74LV132
Quad 2-input NAND Schmitt trigger
Rev. 6 — 9 December 2015
Product data sheet
1. General description
The 74LV132 is a low-voltage Si-gate CMOS device that is pin and function compatible
with 74HC132 and 74HCT132.
The 74LV132 contains four 2-input NAND gates which accept standard input signals.
They are capable of transforming slowly changing input signals into sharply defined,
jitter-free output signals.
The gate switches at different points for positive and negative-going signals. The
difference between the positive voltage VT+ and the negative voltage VT is defined as the
input hysteresis voltage VH.
2. Features and benefits
Wide operating voltage: 1.0 V to 5.5 V
Optimized for low voltage applications: 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 C
Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and
Tamb = 25 C
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
3. Applications
Wave and pulse shapers for highly noisy environments
Astable multivibrators
Monostable multivibrators
74LV132
Nexperia
4. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LV132D
40 C to +125 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74LV132DB
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads;
body width 5.3 mm
SOT337-1
74LV132PW
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74LV132BQ
40 C to +125 C
DHVQFN14 plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
SOT762-1
5. Functional diagram
Logic symbol
74LV132
Product data sheet
PQD
PQD
Fig 1.
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
PQD
Fig 3.
Logic diagram (one gate)
Nexperia B.V. 2017. All rights reserved
2 of 17
74LV132
Nexperia
6. Pinning information
6.1 Pinning
1A
terminal 1
index area
14 VCC
74LV132
9&&
1B
2
13 4B
1Y
3
12 4A
2A
4
2B
5
2Y
6
1
*1'
11 4Y
VCC
(1)
10 3B
9
8
3Y
7
GND
3A
001aah099
Transparent top view
DDF
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to VCC.
Fig 4.
Pin configuration SO14 and (T)SSOP14
Fig 5.
Pin configuration DHVQFN14
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A to 4A
1, 4, 9, 12
data input
1B to 4B
2, 5, 10, 13
data input
1Y to 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
7. Functional description
Table 3.
Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
nA
nB
nY
L
L
H
L
H
H
H
L
H
H
H
L
74LV132
Product data sheet
3 of 17
74LV132
Nexperia
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7.0
V
mA
50
mA
25
mA
50
mA
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = 0.5 V to (VCC + 0.5 V)
ICC
supply current
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
Tamb = 40 C to +125 C
SO14 package
[2]
500
mW
(T)SSOP14 package
[3]
500
mW
DHVQFN14 package
[4]
500
mW
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Ptot derates linearly with 8 mW/K above 70 C.
[3]
Ptot derates linearly with 5.5 mW/K above 60 C.
[4]
Ptot derates linearly with 4.5 mW/K above 60 C.
9. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage[1]
VI
Min
Typ
Max
Unit
1.0
3.3
5.5
V
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
[1]
Conditions
The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to
VCC = 1.0 V (with input levels GND or VCC).
74LV132
Product data sheet
4 of 17
74LV132
Nexperia
10. Static characteristics
Table 6.
Symbol Parameter
VOH
LOW-level output voltage
VOL
Conditions
40 C to +85 C
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
lO = 100 A; VCC = 1.2 V
1.2
V
lO = 100 A; VCC = 2.0 V
1.8
2.0
1.8
V
lO = 100 A; VCC = 2.7 V
2.5
2.7
2.5
V
lO = 100 A; VCC = 3.0 V
2.8
3.0
2.8
V
lO = 100 A; VCC = 4.5 V
4.3
4.5
4.3
V
lO = 6 mA; VCC = 3.0 V
2.4
2.82
2.2
V
lO = 12 mA; VCC = 4.5 V
3.6
4.2
3.5
V
IO = 100 A; VCC = 1.2 V
V
IO = 100 A; VCC = 2.0 V
0.2
V
IO = 100 A; VCC = 2.7 V
0.2
V
IO = 100 A; VCC = 3.0 V
0.2
V
IO = 100 A; VCC = 4.5 V
0.2
V
IO = 6 mA; VCC = 3.0 V
0.25
0.40
0.50
V
IO = 12 mA; VCC = 4.5 V
0.35
0.55
0.65
V
VI = VT+ or VT
VI = VT+ or VT
II
input leakage current
VI = VCC or GND;
VCC = 5.5 V
1.0
1.0
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
20.0
40
A
ICC
additional supply current
per input; VI = VCC 0.6 V;
VCC = 2.7 V to 3.6 V
500
850
A
CI
input capacitance
3.5
pF
[1]
Typical values are measured at Tamb = 25 C.
74LV132
Product data sheet
5 of 17
74LV132
Nexperia
11. Dynamic characteristics
Table 7.
GND = 0 V; For test circuit see Figure 7.
Symbol Parameter
propagation delay
tpd
40 C to +85 C
Conditions
power dissipation
capacitance
[1]
Min
Max
Min
Max
VCC = 1.2 V
65
ns
VCC = 2.0 V
18
34
43
ns
24
30
ns
nA, nB to nY; see Figure 6
15
VCC = 3.0 V to 3.6 V; CL = 15 pF
[3]
10
ns
[3]
12
ns
VCC = 4.5 V to 5.5 V
[3]
9.0
14
17
ns
CL = 50 pF; fi = 1 MHz;
VI = GND to VCC
[4]
24
pF
All typical values are measured at Tamb = 25 C.
[2]
tpd is the same as tPLH and tPHL.
[3]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[4]
Unit
[2]
VCC = 2.7 V
CPD
40 C to +125 C
Typ[1]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz, fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in V
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs.
12. Waveforms
9,
90
Q$Q%LQSXW
*1'
W 3+/
W 3/+
92+
90
Q
很抱歉,暂时无法提供与“74LV132D,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.739171+0.45323
- 10+3.1891710+0.38657
- 25+2.9760125+0.36073
- 100+2.38085100+0.28859
- 250+2.21049250+0.26794
- 500+1.87052500+0.22673
- 1000+1.445351000+0.17520
