Plastic-Encapsulate Transistors
BCX51/52/53 (PNP)
FEATURES
IC = -1A Continuous Collector Current
Low Saturation Voltage VCE(sat) < -500mV @ -0.5A
Epitaxial Planar Die Construction
1. BASE
Complementary NPN types: BCX54, 55, and 56
SOT-89
2. COLLECTO
3. EMITTER
Product
BCX51
BCX51-10
BCX51-16
BCX52
BCX52-10
BCX52-16
BCX53
BCX53-10
BCX53-16
Marking
AA
AC
AD
AE
AG
AM
AH
AK
AL
Maximum Ratings (Ta=25
unless otherwise noted)
Characteristic
Symbol
BCX51
BCX52
BCX53
Unit
Collector-Base Voltage
VCBO
-45
-60
-100
V
Collector-Emitter Voltage
VCEO
-45
-60
-80
V
Emitter-Base Voltage
VEBO
-5
IC
-1
Peak Pulse Collector Current
ICM
-1.5
Continuous Base Current
IB
-100
Peak Pulse Base Current
IBM
-200
mA
Power Dissipation (Note 1)
PD
1
W
TJ, TSTG
-65 to +150
°C
Operating and Storage Temperature Range
ELECTRICAL CHARACTERISTICS ( @ Ta=25
Characteristic
BCX52
Breakdown Voltage
BCX53
Collector-Emitter
BCX51
BCX52
Breakdown Voltage (Note 2)
A
unless otherwise specified)
Symbol
BCX51
Collector-Base
V
BVCBO
BVCEO
BCX53
Min
-45
-60
-100
-45
-60
-80
Typ
Max
Unit
V
IC = -100µA
V
IC = -10mA
IE = -10µA
BVEBO
-5
V
Collector Cut-off Current
ICBO
-0.1
-20
µA
Emitter Cut-off Current
IEBO
Emitter-Base Breakdown Voltage
All versions
Static Forward Current Transfer Ratio (Note 2)
hFE
25
40
25
-20
250
nA
160
250
-0.5
-1.0
V
V
VCE(sat)
Base-Emitter Turn-On Voltage (Note 2)
VBE(on)
fT
150
MHz
Cobo
25
pF
Transition Frequency
Output Capacitance
VCB = -30V, TA = 150°C
VEB = -4V
IC = -150mA, VCE = -2V
Collector-Emitter Saturation Voltage (Note 2)
16 gain grp
VCB = -30V
IC = -5mA, VCE = -2V
IC = -500mA, VCE = -2V
63
100
10 gain grp
Test Condition
IC = -500mA, IB = -50mA
IC = -50mA, VCE = -10V
f = 100MHz
VCB = -10V, f = 1MHz
Notes: 1. For a device surface mounted on 25 mm X 25mm FR4 PCB with high coverage of single sided 1 oz copper, in still air conditions; the device is measured
when operating in a steady-state condition.
Notes: 2. Measured under pulsed conditions. Pulse width ≤ 300µs. Duty cycle ≤ 2%.
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P1
0.5
-VCE(SAT), COLLECTOR-EMITTER
SATURATION VOLTAGE (V)
1.0
0.8
TA = -55°C
0.6
TA = 25°C
T A = 85°C
0.4
T A = 150°C
0.2
0.4
0.3
TA = 150°C
0.2
TA = 85°C
TA = 25°C
0.1
VCE = -2V
TA = -55°C
0.01
0.1
1
-IC, COLLECTOR CURRENT(A)
Fig 3 Typical Base-Emitter Turn-On Voltage
vs. Collector Current
10
0.01
0.1
1
10
-IC, COLLECTOR CURRENT (A)
Fig. 4 Typical Collector-Emitter Saturation Voltage
1.2
300
1.0
0.8
T A = -55°C
0.6
TA = 25°C
TA = 85°C
0.4
TA = 150°C
0.2
IC / IB = 10
fT, GAIN-BANDWIDTH PRODUCT (MHz)
-VBE(SAT), BASE-EMITTER SATURATION VOLTAGE (V)
-VBE(ON), BASE-EMITTER TURN-ON VOLTAGE (V)
BCX51/52/53 Typical Characteristics
250
200
150
100
VCE = -5V
f = 100MHz
50
0.01
0.1
1
10
Fig. 5 Typical Base-Emitter Saturation Voltage
60
80
100
-IC, COLLECTOR CURRENT (mA)
Fig. 6 Typical Gain-Bandwidth Product vs. Collector Current
160
140
f = 1MHz
CAPACITANCE(pF)
120
100
80
Cibo
60
40
Cobo
40
VR, REVERSE VOLTAGE (V)
Fig. 7 Typical Capacitance Characteristics
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P2
很抱歉,暂时无法提供与“BCX53-AH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.34798
- 100+0.32478
- 300+0.30159
- 500+0.27839
- 2000+0.26679
- 5000+0.25983
