Liown Semiconductor Co.,Ltd.
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
SMF Series Datasheet
Description
The SMF series is designed specifically to protect sensitive electronic equipment from voltage transients
induced by lightning and other transient voltage events. SMF package is 50% smaller in footprint when compare to
SMA package and deliverying one of the low height profiles (1.2mm) in the industry.
Features
IEC61000-4-2 ESD 15KV Air, 8KV contact compliance
SOD-123FL surface mount package
Protects one I/O line
Peak power dissipation of 1000W under 8/20μs waveform
Low leakage current
Solid-state silicon avalanche technology
RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
Applications
SMF devices are ideal for the protection of I/O interfaces, VCC bus and other vulnerable circuit used in cellular
phones, portable devices, business machines, power supplies and other consumer applications.
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 200
Watts
Peak pulse power (tp=8/20μs waveform)
PPPM
Minimum 1000
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
1.0
Watts
VF
3.5
V
IFSM
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
100
℃/W
Typical thermal resistance junction to ambient
RθJA
220
℃/W
Steady state power dissipation at TL=75℃ (Fig.5)
Maximum Instantaneous Forward Voltage at 12A for
Unidirectional Only
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Ranges.
Notes: 1. Non-repetitive current pulse, per Fig.3 and Derating above TA=25℃ per Fig.2.
2. Each terminal is surface Mounted on the 5.0mm×5.0mm (0.03mm thick) copper pads.
3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum.
www.liownsemi.com
掌握芯技术 Core Technology
(V2)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Dimensions (SOD123FL)
Dimensions
D
C
F
B
Soldering Pad Layout Recommended
A
Inches
Millimeters
Min.
Max.
Min.
Max.
A
0.138
0.154
3.50
3.90
B
0.102
0.118
2.60
3.00
C
0.030
0.043
0.75
1.10
D
0.063
0.079
1.60
2.00
1.00
F
H
1.10
h
2.00
0.031Typ.
0.80Typ.
H
0.035
0.053
0.90
1.35
h
0.005
0.009
0.12
0.22
Electrical Characteristics (TA=25℃)
Part Number
Device
Reverse
Breakdown
Marking
Stand-Off
Voltage
Code
Voltage
@IT
Maximum
Test
Clamping
Current
Voltage
@IPP
Peak
Reverse
Pulse
Leakage
Current
@VR
Uni
Bi
UNI
BI
VR(V)
Min(V)
Max(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMF5.0A
SMF5.0CA
KE
AE
5
6.4
7
10
9.2
21.8
500
SMF6.0A
SMF6.0CA
KG
AG
6
6.67
7.37
10
10.3
19.4
400
SMF6.5A
SMF6.5CA
KK
AK
6.5
7.22
7.98
10
11.2
17.9
350
SMF7.0A
SMF7.0CA
KM
AM
7
7.78
8.6
10
12.0
16.7
200
SMF7.5A
SMF7.5CA
KP
AP
7.5
8.33
9.21
1
12.9
15.5
100
SMF8.0A
SMF8.0CA
KR
AR
8
8.89
9.83
1
13.6
14.7
50
SMF8.5A
SMF8.5CA
KT
AT
8.5
9.44
10.4
1
14.4
13.9
SMF9.0A
SMF9.0CA
KV
AV
9
10
11.1
1
15.4
13.0
10
SMF10A
SMF10CA
KX
AX
10
11.1
12.3
1
17.0
11.8
5
SMF11A
SMF11CA
KZ
AZ
11
12.2
13.5
1
18.2
11.0
3
SMF12A
SMF12CA
LE
BE
12
13.3
14.7
1
19.9
10.1
1
SMF13A
SMF13CA
LG
BG
13
14.4
15.9
1
21.5
9.3
1
SMF14A
SMF14CA
LK
BK
14
15.6
17.2
1
23.2
8.6
1
SMF15A
SMF15CA
LM
BM
15
16.7
18.5
1
24.4
8.2
1
SMF16A
SMF16CA
LP
BP
16
17.8
19.7
1
26.0
7.7
1
SMF17A
SMF17CA
LR
BR
17
18.9
20.9
1
27.6
7.3
1
SMF18A
SMF18CA
LT
BT
18
1
29.2
6.9
1
SMF20A
SMF20CA
LV
BV
24.5
1
32.4
6.2
1
SMF22A
SMF22CA
LX
BX
22
24.4
26.9
1
35.5
5.7
1
SMF24A
SMF24CA
LZ
BZ
24
26.7
29.5
1
38.9
5.2
1
SMF26A
SMF26CA
ME
CE
26
28.9
31.9
1
42.1
4.8
1
SMF28A
SMF28CA
MG
CG
28
31.1
34.4
1
45.4
4.4
1
SMF30A
SMF30CA
MK
CK
30
33.3
36.8
1
48.4
4.2
1
SMF33A
SMF33CA
MM
CM
33
36.7
40.6
1
53.3
3.8
1
www.liownsemi.com
(V2)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Part Number
Device
Reverse
Breakdown
Marking
Stand-Off
Voltage
Code
Voltage
@IT
Maximum
Test
Clamping
Current
Voltage
@IPP
Peak
Reverse
Pulse
Leakage
Current
@VR
Uni
Bi
UNI
BI
VR(V)
Min(V)
Max(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMF36A
SMF36CA
MP
CP
36
40
44.2
1
58.1
3.5
1
SMF40A
SMF40CA
MR
CR
40
44.4
49.1
1
64.5
3.1
1
SMF43A
SMF43CA
MT
CT
43
47.8
52.8
1
69.4
2.9
1
SMF45A
SMF45CA
MV
CV
45
50
55.3
1
72.7
2.8
1
SMF48A
SMF48CA
MX
CX
48
53.3
58.9
1
77.4
2.6
1
SMF51A
SMF51CA
MZ
CZ
51
56.7
62.7
1
82.4
2.5
1
SMF54A
SMF54CA
NE
DE
54
60
66.3
1
87.1
2.3
1
SMF58A
SMF58CA
NG
DG
58
64.4
71.2
1
93.6
2.2
1
SMF60A
SMF60CA
NK
DK
60
66.7
73.7
1
96.8
2.1
1
SMF64A
SMF64CA
NM
DM
64
71.1
78.6
1
103.0
2.0
1
SMF70A
SMF70CA
NP
DP
70
77.8
86
1
113.0
1.8
1
SMF75A
SMF75CA
NR
DR
75
83.3
92.1
1
121.0
1.7
1
SMF78A
SMF78CA
NT
DT
78
86.7
95.8
1
126.0
1.6
1
SMF85A
SMF85CA
NV
DV
85
94.4
104
1
137.0
1.5
1
SMF90A
SMF90CA
NX
DX
90
100
111
1
146.0
1.4
1
SMF100A
SMF100CA
NZ
DZ
100
111
123
1
162.0
1.3
1
SMF110A
SMF110CA
PE
EE
110
122
135
1
177.0
1.2
1
SMF120A
SMF120CA
PG
EG
120
133
147
1
193.0
1.1
1
SMF130A
SMF130CA
PK
EK
130
144
159
1
209.0
1.0
1
SMF150A
SMF150CA
PM
EM
150
167
185
1
243.0
0.8
1
SMF160A
SMF160CA
PP
EP
160
178
197
1
259.0
0.8
1
SMF170A
SMF170CA
PR
ER
170
189
209
1
275.0
0.8
1
www.liownsemi.com
(V2)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Ratings and Characteristic Curves (Ta=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (I PP)
Derating in Percentage %
PPP - Peak Pulse Power (W)
10000
1000
100
10
0.1
1
10
100
1000
tP-Pulse Duration (µs)
60
Tjmax=150℃
40
75
100 125 150
TA-Ambient Temperature (℃)
175
Figure 4. Typical Junction Capacitance
TJ =25℃
Pulse Width(td ) is defined as
the point where the peak
current decays to 50% of IPP M
tr=10µs
1000
Uni-directional V=0V
100
Cj (pF)
Peak Value IPPM
Half Value IPPM (IPPM/2)
50
10/1000µs Waveform
as defined by R.E.A
1.0
2.0
3.0
Bi-directional V=0V
10
td
Figure 5. Steady State Power Dissipation Derating
Curve
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
4.0
1
Time (ms)
10
100
1000
VBR-Reverse Breakdown Voltage (V)
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
1.0
35
Peak Forward Surve Current (A)
PM(AV), Steady State Power Dissipation (W)
25
10000
150
Peak Pulse Current, %IRSM
80
10000
Figure 3. Pulse Waveform
0.75
0.50
Tjmax=150℃
0.25
www.liownsemi.com
50
75
100 125 150
TL-Lead Temperature(℃)
175
Tj = Tj max.
8.3 ms Single Half Sine-Wave
30
25
10
5
1
10
5
50
Number of Cycles at 60Hz
100
(V2)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Marking Code
Cathode Marking
XY
XY
XY
Device Code
Device Code
Part Number Code
SMF
XX C A
A:5% VBR Tolerance
C:Bidirectional;No C:Unidirectional
VR Voltage
200W Series Code
Soldering Parameters
www.liownsemi.com
(V2)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Packaging Specification
Tape
For Uni-Devices
7 Inches Reel
d
D
www.liownsemi.com
W
D
Φ178.0±2.0
d
Φ13.0
W
9.5
Quantity: 3000PCS/Reel
(V2)
很抱歉,暂时无法提供与“SMF36CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.12090
- 10+0.11160
- 30+0.10974
- 100+0.10416
