74LVC1G10
Single 3-input NAND gate
Rev. 5 — 28 November 2016
Product data sheet
1. General description
The 74LVC1G10 provides a low-power, low-voltage single 3-input NAND gate.
The inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of
this device in a mixed 3.3 V and 5 V environment.
Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall
time.
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8-B/JESD36 (2.7 V to 3.6 V).
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74LVC1G10
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1G10GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC1G10GV
40 C to +125 C
SC-74
plastic surface-mounted package (TSOP6); 6 leads
SOT457
74LVC1G10GM
40 C to +125 C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 1.45 0.5 mm
SOT886
74LVC1G10GF
40 C to +125 C
XSON6
no leads; 6 terminals; body 1 1 0.5 mm
SOT891
74LVC1G10GN
40 C to +125 C
XSON6
extremely thin small outline package; no leads;
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74LVC1G10GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G10GW
YM
74LVC1G10GV
YM
74LVC1G10GM
YM
74LVC1G10GF
YM
74LVC1G10GN
YM
74LVC1G10GS
YM
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
DDJ
Fig 1.
Logic symbol
74LVC1G10
Product data sheet
DDJ
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3.
DDJ
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 17
74LVC1G10
Nexperia
6. Pinning information
6.1 Pinning
/9&*
/9&*
*1'
9&&
*1'
9&&
*1'
9&&
DDJ
DDJ
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
DDJ
Fig 4.
/9&*
Pin configuration SOT363
and SOT457
Fig 5.
Pin configuration SOT886
Fig 6.
Pin configuration SOT891,
SOT1115 and SOT1202
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
A
1
data input
GND
2
ground (0 V)
B
3
data input
Y
4
data output
VCC
5
supply voltage
C
6
data input
7. Functional description
Table 4.
Function table[1]
Input
Output
A
B
C
Y
H
H
H
L
L
X
X
H
X
L
X
H
X
X
L
H
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
74LVC1G10
Product data sheet
3 of 17
74LVC1G10
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VI < 0 V
[1]
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Min
Max
Unit
0.5
+6.5
V
50
0.5
+6.5
V
mA
mA
50
Active mode
[1][2]
0.5
VCC + 0.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
100
mA
100
mA
250
mW
65
+150
C
VO > VCC or VO < 0 V
output voltage
VO
[1]
Conditions
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For SC-88 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 package: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
74LVC1G10
Product data sheet
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
4 of 17
74LVC1G10
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
HIGH-level input
voltage
VIH
LOW-level input
voltage
VIL
VOH
HIGH-level
output voltage
LOW-level
output voltage
VOL
40 C to +85 C
Conditions
VCC = 1.65 V to 1.95 V
40 C to +125 C
Min
Typ[1]
Max
Min
Unit
Max
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
VCC = 2.7 V to 3.6 V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
0.35VCC
0.7
0.35VCC V
0.7
V
0.8
0.8
V
0.3VCC
0.3VCC
V
VCC 0.1
VCC 0.1
V
IO = 4 mA; VCC = 1.65 V
1.2
0.95
V
IO = 8 mA; VCC = 2.3 V
1.9
1.7
V
IO = 12 mA; VCC = 2.7 V
2.2
1.9
V
IO = 24 mA; VCC = 3.0 V
2.3
2.0
V
IO = 32 mA; VCC = 4.5 V
3.8
3.4
V
IO = 100 A;
VCC = 1.65 V to 5.5 V
0.10
0.10
V
0.45
0.70
V
VI = VIH or VIL
IO = 100 A;
VI = VIH or VIL
0.30
0.45
V
0.40
0.60
V
0.55
0.80
V
0.55
0.80
V
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1
1
A
IOFF
power-off
leakage current
VI or VO = 5.5 V; VCC = 0 V
0.1
2
2
A
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
4
A
ICC
additional supply VI = VCC 0.6 V; IO = 0 A;
current
VCC = 2.3 V to 5.5 V; per pin
5
500
500
A
CI
input
capacitance
3
pF
[1]
VCC = 3.3 V;
VI = GND to VCC
All typical values are measured at Tamb = 25 C.
74LVC1G10
Product data sheet
5 of 17
74LVC1G10
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 8.
Symbol Parameter
40 C to +85 C
Conditions
Min
Max
Min
Max
1.5
4.7
18.0
1.5
21.5
ns
1.0
3.0
6.5
1.0
7.8
ns
VCC = 2.7 V
1.0
3.0
6.0
1.0
7.5
ns
VCC = 3.0 V to 3.6 V
1.0
2.6
5.0
1.0
6.2
ns
1.0
1.9
3.6
1.0
4.4
ns
12
pF
propagation delay A, B and C to Y; see Figure 7
tpd
power dissipation
capacitance
CPD
40 C to +125 C Unit
Typ[1]
VI = GND to VCC; VCC = 3.3 V
[2]
[3]
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
12. Waveforms
9,
LQSXW
*1'
92+
90
W3/+
W3+/
90
很抱歉,暂时无法提供与“74LVC1G10GV,125”相匹配的价格&库存,您可以联系我们找货
