S1MF
S1MF
    SK(台湾时科)
    SMAF
    整流二极管 VRRM=1KV If=1A VF=1.1V CJ=4pF SMAF
S1MF 数据手册
S1AF THRU S1MF Forward Current - 1 A Surface Mount General Purpose Silicon Rectifiers Reverse Voltage - 50 to 1000 V PINNING FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Juntion • Easy to pick and place • Lead free in comply with EU RoHS 2011/65/EU directives PIN MECHANICAL DATA • Case: SMAF • Terminals: Solderable per MIL-STD-750, 750, Method 2026 • Approx. Weight: 27mg 0.00086oz DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code:S1A-S1M Simplified outline SMAF L and symbol Maximum Ratings and Electrical characteristics aracteristics Ratings at 25°C C ambient temperature unless otherwise specified.Single phase half-wave half wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols Parameter S1AF S1BF S1DF S1GF S1JF S1KF S1MF Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at Ta = 65 °C I F(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) I FSM 25 A Maximum Instantaneous Forward Voltage at 1 A VF 1.1 V IR 5 50 μA Cj 4 pF RθJA 180 °C/W T j , T stg -55 ~ +150 °C Maximum DC Reverse Current at Rated DC Blocking Voltage Typical Junction Capacitance Typical Thermal Resistance Ta = 25 °C Ta =125 °C 1) 2) Operating and Storage Temperature Range 1)Measured at 1 MHz and applied reverse voltage of 4 V D.C 2)Thermal resistance from junction to ambient at 0.375" (9.5 mm) lead length, P.C.B. mounted REV.08 1 of 3 S1AF THRU S1MF Fig.2 Typical Instaneous Reverse Characteristics Fig.1 Forward Current Derating Curve Instaneous Reverse Current ( μ A) Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =150°C T J =125°C 10 T J =100°C 1.0 T J =75°C T J =50°C 0.1 T J =25°C 0.01 12 Junction Capacitance ( pF) 1.0 2 5° C TJ = °C 00 TJ =1 =1 50 °C 0.5 TJ Instaneous Forward Current (A) 800 Fig.4 Typical Junction Capacitance 0.2 0.7 0.8 0.9 1.0 10 8 6 4 2 0 0 1.1 Instaneous Forward Voltage (V) REV.08 600 Instaneous Reverse Voltage (V) Fig.3 Typical Forward Characteristic 0.1 0.6 400 200 0 Ambient Temperature (°C) 5 10 15 20 25 30 Reverse Voltage (V) 2 of 3 35 40 S1AF THRU S1MF PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMAF ∠ALL ROUND C A ∠ALL ROUND HE VM g Top View mil Bottom View A C D E e g HE max 1.1 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 43 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm g pad e E A pad D E A 7° The recommended mounting pad size 2.2 (86 ) 1.6 (63 ) 1.8 (71 ) 1.6 (63 ) Unit: mm (mil) REV.08 ∠ 3 of 3
很抱歉,暂时无法提供与“S1MF”相匹配的价格&库存,您可以联系我们找货
S1MF
  • 1+0.05085
  • 100+0.04746
  • 300+0.04407
  • 500+0.04068
  • 2000+0.03898
  • 5000+0.03797
库存:2980
S1MF
    • 50+0.07935
    • 500+0.06336
    • 3000+0.05448
    • 6000+0.04914
    • 24000+0.04452
    • 51000+0.04204
    库存:674
