S1AF-S1MF
SURFACE MOUNT GENERAL RECTIFIER
FEATURES
For surface mounted application
Low forward voltage drop
High current capability
Easy pick and place
High surge current capability
SMAF
Plastic material used carries Underwriters
Laboratory Classification 94V-0
10
MECHANICAL DATA
Cathode
Case: SMAF Molded plastic
Terminals: Pure tin plated, lead free
Polarity: Indicated by cathode band
Weight: 27mg (approx.)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive
load. For capacitive load, derate current by 20%.
S1AF
S1BF
S1DF S1GF
VRRM
50
100
200
Maximum RMS Voltage
VRMS
35
70
Maximum DC Blocking Voltage
VDC
50
100
Maximum Average Forward Rectified Current at
TL =100 °C
I(AV)
1
A
Peak Forward Surge Current 8.3ms Single Half
Sine-wave Superimposed on Rated Load (JEDEC)
IFSM
30
A
Maximum Instantaneous Forward Voltage at 1 A
VF
1.1
V
Maximum DC Reverse Current
at Rated DC Blocking Voltage
IR
5
200
µA
Typical Junction Capacitance 1)
CJ
15
pF
Maximum Thermal Resistance 2)
RθJA
75
°C/W
Operating and Storage Temperature Range
TJ, TS
- 50 to + 150
°C
Parameter
Symbol
Maximum Repetitive Peak Reverse Voltage
TA = 25 °C
TA =125 °C
S1JF
S1KF
S1MF
Unit
400
600
800
1000
V
140
280
420
560
700
V
200
400
600
800
1000
V
Note 1. Measured at 1 MHz and Applied Vr=4.0 volts
2. P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
E-mail:hkt@heketai.com
1/3
S1AF-S1MF
Typical Characteristics
1.0
25 50 75 100 125 150175
LEAD TEMPERATURE .o C
25
15
10
5
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
Fig. 1-FORWARD CURRENT
DERATING CURVE
10
Tj =125o C
Tj =75o C
0.1
Tj =25o C
0.01
0.001
60
1
2
5
10
100
NUMBER OF CYCLES AT 60 Hz
Fig. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
100
1
8.3ms Single Half Sine Wave
(JEDEC Method)
PERCENT OF PEAK REVERSE VOLTAGE, %
INSTANTANEOUS FORWARD CURRENT,
MICROAMPERES
2.0
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD CURRENT,
AMPERES
30
SINGLE PHASE
HALF WAVE 60Hz
RESISTIVE OR
INDUCTIVE LOAD
P.C.B MOUNTED
ON 0.315x0.315"(8.0x8.0mm)
COPPER PAD AREAS
100
50
5
2
1
0.5
0.2
0.1
0.05
0.02
0.01
0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0
VOLTAGE , VOLTS
Fig. 4-TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
Fig. 3-TYPICAL REVERSE
CHARACTERISTICS
500
200
100
50
Units Mounted On
20in2 (5.4mm 2 )+0.5mil
inches(0.013mm)
Thick Copper Land Areas
CAPACITANCE. pF
THERMAL IMPEDANCE (oC/W)
1000
5
2
1
0.01
0.1
1
10
Tj =25 oC
f=1.0MHz
Vsig=50mVp-p
50
5
2
1
10
100
1000
100
REVERSE VOLTAGE VOLTS
Fig. 5-TRANSIENT THERMAL IMPEDANCE
100
Fig. 6-TYPICAL JUNCTION CAPACITANCE
2/3
S1AF-S1MF
SMAF Package Outline Dimensions
∠ALL ROUND
C
A
∠ALL ROUND
HE
E
A
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
43
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
E
e
A
pad
D
V M
7°
3/3
很抱歉,暂时无法提供与“S1MF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.03268
- 100+0.03050
- 300+0.02832
- 500+0.02615
- 2000+0.02506
- 5000+0.02440
