-speed
amplifiers. Keep resistors value as low as possible and consistent with output loading consideration.
Figure 5. Two-Pole Low-Pass Sallen-Key Active Filter
www.cosine-ic.com
7
5. Package Information
5.1 SOT23-5 (Package Outline Dimensions)
5.2 SOP8 (Package Outline Dimensions)
www.cosine-ic.com
8
5.3 MSOP8 (Package Outline Dimensions)
5.4 SOP14 (Package Outline Dimensions)
www.cosine-ic.com
9
5.5 TSSOP14 (Package Outline Dimensions)
6. Related Parts
Part Number
Description
COS6041/2/4
24kHz, 0.5μA, RRIO Op Amps, 1.8 to 5.5V Supply
COS1347/2347/4347
350kHz, 15μA, RRIO Op Amps, 1.8 to 5.5V Supply
LMV321/2/4
1.5MHz, 50μA, RRIO Op Amps, 1.8 to 5.5V Supply
COS1314/2314/4314
3MHz, 150μA, RRIO Op Amps, 1.8 to 5.5V Supply
COS821/2/4
5MHz, 300μA, RRIO Op Amps, 1.8 to 5.5V Supply
COS1374/2374/4374
7MHz, 500μA, RRIO Op Amps, 1.8 to 5.5V Supply
COS721/2/4
10MHz, 650μA, RRIO Op Amps, 2.1 to 5.5V Supply
COS1333/2333/4333
0.35MHz, 18μA, RRIO Op Amps, 1.8 to 5.5V Supply, Zero Drift, Vos
