HNR-1707 SPEC V1.0
规格书
Specification
品名
HNR-1707
1707
C129400
Model name
PROPRIETARY
Huaneng Electronic co.,Ltd.
CONFIDENTIAL
Version #
Spec V1.0
制作日期
Date
2017/08/29
准备
Prepared
Yang shu yin
Acoustic specialist,R&D Dept.
审核
Approved
Zhang chang hua
Executive Manager,R&D Dept.
江苏华能电子有限公司
Components Operating Div.
HuanengElectronic co.,Ltd.
1.适用范围:本规范适用于HNR-1707 蜂鸣器。
This specifications apply the HNR-1707 buzzer.
2.基本规格/General specification
项目/Item
HNR-1707 SPEC V1.0
规格/Spec
条件/Condition
1
额定电压
Rated voltage
3VDC
2
工作电压
Operation voltage
1~30VAC
3
声压
Sound Pressure Level=SPL
≥ 80dB
4
振荡频率
Oscillation frequency
4000
4000±500Hz
5
电流
Rated Current
≤5mA
6
工作温度范围
Range of operation temperature
-20~+70℃
7
保存温度范围
Range of preservation temperature
-30~+80℃
8
针脚强度
Terminal strength
10N
拉负荷方向的终端轴
Pull load on the direction of the
terminal axis
9
外部尺寸
Externals size
Φ17x7
参阅附图
Refer to the attached drawing
10
重量
Mass
1.0g
测试环境:标准状态,标准驱动电路,
额定电压
测试距离:0.1m
Standard State,Standard Drive Circuit.
Rated voltage,Distance at 0.1m
声压 ≥85dB
SPL ≥85dB
☆标准状态:常温(15~35℃),湿度(25~85%相对湿度),空气压力
空气压力(860~1060hpa)
在假设的情况判断,测试是-基本状态下进行。
Standard State:Ordinary Temp(15~35℃),Humidity(25~85%RH),Air
85%RH),Air pressure(860~1060hPa)
pressure(860
In case of doubtful judgment,the test is re-performed
performed under Basic State.
☆基本情况:温度。(20±2℃),湿度(60~70%相对湿度),空气压力
空气压力(860~1060hpa)
Basic State: Temp.(20±2℃),Humidity(60~70%RH),Air pressure(860~
~1060hPa)
3.可靠性规范/Reliability
/Reliability specification
HNR
HNR-1707
SPEC V1.0
项目/Item
试验条件/Test condition
判断标准/Criteria
1
高温保存试验
High
temperature
Preservation
+85℃环境下放置24小时
Exposure to +85℃ for 24 hrs.
2
低温保存试验
Low
temperature
preservation
-20℃环境下放置24小时
Exposure to -20℃ for 24 hrs.
经过测试,符合规格,
没有任何不合格的外
观和性能
After the test the
part shall meet
specificati
-ons without any
degra.
3
高温试验
High
temperature
Shock
4
低温试验
Low
temperature
Shock
5
常温寿命试验
Ordinary
Temp.Life
常温(25℃±10℃)电压3VDC连续测试48
48小时
Driving the sounder at 3VDC for 48hrs
hrs in the room
temperature(25℃±10℃)
6
高温寿命试验
High
Temp.Life
高温(+85℃)电压3VDC连续测试2小时
Driving the sounder at 3VDC for 2hrs
hrs in the low
temperature(+85℃)
7
低温寿命试验
Low Temp.Life
低温(-20℃)电压3VDC连续测试2小时
hrs in the low
temperature(-20℃)
8
端子拉力试验
Lead strength
10N的拉力在端子上拉10±1秒
Pull load on the direction of the terminal axis for
10±1 sec.
9
跌落试验
Free drop
70cm高自由掉落到厚40mm的木板上,每个方向一次
每个方向一次
Free drop,70cm height, on wood boad (t40mm)
X,Y,Z 3Direction 1time each, total 3times.
端子可焊性试
验
Solderability
260±5℃焊接温度。时间:5±0.5sec。
Temp.260±5℃
Soaking Time:5±0.5sec
1
排除弯曲的针
Exclude bending of
Pin
端子95%必须覆盖着焊料
95% surface of lead
pins must be covered
with fresh solder and
no soldering holes
Should be found
引用规格
HNR-1707
江苏华能电子有限公司
Jiangsu huaneng electronics co.,Ltd
产品特征图:
很抱歉,暂时无法提供与“HNR-1707”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.75901
- 10+0.73151
- 100+0.64901
- 500+0.63251
