HMP9435
LOW VOLTAGE MOSFET (P-CHANNEL)
FEATURES
Ultra low on-resistance:VDS=-30V,ID=-5.1A,RDS(ON)≤85mΩ@VGS=-10V
Ultra low gate charge
For load switch or in PWM applications
Surface Mount device
SOP-8
MECHANICAL DATA
Case: SOP-8
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Moisture Sensitivity: Level 1 per J-STD-020
Weight: 0.3 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol
VDS
VGS
ID
IDM
PD
RθJA
TJ
TSTG
Drain-source voltage
Gate-source voltage
Continuous drain current
Pulsed drain current
Power dissipation
Thermal resistance from Junction to ambient
Junction temperature
Storage temperature
Value
-30
±20
-5.1
-8
-20
2.5
50
150
-55 ~+150
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol
Min
Typ
Max
Unit
Off Characteristics
Drain-Source breakdown voltage
Zero gate voltage drain current
Gate-body leakage current
On Characteristics
Gate-threshold voltage
VGS(th)*
Drain-source on-resistance
RDS(ON)*
Forward transconductance
Drain-Source Diode Characteristics
Diode forward voltage
Dynamic Characteristics
Input capacitance
Output capacitance
Reverse transfer capacitance
Switching Characteristics
Total gate charge
Gate-source charge
Gate-drain charge
Turn-on delay time
Turn-on rise time
Turn-off delay time
Turn-off fall time
V(BR)DSS
IDSS
IGSS
gFS*
-1
4
-1
±100
46
70
7
VSD
V
μA
nA
V
V
A
A
W
°C/W
°C
°C
Conditions
VGS=0V, ID=-250μA
VDS=-24V, VGS=0V
VDS=0V, VGS=±20V
-3
53
85
V
mΩ
mΩ
S
-1.2
V
IS=-1.7A, VGS=0V
VDS=-15V, VGS=0V, f=1MHz
Ciss
Coss
Crss
1040
420
150
pF
pF
pF
Qg
Qgs
Qgd
td(on)
tr
td(off)
tf
12
2.2
3
15
13
58
21
nC
nC
nC
nS
nS
nS
nS
*Pulse test ; Pulse width ≤300µs, Duty cycle ≤2% .
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
-30
Unit
E-mail:hkt@heketai.com
VDS=VGS, ID=-250μA
VGS=-10V, ID=-5.1A
VGS=-4.5V, ID=-4.2A
VDS=-15V, ID=-4.5A
VGS=-10V,VDS=-15V,ID=-5.1A
VGS=-10V, VDD=-15V,
RGEN=6Ω, ID=-1A
1/6
HMP9435
TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS
ton
tr
td(on)
toff
tf
td(off)
90%
VOUT
90%
INVERTED
10%
10%
90%
VIN
50%
50%
10%
PULSE WIDTH
Figure 2:Switching Waveforms
PD Power(W)
ID- Drain Current (A)
Figure 1:Switching Test Circuit
TJ-Junction Temperature(℃)
Figure 4 Drain Current
Rdson On-Resistance(mΩ)
Figure 3 Power Dissipation
Vds Drain-Source Voltage (V)
Figure 5 Output CHARACTERISTICS
Figure 6 Drain-Source On-Resistance
2/6
HMP9435
Normalized On-Resistance
Vgs Gate-Source Voltage (V)
Figure 8 Drain-Source On-Resistance
C Capacitance (pF)
Figure 7 Transfer Characteristics
Figure 10 Capacitance vs Vds
Is- Reverse Drain Current (A)
Figure 9 Rdson vs Vgs
Qg Gate Charge (nC)
Figure 11 Gate Charge
Vsd Source-Drain Voltage (V)
Figure 12 Source- Drain Diode Forward
3/6
HMP9435
Safe Operation Area
r(t),Normalized Effective
Transient Thermal Impedance
Figure 13
Square Wave Pluse Duration(sec)
Figure 14 Normalized Maximum Transient Thermal Impedance
4/6
HMP9435
SOP-8 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
1.350
1.750
0.053
0.069
A1
0.100
0.250
0.004
0.010
A2
1.350
1.550
0.053
0.061
b
0.330
0.510
0.013
0.020
c
0.170
0.250
0.007
0.010
D
4.800
5.000
0.189
0.197
e
0.050(BSC)
1.270(BSC)
E
5.800
6.200
0.228
0.244
E1
3.800
4.000
0.150
0.157
L
0.400
1.270
0.016
0.050
θ
0°
8°
0°
8°
SOP-8 Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
5/6
HMP9435
SOP-8 Tape and Reel
SOP-8 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOP-8
6.40
5.40
2.10
Ø1.50
1.75
5.50
4.00
8.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOP-8 Tape Leader and Trailer
SOP-8 Reel
REEL OPTION
13 ’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø330.00
100.00
13.00
R151.00
R56.00
R6.50
12.40
17.60
±2
±1
±1
±1
±1
±1
±1
±1
6/6
很抱歉,暂时无法提供与“AO9435”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.36002
- 100+0.33602
- 300+0.31202
- 500+0.28801
- 2000+0.27601
- 5000+0.26881
