Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
DISCRETE SEMICONDUCTORS
DATA SHEET
dbook, halfpage
M3D109
PBSS5480X
80 V, 4 A
PNP low VCEsat (BISS) transistor
Product data sheet
Supersedes data of 2004 Jun 8
2004 Nov 08
NXP Semiconductors
Product data sheet
80 V, 4 A
PBSS5480X
FEATURES
QUICK REFERENCE DATA
• High hFE and low VCEsat at high current operation
SYMBOL
• High collector current IC: 4 A
VCEO
collector-emitter voltage
−80
V
IC
collector current (DC)
−4
A
ICM
peak collector current
−10
A
RCEsat
equivalent on-resistance
75
mΩ
• High efficiency leading to less heat generation.
APPLICATIONS
PARAMETER
MAX.
UNIT
• Medium power peripheral drivers (e.g. fans and motors)
PINNING
• Strobe flash units for digital still cameras and mobile
phones
PIN
• Inverter applications (e.g. TFT displays)
• Power switch for LAN and ADSL systems
• Medium power DC-to-DC conversion
DESCRIPTION
1
emitter
2
collector
3
base
• Battery chargers.
DESCRIPTION
PNP low VCEsat (BISS) transistor in a SOT89 (SC-62)
plastic package.
NPN complement: PBSS4480X.
2
3
MARKING
TYPE NUMBER
MARKING CODE(1)
PBSS5480X
1
*1Z
3
2
1
sym079
Note
1. * = p: made in Hong Kong.
* = t: made in Malaysia.
* = W: made in China.
Fig.1 Simplified outline (SOT89) and symbol.
ORDERING INFORMATION
PACKAGE
TYPE NUMBER
NAME
PBSS5480X
2004 Nov 08
SC-62
DESCRIPTION
plastic surface mounted package; collector pad for
good heat transfer; 3 leads
2
VERSION
SOT89
NXP Semiconductors
Product data sheet
80 V, 4 A
PBSS5480X
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134).
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
VCBO
collector-base voltage
open emitter
−80
V
VCEO
open base
−80
V
VEBO
emitter-base voltage
open collector
−5
V
IC
note 1
−4
A
ICM
tp ≤ 1 ms or limited by Tj(max)
−10
A
ICRP
repetitive peak collector current
tp ≤ 10 ms; δ ≤ 0.1
−6
A
IB
base current (DC)
−1
A
IBM
peak base current
tp ≤ 1 ms
−2
A
Ptot
total power dissipation
Tamb ≤ 25 °C
notes 2 and 3
2.5
W
note 3
0.55
W
note 4
1
W
note 1
1.4
W
note 5
1.6
W
Tstg
storage temperature
−65
+150
°C
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Notes
1. Device mounted on a printed-circuit board, single-sided copper, tin-plated, mounting pad for collector 6 cm2.
2. Operated under pulsed conditions; pulse width tp ≤ 10 ms; duty cycle δ ≤ 0.1.
3. Device mounted on a printed-circuit board, single-sided copper, tin-plated, standard footprint.
4. Device mounted on a printed-circuit board, single-sided copper, tin-plated, mounting pad for collector 1 cm2.
5. Device mounted on a 7 cm2 ceramic printed-circuit board, 1 cm2 single-sided copper, tin-plated.
2004 Nov 08
3
NXP Semiconductors
Product data sheet
80 V, 4 A
001aaa229
1600
Ptot
(mW)
PBSS5480X
(1)
1200
(2)
800
(3)
400
−50
100
150
200
Tamb (°C)
(1) FR4 PCB; 6 cm2 mounting pad for collector.
(2) FR4 PCB; 1 cm2 mounting pad for collector.
(3) FR4 PCB; standard footprint.
Fig.2 Power derating curves.
2004 Nov 08
4
NXP Semiconductors
Product data sheet
80 V, 4 A
PBSS5480X
THERMAL CHARACTERISTICS
SYMBOL
Rth(j-a)
PARAMETER
CONDITIONS
thermal resistance from junction to ambient
Rth(j-s)
VALUE
UNIT
notes 1 and 2
50
K/W
note 2
225
K/W
note 3
125
K/W
note 4
90
K/W
note 5
80
K/W
16
K/W
in free air
thermal resistance from junction to soldering point
Notes
1. Operated under pulsed conditions; pulse width tp ≤ 10 ms; duty cycle δ ≤ 0.2.
2. Device mounted on a printed-circuit board, single-sided copper, tin-plated, standard footprint.
3. Device mounted on a printed-circuit board, single-sided copper, tin-plated, mounting pad for collector 1 cm2.
4. Device mounted on a printed-circuit board, single-sided copper, tin-plated, mounting pad for collector 6 cm2.
006aaa232
103
Zth
(K/W)
102
(1)
(2)
(3)
(4)
(5)
(6)
10
(7)
(8)
(9)
1
10−1
10−5
(10)
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Mounted on FR4 printed-circuit board; standard footprint.
(1) δ = 1.
(2) δ = 0.75.
(3) δ = 0.5.
(4) δ = 0.33.
(5) δ = 0.2.
(6) δ = 0.1.
(7) δ = 0.05.
(8) δ = 0.02.
(9) δ = 0.01.
(10) δ = 0.
Fig.3 Transient thermal impedance as a function of pulse time; typical values.
2004 Nov 08
5
NXP Semiconductors
Product data sheet
80 V, 4 A
PBSS5480X
006aaa233
103
Zth
(K/W)
(1)
102
(2)
(3)
(5)
(4)
(6)
10
(7)
(8)
(9)
1
(10)
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Mounted on FR4 printed-circuit board; mounting pad for collector 1 cm2.
(1) δ = 1.
(2) δ = 0.75.
(3) δ = 0.5.
(4) δ = 0.33.
(5) δ = 0.2.
(6) δ = 0.1.
(7) δ = 0.05.
(8) δ = 0.02.
(9) δ = 0.01.
(10) δ = 0.
Fig.4 Transient thermal impedance as a function of pulse time; typical values.
006aaa234
103
Zth
(K/W)
102
(1)
(2)
(3)
(4)
10
(5)
(6)
(7)
(8)
(9)
1
(10)
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Mounted on FR4 printed-circuit board; mounting pad for collector 6 cm2.
(1) δ = 1.
(2) δ = 0.75.
(3) δ = 0.5.
(4) δ = 0.33.
(5) δ = 0.2.
(6) δ = 0.1.
(7) δ = 0.05.
(8) δ = 0.02.
(9) δ = 0.01.
(10) δ = 0.
Fig.5 Transient thermal impedance as a function of pulse time; typical values.
2004 Nov 08
6
NXP Semiconductors
Product data sheet
80 V, 4 A
PBSS5480X
CHARACTERISTICS
Tamb = 25 °C unless otherwise specified.
SYMBOL
ICBO
PARAMETER
collector-base cut-off current
CONDITIONS
MIN.
TYP.
MAX.
UNIT
VCB = −80 V; IE = 0 A
−100
nA
VCB = −80 V; IE = 0 A; Tj = 150 °C
−50
μA
ICES
collector-emitter cut-off current
VCE = −60 V; VBE = 0 V
−100
nA
IEBO
emitter-base cut-off current
VEB = −5 V; IC = 0 A
−100
nA
hFE
DC current gain
VCE = −2 V; IC = −0.5 A
200
300
VCE = −2 V; IC = −1 A; note 1
180
280
VCE = −2 V; IC = −2 A; note 1
150
240
VCE = −2 V; IC = −4 A; note 1
80
150
−35
−55
mV
IC = −1 A; IB = −50 mA
−70
−105
mV
IC = −2 A; IB = −40 mA
−170
−250
mV
IC = −4 A; IB = −200 mA; note 1
−220
−340
mV
IC = −5 A; IB = −500 mA; note 1
−250
−380
mV
VCEsat
collector-emitter saturation voltage IC = −0.5 A; IB = −50 mA
RCEsat
50
75
mΩ
VBEsat
base-emitter saturation voltage
−770
−850
mV
−810
−900
mV
IC = −1 A; IB = −100 mA; note 1
−810
−900
mV
IC = −4 A; IB = −400 mA; note 1
−930
−1000 mV
VBEon
base-emitter turn-on voltage
−760
−850
mV
fT
transition frequency
IC = −0.1 A; VCE = −10 V;
f = 100 MHz
100
125
MHz
Cc
collector capacitance
VCB = −10 V; IE = ie = 0 A;
f = 1 MHz
60
90
pF
Note
1. Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
2004 Nov 08
7
NXP Semiconductors
Product data sheet
80 V, 4 A
PBSS5480X
001aaa753
−10
(4)
(3)
(2)
IC
(A)
−8
VBE
(V)
(5)
(6)
(7)
−0.8
(8)
−6
001aaa754
−1.2
(1)
(1)
(9)
(2)
(10)
−4
(3)
−0.4
−2
−0.4
(2)
(3)
(4)
IB = −300 mA.
IB = −270 mA.
IB = −240 mA.
IB = −210 mA.
Fig.6
−0.8
−1.2
(5) IB = −180 mA.
(6) IB = −150 mA.
(7) IB = −120 mA.
−10−1
−1.6
−2
VCE (V)
(8) IB = −90 mA.
(9) IB = −60 mA.
(10) IB = −30 mA.
−10
−102
−103
−104
IC (mA)
VCE = −2 V.
(1) Tamb = −55 °C.
(2) Tamb = 25 °C.
(3) Tamb = 100 °C.
Collector current as a function of
collector-emitter voltage; typical values.
001aaa755
600
−1
Fig.7
Base-emitter voltage as a function of
collector current; typical values.
103
001aaa756
RCEsat
(Ω)
hFE
102
(1)
400
10
(2)
1
200
(3)
10−1
(1)
(2)
−10−1
−1
−10
−102
10−2
−10−1
−103
−104
IC (mA)
VCE = −2 V.
(1) Tamb = 100 °C.
(2) Tamb = 25 °C.
−1
(3) Tamb = −55 °C.
IC/IB = 20.
(1) Tamb = 100 °C.
(2) Tamb = 25 °C.
(3) Tamb = −55 °C.
Fig.8
Fig.9
DC current gain as a function of collector
2004 Nov 08
8
−10
−102
(3)
−103
−104
IC (mA)
Equivalent on-resistance as a function of
NXP Semiconductors
Product data sheet
80 V, 4 A
PBSS5480X
001aaa757
−1
001aaa758
−1
VCEsat
(V)
VCEsat
(V)
−10−1
(1)
(2)
−10−1
−10−2
(3)
(1)
(2)
(3)
−10−2
−10−1
−1
−10
−102
−10−3
−10−1
−103
−104
IC (mA)
−1
−10
−102
−103
−104
IC (mA)
IC/IB = 20.
(1) Tamb = 100 °C.
(2) Tamb = 25 °C.
(3) Tamb = −55 °C.
Tamb = 25 °C.
(1) IC/IB = 100.
(2) IC/IB = 50.
(3) IC/IB = 10.
Fig.10 Collector-emitter saturation voltage as a
function of collector current; typical values.
Fig.11 Collector-emitter saturation voltage as a
001aaa759
−1.2
001aaa760
−1.2
VBEsat
(V)
VBEon
(V)
(1)
−0.8
−0.8
(2)
(3)
−0.4
−10−1
−0.4
−1
−10
−102
−10−1
−103
−104
IC (mA)
−1
−10
−102
−103
−104
IC (mA)
Tamb = 25 °C; VCE = −2 V.
IC/IB = 20.
(1) Tamb = −55 °C.
(2) Tamb = 25 °C.
(3) Tamb = 100 °C.
Fig.12 Base-emitter saturation voltage as a
2004 Nov 08
Fig.13 Base-emitter turn-on voltage as a function
9
NXP Semiconductors
Product data sheet
80 V, 4 A
PBSS5480X
Reference mounting conditions
32 mm
handbook, halfpage
32 mm
10 mm
40
mm
2.5 mm
40 mm
1 mm
10 mm
3 mm
2.5 mm
2.5 mm
1 mm
1 mm
0.5 mm
0.5 mm
5 mm
5 mm
3.96 mm
3.96 mm
1.6 mm
1.6 mm
MLE322
001aaa234
Fig.15 FR4, mounting pad for collector 1 cm2.
Fig.14 FR4, standard footprint.
32 mm
30 mm
mm
40
mm
2.5 mm
1 mm
0.5 mm
5 mm
3.96 mm
1.6 mm
001aaa235
Fig.16 FR4, mounting pad for collector 6 cm2.
2004 Nov 08
10
NXP Semiconductors
Product data sheet
80 V, 4 A
PBSS5480X
PACKAGE OUTLINE
Plastic surface-mounted package; collector pad for good heat transfer; 3 leads
SOT89
B
D
A
bp3
E
HE
Lp
1
2
3
c
bp2
w M
bp1
e1
e
4 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
bp1
bp2
bp3
c
D
E
e
e1
HE
Lp
w
mm
1.6
1.4
0.48
0.35
0.53
0.40
1.8
1.4
0.44
0.23
4.6
4.4
2.6
2.4
3.0
1.5
4.25
3.75
1.2
0.8
0.13
OUTLINE
VERSION
SOT89
2004 Nov 08
REFERENCES
IEC
JEDEC
JEITA
TO-243
SC-62
11
EUROPEAN
PROJECTION
ISSUE DATE
04-08-03
06-03-16
NXP Semiconductors
Product data sheet
80 V, 4 A
PBSS5480X
DATA SHEET STATUS
DOCUMENT
STATUS(1)
PRODUCT
STATUS(2)
DEFINITION
Objective data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary data sheet
Qualification
This document contains data from the preliminary specification.
Product data sheet
Production
This document contains the product specification.
Notes
1. Please consult the most recently issued document before initiating or completing a design.
2. The product status of device(s) described in this document may have changed since this document was published
and may differ in case of multiple devices. The latest product status information is available on the Internet at
URL http://www.nxp.com.
DISCLAIMERS
above those given in the Characteristics sections of this
document is not implied. Exposure to limiting values for
extended periods may affect device reliability.
General ⎯ Information in this document is believed to be
accurate and reliable. However, NXP Semiconductors
does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness
of such information and shall have no liability for the
consequences of use of such information.
Terms and conditions of sale ⎯ NXP Semiconductors
products are sold subject to the general terms and
conditions of commercial sale, as published at
http://www.nxp.com/profile/terms, including those
pertaining to warranty, intellectual property rights
infringement and limitation of liability, unless explicitly
otherwise agreed to in writing by NXP Semiconductors. In
case of any inconsistency or conflict between information
in this document and such terms and conditions, the latter
will prevail.
Right to make changes ⎯ NXP Semiconductors
reserves the right to make changes to information
published in this document, including without limitation
specifications and product descriptions, at any time and
without notice. This document supersedes and replaces all
information supplied prior to the publication hereof.
No offer to sell or license ⎯ Nothing in this document
may be interpreted or construed as an offer to sell products
that is open for acceptance or the grant, conveyance or
implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use ⎯ NXP Semiconductors products are
not designed, authorized or warranted to be suitable for
use in medical, military, aircraft, space or life support
equipment, nor in applications where failure or malfunction
of an NXP Semiconductors product can reasonably be
expected to result in personal injury, death or severe
property or environmental damage. NXP Semiconductors
accepts no liability for inclusion and/or use of NXP
Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at
the customer’s own risk.
Export control ⎯ This document as well as the item(s)
described herein may be subject to export control
regulations. Export might require a prior authorization from
national authorities.
Quick reference data ⎯ The Quick reference data is an
extract of the product data given in the Limiting values and
Characteristics sections of this document, and as such is
not complete, exhaustive or legally binding.
Applications ⎯ Applications that are described herein for
any of these products are for illustrative purposes only.
NXP Semiconductors makes no representation or
warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values ⎯ Stress above one or more limiting
values (as defined in the Absolute Maximum Ratings
System of IEC 60134) may cause permanent damage to
the device. Limiting values are stress ratings only and
operation of the device at these or any other conditions
2004 Nov 08
12
NXP Semiconductors
Customer notification
This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal
definitions and disclaimers. No changes were made to the technical content, except for package outline
drawings which were updated to the latest version.
Contact information
For additional information please visit: http://www.nxp.com
For sales offices addresses send e-mail to: salesaddresses@nxp.com
© NXP B.V. 2009
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed
without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license
under patent- or other industrial or intellectual property rights.
Printed in The Netherlands
R75/02/pp13
Date of release: 2004 Nov 08
Document order number: 9397 750 13891
