MMF5.0A/CA
SMF5.0A/CA---SMF5.0A/CA--SMF190A/CA
---MMF190A/CA
SMF190A/CA
200W Surface Mount
Transient Voltage
Suppressors
Features
z
z
z
z
z
z
z
z
z
Working peak reverse voltage range – 5.0V to 190V.
Peak power dissipation 200W @10 x 1000 us Pulse
Low profile package.
Excellent clamping capability.
Glass passivated junction.
Fast response time: typically less than 1 ns for Uni-direction.
Typical IR less than 1uA above 10V.
Plastic material has UL flammability classification 94V-O
RoHS compliant in lead-free versions
SOD-123FL
Mechanical Characteristics
CASE: Void-free, Molded Plastic over glass passivated junction..
Mounting Position: Any
Polarity: by cathode band denotes uni-directional device.
Qualified max reflow temperature: 260°C
Maximum Ratings And Characteristics @ 25°C Ambient Temperature (unless otherwise noted)
Parameter
Symbol
Value
Units
Peak Pulse Power Dissipation on 10/1000 us Waveform (Note 1, 2, FIG.1)
PPPM
Min 200
W
Peak Pulse Current of on 10/1000us Waveform (Note 1, FIG.3)
IPPM
See Table 1
Amps
TJ
-55 to 150
°C
TSTG
-55 to 150
°C
Operating Junction Temperature Range
Storage Temperature Range
Notes:
1. Non-repetitive current pulse, per Fig.3 and derated above TA=25°C per Fig.2.
1/4
4/4
MMF5.0A/CA
---MMF190A/CA
SMF190A/CA
Electrical Specification @ Tamb 25°C
Type
Number
Marking
Reverse Breakdown
Stand-Off
Voltage
Voltage
Min. @IT
Breakdown
Voltage
Max. @ IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRMW
Uni
Bi
Uni
Bi
VRMW(V)
VBR MIN(V)
VBR MAX(V)
IT (mA)
VC(V)
IPP(A)
IR(uA)
MMF5.0A
SMF5.0A
MMF5.0CA
SMF5.0CA
5.0A
5.0CA
5.0
6.40
7.25
10
9.2
21.7
400.0
MMF6.0A
SMF6.0A
MMF6.0CA
SMF6.0CA
6.0A
6.0CA
6.0
6.67
7.67
10
10.3
19.4
400.0
MMF6.5A
SMF6.5A
MMF6.5CA
SMF6.5CA
6.5A
6.5CA
6.5
7.22
8.30
10
11.2
17.9
250.0
SMF7.0A
MMF7.0A
MMF7.0CA
SMF7.0CA
7.0A
7.0CA
7.0
7.78
8.95
10
12
16.7
100.0
MMF7.5A
SMF7.5A
MMF7.5CA
SMF7.5CA
7.5A
7.5CA
7.5
8.33
9.58
1.0
12.9
15.5
50.0
MMF8.0A
SMF8.0A
MMF8.0CA
SMF8.0CA
8.0A
8.0CA
8.0
8.89
10.23
1.0
13.6
14.7
25.0
MMF8.5A
SMF8.5A
MMF8.5CA
SMF8.5CA
8.5A
8.5CA
8.5
9.44
10.82
1.0
14.4
13.9
10.0
MMF9.0A
SMF9.0A
MMF9.0CA
SMF9.0CA
9.0A
9.0CA
9.0
10.0
11.5
1.0
15.4
13
5.0
MMF10A
SMF10A
MMF10CA
SMF10CA
10A
10CA
10
11.1
12.8
1.0
17
11.8
2.5
MMF11A
SMF11A
MMF11CA
SMF11CA
11A
11CA
11
12.2
14.0
1.0
18.2
11
2.5
MMF12A
SMF12A
MMF12CA
SMF12CA
12A
12CA
12
13.3
15.3
1.0
19.9
10.1
2.5
MMF13A
SMF13A
MMF13CA
SMF13CA
13A
13CA
13
14.4
16.5
1.0
21.5
9.3
1.0
MMF14A
SMF14A
MMF14CA
SMF14CA
14A
14CA
14
15.6
17.9
1.0
23.2
8.6
1.0
MMF15A
SMF15A
MMF15CA
SMF15CA
15A
15CA
15
16.7
19.2
1.0
24.4
8.2
1.0
MMF16A
SMF16A
MMF16CA
SMF16CA
16A
16CA
16
17.8
20.5
1.0
26
7.7
1.0
MMF17A
SMF17A
MMF17CA
SMF17CA
17A
17CA
17
18.9
21.7
1.0
27.6
7.2
1.0
MMF18A
SMF18A
MMF18CA
SMF18CA
18A
18CA
18
20.0
23.3
1.0
29.2
6.8
1.0
MMF20A
SMF20A
MMF20CA
SMF20CA
20A
20CA
25.5
1.0
32.4
6.2
1.0
MMF22A
SMF22A
MMF22CA
SMF22CA
22A
22CA
22
24.4
28.0
1.0
35.5
5.6
1.0
MMF24A
SMF24A
MMF24CA
SMF24CA
24A
24CA
24
26.7
30.7
1.0
38.9
5.1
1.0
MMF26A
SMF26A
MMF26CA
SMF26CA
26A
26CA
26
28.9
33.2
1.0
42.1
4.8
1.0
MMF28A
SMF28A
MMF28CA
SMF28CA
28A
28CA
28
31.1
35.8
1.0
45.4
4.4
1.0
MMF30A
SMF30A
MMF30CA
SMF30CA
30A
30CA
30
33.3
38.3
1.0
48.4
4.1
1.0
MMF33A
SMF33A
MMF33CA
SMF33CA
33A
33CA
33
36.7
42.2
1.0
53.3
3.8
1.0
MMF36A
SMF36A
MMF36CA
SMF36CA
36A
36CA
36
40.0
46.0
1.0
58.1
3.4
1.0
MMF40A
SMF40A
MMF40CA
SMF40CA
40A
40CA
40
44.4
51.1
1.0
64.5
3.1
1.0
MMF43A
SMF43A
MMF43CA
SMF43CA
43A
43CA
43
47.8
54.9
1.0
69.4
2.9
1.0
MMF45A
SMF45A
MMF45CA
SMF45CA
45A
45CA
45
50.0
57.5
1.0
72.7
2.8
1.0
MMF48A
SMF48A
MMF48CA
SMF48CA
48A
48CA
48
53.3
61.3
1.0
77.4
2.6
1.0
MMF51A
SMF51A
MMF51CA
SMF51CA
51A
51CA
51
56.7
65.2
1.0
82.4
2.4
1.0
MMF54A
SMF54A
MMF54CA
SMF54CA
54A
54CA
54
60.0
69.0
1.0
87.1
2.3
1.0
MMF58A
SMF58A
MMF58CA
SMF58CA
58A
58CA
58
64.4
74.1
1.0
93.6
2.1
1.0
MMF60A
SMF60A
MMF60CA
SMF60CA
60A
60CA
60
66.7
76.7
1.0
96.8
1.8
1.0
MMF64A
SMF64A
MMF64CA
SMF64CA
64A
64CA
64
71.1
81.8
1.0
103
1.7
1.0
MMF70A
SMF70A
MMF70CA
SMF70CA
70A
70CA
70
77.8
89.5
1.0
113
1.5
1.0
MMF75A
SMF75A
MMF75CA
SMF75CA
75A
75CA
75
83.3
95.8
1.0
121
1.4
1.0
MMF78A
SMF78A
MMF78CA
SMF78CA
78A
78CA
78
86.7
99.7
1.0
126
1.4
1.0
2/4
4/4
MMF5.0A/CA
---MMF190A/CA
SMF190A/CA
Type
Number
Uni
Marking
Bi
Reverse Breakdown Breakdown
Stand-Off
Voltage
Voltage
Voltage
Min. @IT
Max. @ IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRMW
Uni
Bi
VRMW(V)
VBR MIN(V)
VBR MAX(V)
IT (mA)
VC(V)
IPP(A)
IR(uA)
MMF85A
SMF85A
SMF85CA
MMF85CA
85A
85CA
85
94.4
108.2
1.0
137
1.3
1.0
MMF90A
SMF90A
SMF90CA
MMF90CA
90A
90CA
90
100.0
115.5
1.0
146
1.2
1.0
MMF100A
SMF100A
MMF100CA
SMF100CA
100
100C
100
111.0
128.0
1.0
162
1.1
1.0
MMF110A
SMF110A
SMF110CA
MMF110CA
110
110C
110
122.0
140.5
1.0
177
1.0
1.0
MMF120A
SMF120A
MMF120CA
SMF120CA
120
120C
120
133.0
153.0
1.0
193
0.9
1.0
MMF130A
SMF130A
MMF130CA
SMF130CA
130
130C
130
144.0
165.5
1.0
209
0.8
1.0
MMF150A
SMF150A
MMF150CA
SMF150CA
150
150C
150
167.0
192.5
1.0
243
0.7
1.0
MMF160A
SMF160A
MMF160CA
SMF160CA
160
160C
160
178.0
205.0
1.0
259
0.7
1.0
MMF170A
SMF170A
MMF170CA
SMF170CA
170
170C
170
189.0
217.5
1.0
275
0.6
1.0
MMF180A
SMF180A
MMF180CA
SMF180CA
180
180C
180
198.0
230.4
1.0
292
0.6
1.0
MMF190A
SMF190A
MMF190CA
SMF190CA
190
190C
190
209.0
243.2
1.0
308
0.5
1.0
Ratings and Characteristic Curves TA=25°C unless otherwise noted
3/4
4/4
MMF5.0A/CA
---MMF190A/CA
SMF190A/CA
Package Outline Dimensions and Pad Layouts
SOD-123FL
Dim
Millimeters
Min
4/4
Max
Inches
Min
Max
A
3.40
3.85
0.142
0.150
B
2.50
2.90
0.098
0.114
C
1.40
1.80
0.055
0.071
D
0.90
1.35
0.035
0.053
E
0.50
1.10
0.020
0.043
G
0.25
0.010
H
0.20
0.008
很抱歉,暂时无法提供与“SMF36CA”相匹配的价格&库存,您可以联系我们找货
